Originally Posted by Sammy
Originally Posted by rickraw
Put on an accusump on and be done.
I have one on the car already. It does not help
shock
How did you plumb it?Whay size is it?
I'm going to plumb mine(Canton 3 quart) in the return line going to the block from the remote mounted oil filter up
The oil pump will act as the check valve up
