Re: Master Cylinder Push Rod?
[Re: ccdave]
#2777065
05/22/20 02:54 PM
05/22/20 02:54 PM
RapidRobert
too much travel or pedal height too low?
[Re: ccdave]
#2777075
05/22/20 03:04 PM
05/22/20 03:04 PM
Posts: 11,655 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
For an extra $15, the M/C kit with mounting parts is a deal. It's going to take some fabrication, a threaded pushrod and the right parts/retainers to make sure the pushrod is retained in the master cylinder correctly.
Typically I would cut and thread the original, use a long nut with a couple of jams to create a turnbuckle affair and use the adjustable rod the comes in the kit. You could probably use the two halves of the original and make it adjustable.
Did I say to make sure the retainer has a fresh rubber ring on it and is secure in the master cylinder?
[Re: ccdave]
#2789921
06/27/20 03:44 PM
06/27/20 03:44 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Problem is completely solved!!! I installed Wilwood brakes on all 4. Car stops like a new Corvette now! Glad it all worked out for you. An inch and an eighth is a pretty big bore MC. Pardon the barrage of questions that follow, but I'm interested. How is the pedal feel with the new set-up? Are the brakes touchy at all? Did you use/add a drum brake distribution block when you swapped in the new discs? Which brakes lock up first during hard braking?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: dvw]
#2790121
06/27/20 09:51 PM
06/27/20 09:51 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Make sure the rod is either held in with urethane or you build a better up stop for the pedal. If the stop lamp switch bends or comes loose the rod backing out of the master cylinder is a real possibility. Had a friend have this happen last year. Crashed the car bad and was injured pretty bad as well. Doug Unfortunately, this is common. Saw a car go off the end of National Trail at the Mopar Nats and get totaled from the pushrod falling out.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
