Re: Break in oil.. Zinc?
[Re: jlatessa]
#2780071
05/31/20 01:33 PM
05/31/20 01:33 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I love OIL threads, so entertaining.
So, if you go by the rules in USA, Shell Rotella T5 is Synthetic. But in the Euro rules it is just a highly refined dino oil... But it is still a good oil.
Zinc and Phorphous should be above 800 PPM for a slider cam. But this level will kill a CatCon so that is why most modern oils do not have any.
Most oil fanatics will NEVER blend different weights or brands. But if you do blend, kind of know what your mixing. For a street daily driver, mixing can be OK if your sphincter muscle is not too tight.
I have a 110 volt hot plate that will keep food at 145 to 170 degrees F. I do this outside in the driveway, not inside the garage... I would pour three quarts of my base stock oil into a 4 quart Revele Ware pan. Then I'd add the GM EOS Zinc additive, 1 can of STP and heat it up. I mix it real well and then pour some into the oil filter and the rest in the engine and top off with base stock oil.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2783126
06/09/20 10:29 AM
06/09/20 10:29 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
My engine builder said only use this for break-in. Plenty of zinc. He builds F.A.S.T. motors and knows what he is doing.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
[Re: Dave_J]
#2783171
06/09/20 11:53 AM
06/09/20 11:53 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Zinc and Phorphous should be above 800 PPM for a slider cam. But this level will kill a CatCon so that is why most modern oils do not have any. Really? “Most modern oils do not have any”? Please post your source for this very interesting information!
[Re: Pacnorthcuda]
#2783227
06/09/20 01:42 PM
06/09/20 01:42 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
A bit off topic...but thought I would post anyhow. Here is how I filled my 4 speed while in the car. It took awhile to fill all 3.5 quarts but worked very well. Don't ask me why I wasn't smart enough to fill before install.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: jlatessa]
#2783592
06/10/20 11:01 AM
06/10/20 11:01 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I think some of you are making this more difficult than it has to be.
Your viscosity should be bases on your clearances, if known.
We've used (for our clearances) VR1 as break-in and normal running with no problems, hyd. flat tappet, 6500 RPMs and solid roller stroker 6000 RPMs
Just our experience, I know many of your builds are more extreme, but VR1 has been flawless for us.
Just my 2 cents, Joe
Same here as I have used Valvoline VR1 racing oil as long as I can remember. Break in cams with it and have never wiped a cam. And I have always run flat tappet cams. I do add a bottle of zinc additive when breaking in a new cam but the VR1 Valvoline has been flawless for me also. Ron
