Re: Ramp truck
[Re: kenworth_goose]
#2778373
05/26/20 02:53 PM
05/26/20 02:53 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's my '92 D-350 hauler. Most good conversions involve a 4-foot frame stretch.
Re: Ramp truck
[Re: dOc …]
#2778588
05/27/20 06:50 AM
05/27/20 06:50 AM
Posts: 2,046 ky.
kenworth_goose
ky.
GOOSEer ... might I suggest 413,power ? I have a low mile 78 440 and a fresh set of 67 big valve 915 heads to bump up the compression. Should be a good combo. Later idea is a late model 6.7 and a 6 speed manual trans.
Re: Ramp truck
[Re: John_Kunkel]
#2778590
05/27/20 06:51 AM
05/27/20 06:51 AM
Posts: 2,046 ky.
kenworth_goose
ky.
Here's my '92 D-350 hauler. Most good conversions involve a 4-foot frame stretch. My plans have me adding 6ft of frame to it.
Re: Ramp truck
[Re: Handygun]
#2778826
05/27/20 05:53 PM
05/27/20 05:53 PM
Posts: 2,046 ky.
kenworth_goose
ky.
What's the max gvw on the door tag? 10k bit the suspension will be way heavier than stock.
Re: Ramp truck
#2778880
05/27/20 08:20 PM
05/27/20 08:20 PM
Posts: 30,494 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
GOOSEer ... might I suggest 413,power ? I have a low mile 78 440 and a fresh set of 67 big valve 915 heads to bump up the compression. Should be a good combo. Later idea is a late model 6.7 and a 6 speed manual trans. A stock 78 440 is a weak combo ... if you go that direction get the block sonic checked
Re: Ramp truck
[Re: dOc …]
#2778884
05/27/20 08:31 PM
05/27/20 08:31 PM
Posts: 2,046 ky.
kenworth_goose
ky.
GOOSEer ... might I suggest 413,power ? I have a low mile 78 440 and a fresh set of 67 big valve 915 heads to bump up the compression. Should be a good combo. Later idea is a late model 6.7 and a 6 speed manual trans. A stock 78 440 is a weak combo ... if you go that direction get the block sonic checked Only thing weak is the compression and the closed chamber heads will take care of that.
Re: Ramp truck
[Re: dOc …]
#2778896
05/27/20 08:55 PM
05/27/20 08:55 PM
Posts: 43,638 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My old ramp truck was a 93 3500 dually to begin with. PO made the frame extension and got a Hodges bed and built the frame to bolt it on.
JB Rhinehart, Realist
A-Body's RULE!
Re: Ramp truck
#2779055
05/28/20 12:41 PM
05/28/20 12:41 PM
Posts: 2,123 Byron, NY
W.I.N. Racing
Byron, NY
What's the max gvw on the door tag? 10k bit the suspension will be way heavier than stock. Ultimately it does not matter what the suspension is capable of... what will matter with the DOT in (you pick the state) is what the door tag says, That is why you see fewer and fewer (pick up based) ramp trucks. Here in the land of Taxes its approx $150 for the first 1-1000 Lbs of over weight,and goes up from there. Not including the impound, towing and all the other assessments they make once they find the first "cause" The second axle will need to have brakes equal to the first axle. BTW these are not NYS DOT regs but FED regs. If you dont plan on leaving you local area you may be fine but once you get out into the bustling metropolis its game on. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I used to have a Ramp truck (late '80s) 10000lbs door tag but 13000lbs going down the road loaded. Nice well maintained truck and could carry a Bulldozer (on more than on occasion) but stopping was another issue. Those days are behind us...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Ramp truck
[Re: W.I.N. Racing]
#2779190
05/28/20 06:09 PM
05/28/20 06:09 PM
Posts: 2,046 ky.
kenworth_goose
ky.
What's the max gvw on the door tag? 10k bit the suspension will be way heavier than stock. Ultimately it does not matter what the suspension is capable of... what will matter with the DOT in (you pick the state) is what the door tag says, That is why you see fewer and fewer (pick up based) ramp trucks. Here in the land of Taxes its approx $150 for the first 1-1000 Lbs of over weight,and goes up from there. Not including the impound, towing and all the other assessments they make once they find the first "cause" The second axle will need to have brakes equal to the first axle. BTW these are not NYS DOT regs but FED regs. If you dont plan on leaving you local area you may be fine but once you get out into the bustling metropolis its game on. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I used to have a Ramp truck (late '80s) 10000lbs door tag but 13000lbs going down the road loaded. Nice well maintained truck and could carry a Bulldozer (on more than on occasion) but stopping was another issue. Those days are behind us... None of this matters as it will be a Not For Hire project. I'm very much up on the knowledge needed for such a project. It will be way over built as with all of my truck and trailer projects. If I were to de a tandem the dead axle would be equipped with electric brakes. I hate to see units going down the road knowing they can't handle what they are towing or hauling. I'm a long time cdl-a driver, wreckmaster certified in towing and recovery as well as being an ASE certified tech in auto and trailer service and repair. I have built several trailers in the past. This truck will also tow a trailer. Trailer will have 3 3500lb axles as well as brakes on all 3 axles. I always use at least a 4 point tie down with anything on my trailers. The ramp truck will be no different. Actually I will use more when strapping down a vehicle on the ramp truck simply because I don't want something running over the cab with me in it. I will build a truck with the capability to do the job safely. And also being non commercial you can through any over weight tickets out the window as long as I'm under 26001 lbs.
Re: Ramp truck
#2779264
05/28/20 09:10 PM
05/28/20 09:10 PM
W.I.N. Racing
Byron, NY
What's the max gvw on the door tag? 10k bit the suspension will be way heavier than stock. Ultimately it does not matter what the suspension is capable of... what will matter with the DOT in (you pick the state) is what the door tag says, That is why you see fewer and fewer (pick up based) ramp trucks. Here in the land of Taxes its approx $150 for the first 1-1000 Lbs of over weight,and goes up from there. Not including the impound, towing and all the other assessments they make once they find the first "cause" The second axle will need to have brakes equal to the first axle. BTW these are not NYS DOT regs but FED regs. If you dont plan on leaving you local area you may be fine but once you get out into the bustling metropolis its game on. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I used to have a Ramp truck (late '80s) 10000lbs door tag but 13000lbs going down the road loaded. Nice well maintained truck and could carry a Bulldozer (on more than on occasion) but stopping was another issue. Those days are behind us... None of this matters as it will be a Not For Hire project. I'm very much up on the knowledge needed for such a project. It will be way over built as with all of my truck and trailer projects. If I were to de a tandem the dead axle would be equipped with electric brakes. I hate to see units going down the road knowing they can't handle what they are towing or hauling. I'm a long time cdl-a driver, wreckmaster certified in towing and recovery as well as being an ASE certified tech in auto and trailer service and repair. I have built several trailers in the past. This truck will also tow a trailer. Trailer will have 3 3500lb axles as well as brakes on all 3 axles. I always use at least a 4 point tie down with anything on my trailers. The ramp truck will be no different. Actually I will use more when strapping down a vehicle on the ramp truck simply because I don't want something running over the cab with me in it. I will build a truck with the capability to do the job safely. And also being non commercial you can through any over weight tickets out the window as long as I'm under 26001 lbs. OK ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
