automatic trans issue help requested
#2777758
05/24/20 06:21 PM
05/24/20 06:21 PM
RapidRobert
1997 dodge ran van with 4 speed automatic overdrive. for a week or 2 it was having a problem shifting into high (3rd I believe as I never activate the OD), I'd have to give it more throttle. then it had started to slip a bit (like it was almost in neutral & today I went several miles & at an intersection It would barely creep forward. after sitting a few minutes it barely crept forward enough to park it. after several hours I started it & it went about a half block good then total slippage in any gear position. I dont want to spend thousands at a trans shop & I have been wanting to get rid of it for awhile now. I was thinking of haveing it towed to a trans shop & have them replace fluid/filter & adj the bands & if that dont do it then I'll part it or junk it. do these symptoms sound like a possible fluid/filter/band issue? If not I might as well have em tow it home/forget the tran shop & call it done. Your thoughts please and thank you for your time.
Re: automatic trans issue help requested
[Re: RapidRobert]
#2777783
05/24/20 07:28 PM
05/24/20 07:28 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Fluid/filter change is a good idea. Bands have nothing to do with moving forward from a dead stop but an adjustment won't hurt.
If that doesn't correct the slipping, the rear clutch is the most likely culprit.
[Re: John_Kunkel]
#2777786
05/24/20 07:32 PM
05/24/20 07:32 PM
RapidRobert
Very much appreciated John, the tow truck driver is going to call in 30 minutes!
[Re: RapidRobert]
#2777787
05/24/20 07:43 PM
05/24/20 07:43 PM
Posts: 30,452 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
SPENDING THOUSANDS at a trans shop ??!! ..... and the issue being as simple as a rubber seal ? You bet ! ... and it did happen at a trans shop some years ago in a transmission shop STING!
[Re: RapidRobert]
#2777789
05/24/20 07:46 PM
05/24/20 07:46 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
I'm not one to disagree with John as he has way more knowledge on the transmissions than I do. But will say it certainly sounds like a filter clogging up when running and then dropping some of the debris back into the pan which allows a short time for fluid to pass until it sucks the debris up again. Fuel filters will do the same thing with a rusty tank. I would not be a bit surprised to find a lot of friction material in the pan and filter. If my suspicions are correct, a fluid/ filter change may buy a bit of time but I wouldn't count on it lasting very long good luck and keep us posted
[Re: poorboy]
#2780095
05/31/20 03:44 PM
05/31/20 03:44 PM
Posts: 422 montana
BANDIT
montana
Your better off to find a shop close to home, I did the “ I’m going to a reputable shop” that was 1000, miles away. Had issues with it, poor workmanship, wrong converter 2x, the shop owner was a pr##k to deal with. My $2000.00 ended up costing me $3500.00. Had a local guy fix it, he gets all my tranny work from now on. The shop that wanted 4 k is nuts!. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: poorboy]
#2780320
06/01/20 12:42 PM
06/01/20 12:42 PM
John_Kunkel
Rio Linda, CA
I would be leery of any shop that would reinstall an un-cleaned VB in a fresh overhaul. A governor pressure sensor and solenoid replacement should be part of any overhaul.
[Re: J_BODY]
#2780984
06/03/20 09:45 AM
06/03/20 09:45 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I had $1400 in parts alone for my 47RE..... but that was 16 years and 150k miles ago. Glad it’s just a hobby. I still hook up to my trailer and go anywhere without a worry. For clutches and seals? What else did you upgrade while you were in there? Kevin
[Re: Twostick]
#2781158
06/03/20 06:06 PM
06/03/20 06:06 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I rebuild mine for about 500 bucks and that included a rebuild torque converter.....not that hard to do.....
727 with overdrive.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2781224
06/03/20 09:30 PM
06/03/20 09:30 PM
RapidRobert
I'm not in any position to do any work right now. yeah the 4K quote got an immediate response from me! He was doing great up to that point with a $69.95 bill for the eval but it did take 10 minutes on the phone ahead of time to tell him that I am only authorizing the eval & nothing else. Not sure what I am gonna do for transportation in the near future. Guys thank you very very much for the additional feedback. this site rocks!
[Re: Twostick]
#2782009
06/06/20 08:56 AM
06/06/20 08:56 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
I had $1400 in parts alone for my 47RE..... but that was 16 years and 150k miles ago. Glad it’s just a hobby. I still hook up to my trailer and go anywhere without a worry. For clutches and seals? What else did you upgrade while you were in there? Kevin Input shaft and hub, clutches steels, all thrust washers and roller bearings, valve body kit, GOOD torque converter. All parts at dealer cost and aftermarket VB kit and converter.
