Re: Fuel bypass regulator... before or after
[Re: jughed]
#2779245
05/28/20 08:25 PM
05/28/20 08:25 PM
Posts: 23,295 Here
jcc
Here
So for the regulator after the feed thinkers, the question remaining, put the regulator up by the engine with a low pressure long return, or back with the fuel cell and a short return?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: jcc]
#2779253
05/28/20 08:40 PM
05/28/20 08:40 PM
Posts: 31,203 Oregon
AndyF
So for the regulator after the feed thinkers, the question remaining, put the regulator up by the engine with a low pressure long return, or back with the fuel cell and a short return? For EFI I'd put the regulator next to the fuel cell and just feed a high pressure line to the front. Not so sure I'd do that with a low pressure line though. Too many variables at play when you only have 5 or 6 psi. When you have 60 psi a long dead head stretch from the rear to the front doesn't seem to matter.
[Re: jughed]
#2779254
05/28/20 08:42 PM
05/28/20 08:42 PM
AndyF
Not to hijack the thread, but I have a 4-port dual carb. regulator...How would I plumb in a return line with this regulator? I have ran it as is with 2 ports plugged.I want to switch to e85 and would like to have a return line. The internals have already been changed to run e85, but if i need a different regulator, so be it. Check with the mfg. If the black fitting is the inlet then it looks like you just have four outlets and no return line but maybe there is something else going on that I don't see.
