Re: To cold spark plugs?
[Re: lewtot184]
#2773171
05/10/20 12:36 PM
05/10/20 12:36 PM
Posts: 138 Sweden
Mopar493
Sweden
the more I think about this engine the more I think any kind of performance ignition curve is a waste. your engine, in my opinion, is more efficient than a stocker with that high vacuum. I have a stock 440 I run around in and it's not as efficient as yours. i'd 'bet it's doing well over 20"hg vacuum at cruise speed; maybe 22-24",...? i'd try a curve very similar to the original mopar performance electronic distributors. I think that would be a good baseline and go from there. hopefully your not using a loose torque converter (if this is an automatic transmission) or low rear gears (numerically high). Ok thanks, i will see if i find some good Mopar distributor or try to rebuild the FBO one. Im using a TCI breakaway converter 2400 stallspeed, the engine have huge low end and not going to see much more than 5500-6000 rpm, no meaning to rev higher with this cam and hydraulic lifters.
[Re: lewtot184]
#2773189
05/10/20 01:30 PM
05/10/20 01:30 PM
Posts: 138 Sweden
Mopar493
Sweden
try a 68x52 metering rod. something to keep in mind is the relationship between the engines high vacuum and the annular boosters. the high vacuum may be making the annular boosters over sensitive. i'm sure once the vacuum advance comes into play some of that carbon will be cleaned up. i'd take the FBO distributor apart and see what's in there. Ok i will try it, thanks for the advice
[Re: Mopar493]
#2775198
05/16/20 06:39 PM
05/16/20 06:39 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
This plug is not to cold The mixture is to rich though, lean it down a little Hi, thanks for answer. Im driving Ngk 6 now, the carb is one step leaner with 63-47 metering rod and the original 5hg orange feather,i have 18hg inch vacuum at idle. I get the FBOdistributor working properly now, its running better with that, no misses at idle and a rock steady timing mark, better with vacuum advance for the street. It looks rich, this big Mopar seems to not want so much fuel😃 Factory metering rod is .065x.052 If you are running .063x.047 metering rods with the factory jets .104 You are over 8% RICHER from stock
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2775296
05/17/20 02:11 AM
05/17/20 02:11 AM
Posts: 138 Sweden
Mopar493
Sweden
This plug is not to cold The mixture is to rich though, lean it down a little Hi, thanks for answer. Im driving Ngk 6 now, the carb is one step leaner with 63-47 metering rod and the original 5hg orange feather,i have 18hg inch vacuum at idle. I get the FBOdistributor working properly now, its running better with that, no misses at idle and a rock steady timing mark, better with vacuum advance for the street. It looks rich, this big Mopar seems to not want so much fuel😃 Factory metering rod is .065x.052 If you are running .063x.047 metering rods with the factory jets .104 You are over 8% RICHER from stock Hi, i know the usuall avs 800 have .094 primary jet i belive but look at this avs2 800 calibrating chart, both primary and secondary is .104 from factory, richer factory settings of some reason and i see what i have missed to go one step leaner, i have not change the jet from ,104 to .101, otherwise .063x.047 needle is one step leaner on this chart.
[Re: Mopar493]
#2775318
05/17/20 08:08 AM
05/17/20 08:08 AM
bee1971
Sobieski Wi
If you don’t want to dig into the carb to change the Primary Jet
Keep the factory .104 Primary Jet
First try
A .068x.057 Metering Rod and see how your plugs look and the car runs
10 minute job
I run the 7" Vacuum Metering Rod Springs Also
[Re: bee1971]
#2775370
05/17/20 11:10 AM
05/17/20 11:10 AM
Posts: 138 Sweden
Mopar493
Sweden
First try
10 minute job
I run the 7" Vacuum Metering Rod Springs Also I will try to change the rod and see
