New addition - 75 D200 #2776775
05/21/20 03:07 PM
05/21/20 03:07 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
One owner 75 D200 440 auto. After slapping on another oil pump, which had been borrowed, an intake and carb, it runs great. Major tranny leak requires it to be removed and the obvious reason it was parked. No real rust on cab or cab floor...just the rear wheel arches on back.
I bought it for the 440 and the dana 60 but I think it's going to force me to sell the 69 D100.
Re: New addition [Re: 64Bel] #2776866
05/21/20 10:07 PM
05/21/20 10:07 PM
Alberta
440_Offroader Online content
440_Offroader  Online Content
Alberta
Nice, too bad the box on the passenger side is wrinkled. I bought one several years ago similar to that for parts...the 400/727/203.
Re: New addition [Re: 64Bel] #2776944
05/22/20 09:18 AM
05/22/20 09:18 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
nice find! well worth saving.
1981 Dodge D150 360 auto
Re: New addition [Re: 440_Offroader] #2777111
05/22/20 04:56 PM
05/22/20 04:56 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
Yeah, it was rear ended slightly in that corner and farmer straightened to "good enuf!". The inside of the box is mint, it's like it was hardly used or at least protected except for one fist sized dent in the wheel well.
Re: New addition [Re: 64Bel] #2777238
05/22/20 10:16 PM
05/22/20 10:16 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
eek
OMG!! I'm having hard flashbacks right now! The Club Cab I owned back in the '90's was this same exact color (mine was a 1/2 ton though). I got rid of mine because the frame was coming apart I guess due to the high miles it had (300K+?). Mine had no real rust, but had numerous little dings and was lightly sideswiped down the passenger side of the bed. Mine originally had 360/727 and I swapped in a (stock) 440/727 from a '77 cop car. When I did the big block swap, I also swapped out the stock tank for a 36 gallon Ramcharger tank. Being that I did all this in the '90's, parts (and parts trucks) could still be found pretty easy and fairly cheaply.
*sigh*
John
Re: New addition [Re: 64Bel] #2777267
05/23/20 06:55 AM
05/23/20 06:55 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Nice find. What's on the drivers bedside near the cab? scope
Re: New addition [Re: redraptor] #2777286
05/23/20 08:37 AM
05/23/20 08:37 AM
SattyNoCar Offline
SattyNoCar  Offline
Looks like a door for an auxiliary tank (you can kinda see it hanging down)
work
John
Re: New addition [Re: SattyNoCar] #2777383
05/23/20 03:13 PM
05/23/20 03:13 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
Nice. Grandparents had a 74 club cab power wagon with a 440, beige and dark brown with an orange stripe, so I've always wanted one. Just had to wait until the right deal came along.
Did a bunch of research on rust repair panels and I see they are very reasonable. Only pieces not available are the lower rear box corners.
Re: New addition [Re: SattyNoCar] #2777385
05/23/20 03:16 PM
05/23/20 03:16 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
work
That's exactly it. Steel tank mounted outside the frame. Odd it wasn't installed on the other side for better weight balance. Guy said his dad used it mostly for hauling cattle.
Re: New addition [Re: 64Bel] #2777509
05/23/20 09:28 PM
05/23/20 09:28 PM
SattyNoCar Offline
SattyNoCar  Offline
work
Talking about weight balance, after I installed the Ramcharger tank in mine, it rode soooooooo much better (I rarely carried anything), handled a little better, and the infamous drivers side lean was hardly noticeable.
If the original tank hadn't been cracked, I seriously thought about keeping it and having over 50 gallons of fuel capacity as I knew I'd be driving it out to (Phoenix) AZ from MA.
Probably a good thing I didn't. panic
John
Re: New addition [Re: SattyNoCar] #2777684
05/24/20 01:52 PM
05/24/20 01:52 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
That could be a nice old cruiser. I like the color combo.
Facts are stubborn things.
Re: New addition [Re: larrymopar360] #2784337
06/11/20 10:21 PM
06/11/20 10:21 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
Went to plate it today....Has a salvage title on it...arrgh!! Always remember to check out the title first!
On a good note it now runs, moves and stops, but now I need to find out if it just needs an out of province inspection ($190) or full salvage inspection $600. That also means it might need to have the body work fixed before it can be driven.
Suffice it to say, I'm a little annoyed and pondering my plans for this truck.
