Re: Updated pictures.. July 4th..... UPDATES!
[Re: Edison62]
#277667
07/04/10 08:09 PM
07/04/10 08:09 PM
Posts: 4,130 Halifax, N.S. Canada
Edison62
Ok, got some updates..... been busy with the engine side of things mostly. So, the 4 speed hump has been welded in place and a coat of undercoating sprayed over the floor. Also had one small hole just below the bright switch.. also fixed!
Don't be stupid.... it's not smart!
1970 Super Bee. Big blk 4 speed car. 1973 Dodge Dart Sport 340 4 speed car. 1985 Dodge Ram D-100 /6 auto. Original paint 1990 Dodge Ram D-150 V-6 5 Speed. Original paint 1995 Chrysler LHS V-6 auto. Original paint 2014 Ram 1500 R/T 5.7 Hemi...!
[Re: Edison62]
#277670
07/05/10 11:57 AM
07/05/10 11:57 AM
Posts: 6,371 o
ChryCoGuy
o
Underside.......
Looking good, Bryan!
Just a question... would the factory have seam-sealed that from the bottom side?
[Re: Edison62]
#277672
07/06/10 08:17 AM
07/06/10 08:17 AM
Posts: 6,371 o
ChryCoGuy
o
Underside.......
Not sure, I'll be checking out a factory stick car to see exactly how it should look... then go from there. Theres still approx 1 inch of metal overhang on the underside that probably should be trimmed.
Bryan
Got it!
Might not be a bad idea to seal it anyway, to keep moisture from wicking through to the carpet if you happen to drive it in the rain.
Man, that car is gonna be awesome when you finish it!
Re: Updated pictures.. July 20th..... UPDATES!
[Re: Edison62]
#277674
07/20/10 04:17 PM
07/20/10 04:17 PM
Edison62
Just picked this up...
Bumpers are re-chromed and ready to pick up, should get them on Thursday (pic's to follow), engine has been bored out 30 over, crank polished and balanced, new pistons & rings ..... heads are getting a refresh w/hardened seats. Still need a big block bell housing and carb...
Bryan
Re: Updated pictures.. Aug 3rd..... UPDATES!
[Re: Edison62]
#277675
08/03/10 10:11 AM
08/03/10 10:11 AM
Edison62
Well, we have paint!!!!!! Got the steel rims painted up in FC-7 over the past weekend. Will mount the tires this week!
Re: Updated pictures.. Aug 20... UPDATES!
[Re: Edison62]
#277677
08/20/10 11:40 PM
08/20/10 11:40 PM
Edison62
Some fun pictures...... More purple soon... Rear end is done as is the 440........ Bryan
[Re: ]
#277679
08/24/10 10:46 PM
08/24/10 10:46 PM
Edison62
Hey Rob, it's been crazy......
Just finished building the 440 and rear diff... still collecting parts for the 4 speed.... sold our home end of June...moving on the 25th of Aug.... bought a bike ..... just got the FC-7 mixed (locals are switching to water base)....just had enough to mix.... it's just been a very busy time.
Bryan
[Re: Edison62]
#277680
08/26/10 12:36 AM
08/26/10 12:36 AM
Good luck with the move, hope all goes well. Nice bike!
