Re: 1st Gen 1998 Dodge Durango Problems
[Re: SportFuryS/23383]
#2779712
05/30/20 11:53 AM
05/30/20 11:53 AM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
I got the crank sensor from RockAuto in the mail today. It will most likely be put in tomorrow. I looked up a video on how to replace it and it looks kind of like a real B.....fill in the rest to do. Has anyone else replaced one before?
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
#2780080
05/31/20 01:59 PM
05/31/20 01:59 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Factory repair manual says to R&R the wheel & tire and the inner fender liner. Probably be easy to get to after all that but I just leaned in over the R. fender and used a 1/4" ratchet and socket. Little bit aggravating but not too bad. Had to lean in over the drivers side to disconnect the pigtail from the main harness. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2780086
05/31/20 02:36 PM
05/31/20 02:36 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Factory repair manual says to R&R the wheel & tire and the inner fender liner. Probably be easy to get to after all that but I just leaned in over the R. fender and used a 1/4" ratchet and socket. Little bit aggravating but not too bad. Had to lean in over the drivers side to disconnect the pigtail from the main harness. Tim I looked up how to do it on YouTube and the guy went through like the manual said with removing the tire and fender liner, wasn't too bad actually and was easier than we thought
[Re: A990]
#2786639
06/17/20 11:24 PM
06/17/20 11:24 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi All,
Just wanted to give an update on my Durango. It has been running great lately, and I just put gas in it today. I put the Gumout in the tank first then put in about 18 gallons of gas......
