Re: Converter slip under power
[Re: AndyF]
#2777834
05/24/20 09:49 PM
05/24/20 09:49 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I had a 10 inch"medium stall" from A&A behind a 408 in a 3450 lb car with 3.55 gears. It would flash to 4000 when i went WOT but would settle in at about 10 percent slip at cruise of 65 to 70 mph. A stock converter would probably slip 7 percent under the same conditions. At least that is what i saw in my dart. I had a lockup trans in it with the same gears and would see over 200 rpm slip at cruise speeds when not locked up.
[Re: AndyF]
#2777905
05/25/20 03:34 AM
05/25/20 03:34 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
Andy, do you know which converter company and model yours is? I had Chris at Contintental converters make me a custom 10 inch street and strip converter for my old pump gas Duster, that converter would foot stall right at 2300 RPM before pushing the 165x15 front tires through the staging beams, it would flash stall around 4200 to 4400 RPM depending on the track elevation and weather conditions. I broke it and install a Turbo Action 8 inch SS/AH Hemi foot brake converter I had in stock and that converter was way better on the street and at the track That change pick up my car at Madras .2+ ET and over 2+ MPH in the 1/8 mile , a little more gain at Woodburn also It drove real nice at light part throttle on the street and at the track and would flash stall up around 5200 RPM in high gear at WOT from a 35 to 45 MPH roll I think it had around 9% slippage across the finish line in the 1/4 mile
[Re: AndyF]
#2778093
05/25/20 03:15 PM
05/25/20 03:15 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
We have noticed no real change in slip % using various gear rations. We used everything from a 5.00 to a 5.48 in the car depending on the weather conditions and track. Stator changes will affect it but minimally. The lock up deal certainly changed the slip% but does not show on the time slip. Well that's not entirely true. We run the back half better with the lockup but we are much worse down low 0-60-330 which is where all the ET is. We used to have to run 5.09-5.12 to run 8.0's we now are running 8.0's going 5.18-5.20. We also have a high speed dump in the trans to drop the line pressure once out of low gear. We are changing the gearset in the trans this year as well as pump and stator combo to try and get back to 1.10-1.13 60' and 5.0's in the 1/8, but we may not get a chance to see if any of the engine and trans changes do anything this year.
[Re: AndyF]
#2778719
05/27/20 12:44 PM
05/27/20 12:44 PM
gregsdart
Since you most likely have a converter with as big a core and a tighter setup than my 10 inch AA, 3.55 or 3.73 gears with 27.5 inch tires should work fine. I sold that Dart, and the new owner drove it home 300 miles without any issues. 3.55 gears, 27.3 inch tall tires.
[Re: gregsdart]
#2778766
05/27/20 03:15 PM
05/27/20 03:15 PM
fast68plymouth
So. Burlington, Vt.
I doubt the 4.10 vs 3.89 gearing will have much affect on either the track ET or street performance, other than perhaps very light throttle cruising rpm being slightly lower. The converter just slips more with that taller gears, so the speed vs rpm hardly changes.
[Re: fast68plymouth]
#2778803
05/27/20 04:53 PM
05/27/20 04:53 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I don't have any experience on street driving, but on 1/4 mile passes I have had a converter at over 11% and my last combo 9 inch (getting a new motor and converter) is somewhere between 3 and 4%. Don't remember exactly. The high slip converters were 10 and 8 inch.
