Master Cylinder Push Rod? #2777024
05/22/20 01:40 PM
05/22/20 01:40 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Got bored during COVID19 and installed rear disc brakes on my 70 Challenger. Also received a new Strange Engineering 1 1/8' master cylinder that did not come with pushrod, boot and adapter. I purchased the 2 stud adapter and used the stock pushrod. Result: lot's of pedal travel. Some say to use and adjustable push rod to make up for the adapter plate. What has your experience been when installing these lightweight aluminum master cylinders??? Thanks !
Re: Master Cylinder Push Rod? [Re: ccdave] #2777065
05/22/20 02:54 PM
05/22/20 02:54 PM
too much travel or pedal height too low?
Re: Master Cylinder Push Rod? [Re: ccdave] #2777072
05/22/20 03:00 PM
05/22/20 03:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As said already.. I make my own using a 3/8 pushrod and weld in the end that I need.. no more
than a small amount of slop
wave
Re: Master Cylinder Push Rod? [Re: ccdave] #2777075
05/22/20 03:04 PM
05/22/20 03:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
For an extra $15, the M/C kit with mounting parts is a deal. It's going to take some fabrication, a threaded pushrod and the right parts/retainers to make sure the pushrod is retained in the master cylinder correctly.
Typically I would cut and thread the original, use a long nut with a couple of jams to create a turnbuckle affair and use the adjustable rod the comes in the kit. You could probably use the two halves of the original and make it adjustable.
Did I say to make sure the retainer has a fresh rubber ring on it and is secure in the master cylinder?
Re: Master Cylinder Push Rod? [Re: CMcAllister] #2789517
06/26/20 03:17 PM
06/26/20 03:17 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Problem is completely solved!!! I installed Wilwood brakes on all 4. Car stops like a new Corvette now!
Re: Master Cylinder Push Rod? [Re: ccdave] #2789527
06/26/20 03:44 PM
06/26/20 03:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Make sure the rod is either held in with urethane or you build a better up stop for the pedal. If the stop lamp switch bends or comes loose the rod backing out of the master cylinder is a real possibility. Had a friend have this happen last year. Crashed the car bad and was injured pretty bad as well.
Doug
Re: Master Cylinder Push Rod? [Re: ccdave] #2789921
06/27/20 03:44 PM
06/27/20 03:44 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Glad it all worked out for you. An inch and an eighth is a pretty big bore MC. Pardon the barrage of questions that follow, but I'm interested. How is the pedal feel with the new set-up? Are the brakes touchy at all? Did you use/add a drum brake distribution block when you swapped in the new discs? Which brakes lock up first during hard braking?
Re: Master Cylinder Push Rod? [Re: dvw] #2790121
06/27/20 09:51 PM
06/27/20 09:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Doug
Unfortunately, this is common. Saw a car go off the end of National Trail at the Mopar Nats and get totaled from the pushrod falling out.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Master Cylinder Push Rod? [Re: Hemi_Joel] #2790137
06/27/20 10:18 PM
06/27/20 10:18 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Wilwood has a good setup for that. They have a washer that goes on the piston end of the rod and a snap ring that’s holds the washer in the bore. Can’t fall out.
