Re: Can't Adjust fuel bowl height [Re: Sammy] #2773506
05/11/20 01:10 PM
05/11/20 01:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by Sammy
Originally Posted by CMcAllister
Originally Posted by 500dart
Check fuel pressure and replace needle and seats
This...Verify the gauge is right too. Needle and seats, as stated, I've had the O-rings shrink and not seal. If you screw the thing out and pull it out of the bore there should be a little felt resistance if its snug enough in the bore. Make sure the floats aren't heavy too.
There is no resistance at all o rings definitely look smaller and not plump.
All 4 are bad.
Never seen this happen before. This Q16 stuff is nasty.
Pump gas is also not good on this stuff. Have had this occur before. O rings shrink and get hard.
Q is not supposed to be left in the fuel system. Says on the can.
Re: Can't Adjust fuel bowl height [Re: CMcAllister] #2773541
05/11/20 02:12 PM
05/11/20 02:12 PM
Mark Whitener Offline
You can buy the o-rings at McMaster-Carr, 3.61 for 100. Part Number 9452K16, Make sure the surface the ring seats on in the bowl doesn't have anything stuck in there or pitted, also make sure your floats are not heavy. A cheap small gram scale will do it, float weight at the link.
https://www.tapatalk.com/groups/racingfuelsystems/holley-float-weights-t31.html
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Can't Adjust fuel bowl height [Re: Mark Whitener] #2773827
05/12/20 10:46 AM
05/12/20 10:46 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
In addition, I use Vaseline on the needle n seats when installing em.......
Re: Can't Adjust fuel bowl height [Re: Sammy] #2774239
05/13/20 02:59 PM
05/13/20 02:59 PM
Winston-Salem, NC
JackZ Offline
JackZ  Offline
Winston-Salem, NC
I chased a problem like that a couple years ago and it turned out that the new foam float I got was molded a little off and it hit the body of the carb inside the float bowl so it would stick open and not shut off. So once I found it I filed the foam a little bit to cure the interference and then sealed the filed spot with clear nail polish and it's worked well ever since.
And how I found it was by removing the needle and seat from the assembled carburetor and then bending a small (~1/8") right angle hook on a paper clip and sticking it into the hole from the removed needle and seat and hooking into the tang on the float arm and gently trying to move the float up and down. When I compared how much the paperclip and float moved when the float bowl was off the carburetor to how much it moved when it was assembled (and hitting internally) it became very apparent that something was wrong there.
Re: Can't Adjust fuel bowl height [Re: fourgearsavoy] #2774528
05/14/20 02:21 PM
05/14/20 02:21 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Originally Posted by fourgearsavoy
Summit sells a kit or there is a guy on E-bay that sells a pack of 10 O-rings
https://www.summitracing.com/parts/sum-200400?rrec=true
Gus beer
So I ordered a 10 pack of o rings off of ebay. Shipped $11.25
Was cheaper from all carbs but I'm ok with it.
I did order 4 new needle and seats from Summit.
The o rings showed up 1st. Lol
So i picked out the old o rings and sure enough they were brittle and just snapped off.
Going to install the needle and seats in a few after lunch and see if the problem is still there.
Hopefully this was the fix. The needles were cleaned and they move freely.
Re: Can't Adjust fuel bowl height [Re: Sammy] #2774551
05/14/20 03:28 PM
05/14/20 03:28 PM
Cab_Burge Online work
Cab_Burge  Online Work
Are your new O rings Viton, neopreme or what are they made of?
Love that Q16, don't we whistling grin
Re: Can't Adjust fuel bowl height [Re: Cab_Burge] #2774565
05/14/20 03:45 PM
05/14/20 03:45 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I believe they are viton.
I'll have to check but I just installed them and they are a nice tight fit.
Adjusted them to where I think they should be and NO MORE FLOODING.
And yes this Q16 is nasty stuff.
And I do drain the bowls after each use.
Putting this on my maintenance schedule.
