Page 1 of 12 1 2 3 11 12
46rh Governor Questions #2771867
05/06/20 04:26 PM
05/06/20 04:26 PM
46rhRebuild Offline OP
Hello, I am in the process of rebuilding a donor transmission for my 1994 Dodge Ram 1500 4x4 with the 5.9L magnum engine. Upon disassembling the overdrive housing I discovered a configuration to the governor that I have not seen before. The donor transmission was advertised being out of a 1995 Ram 1500 2wd with a 5.9L. The governor has steel internal and external weights, yet has two external counterweights that feel like they are tungsten.
My question is this: Is this an appropriate setup for a gas application, or is this a diesel converter that wound up in this transmission?
I have had to replace so many of the internals due to parts failures that I am afraid that I am dealing with someone's franken-transmission. I have attached pictures below to show what I mean.
Also, I have the proper 4x4 extension housing that I'm installing, I just needed the internals and the main casing from this 2wd transmission.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2771912
05/06/20 07:04 PM
05/06/20 07:04 PM
A727Tflite Online content
A727Tflite  Online Content
The two external counterweights shown in the bottom photo are to counteract the weight of the governor.
Diesel governor weights are made of brass.
Re: 46rh Governor Questions [Re: A727Tflite] #2771979
05/07/20 12:37 AM
05/07/20 12:37 AM
Thank you very much for your help, sir. I had posted this before I spoke to you earlier. To clarify, all internal weights for Diesel governors are brass? Do the diesel governors also sometimes employ external counterweights? Cobra Transmission has the only picture of an external-counterweight governor that I could find, and it was listed as a diesel unit. That led me to erroneously conclude that I was dealing with a diesel governor.
Please forgive my lack of knowledge. Though this truck is my work vehicle and daily driver, the 1994 Dodge single cabs were always my dream trucks, and I am attempting to return this truck to it's former glory, largely by myself. So, if you are amenable, I will continue to post questions as I think of them. I do have one additional one now.
When I first tore down this transmission, the thrust bearing on top of the rear overdrive planetary gear was melted directly to it, also the intermediate shaft has deformed against the pocket in the shaft in the forward clutch. Both of those shafts were ruined, the intermediate shaft was peened over so badly that I had to dremel it round to get the aluminum gear set to slip off of it. It looked as if someone had neglected to install the three tab washer and the hardened race that fits onto the end of the intermediate shaft. My question is this: What typically causes damage like this?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2771984
05/07/20 03:09 AM
05/07/20 03:09 AM
Guitar Jones Offline
It sounds like lack of lubrication to me. Trash could be stuck inside the intermediate shaft blocking fluid flow. Most typically a converter failure will fill the fluid with trash, plug the cooler and starve the lube circuit. Always replace the torque converter, and clean and flow test the cooler or better yet, replace the cooler.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: 46rh Governor Questions [Re: Guitar Jones] #2771989
05/07/20 05:52 AM
05/07/20 05:52 AM
iagree
Re: 46rh Governor Questions [Re: A727Tflite] #2772640
05/08/20 09:07 PM
05/08/20 09:07 PM
Thank you very much for that advice, gentleman. I have a new torque converter from Precision of New Hampton that will be installed, model 5443HS . It was recommended as being a high quality oem replacement. Any thoughts on their converters?I will procure a new trans cooler, just in case. Is the Hayden Transaver 1402 adequate for this transmission?
I sincerely appreciate the help, and apologize for my delay in replying. My older brother just came back from his last deployment to Afghanistan, two days ago, and I've been helping him move. The old truck is limping along and still managing to haul truckloads, even with the leaking front seal. I hope to have the transmission fully rebuilt and at the shop for the local mechanic to swap out, later this upcoming week. In the meantime I just keep adding fluid.
The overdrive clutch pack is assembled, and aligned. I will be rebuilding the governor on Monday. The ATSG manual says to inspect the governor sealing rings for wear or damage. It has the teflon rings installed, and there are no nicks. Does anyone happen to have the measurement of good tolerances for those rings?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2772759
05/09/20 08:32 AM
05/09/20 08:32 AM
Precision makes good converters, you won’t have any issues with them.
Teflon sealing rings are pretty forgiving so unless you damage them installing them you won’t have any issues. Just make sure the grooves are not damaged, clearance is not an issue with them.
Thank your brother for helping his Uncle out, I hope he is doing well.
Re: 46rh Governor Questions [Re: A727Tflite] #2773052
05/10/20 12:15 AM
05/10/20 12:15 AM
Thank you for clarifying the teflon ring questions. Also, I am glad to know that Precision does good work.
This transmission build has been a very good learning experience for me. I was absolutely terrified of transmissions, prior to this. Though I understand that this is almost as bare bones as an automatic gets. Trust me, I have zero ego about my abilities in regards to them. There is a gentleman who posted a series of youtube videos detailing the breakdown and re-assembly of these units, else I never would have attempted this on my own. I believe that he owns a website called TheTransmissionBench. The Service Manual and ATSG manual also have provided much needed guidance, along the way.
I did not attempt to tear down and rebuild the valve body on my own. I bought a two solenoid (with boost tube) valve body that had been remanufactured and updated with a Sonnax kit, from Central Valve Bodies, by way of a reseller. The gentleman who owns that shop is name Donny Lester, I believe. I hope that that was a wise move.
In regards to my older brother, he's doing well since he got back stateside. He has the full support of the family, and we're just happy to have him home. Thankfully this was the last deployment before his 20 years are complete. One more year and he's retired and moving onto the civilian trade world.
I have seen that these transmissions can be tested with an air compressor, prior to re-installation. Do you happen to know, off hand, what specialty gauges or fittings are necessary to test the servos on a 46rh? Again, thank you for all of your help, this has been an experience.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2773075
05/10/20 06:44 AM
05/10/20 06:44 AM
A rubber tipped blowgun with air pressure regulated down to 20 or 30 lbs. is all you need.
Listen for leakage. Some guys use real high pressure - real high will mask cut seals.
Just hit the servos to watch them actuate then the front and rear clutch.
Make sure you use a clean air source (drain your compressor of water) before using it.
Re: 46rh Governor Questions [Re: A727Tflite] #2773346
05/10/20 09:01 PM
05/10/20 09:01 PM
Thank you again, sir. I drained my compressor today. Wow, I hadn't realized how much water had accumulated in there.
Are there any quirks to these transmissions that I should keep an eye out for?
I bought the special tools to measure for the correct overdrive shim thickness. Also, I picked up the sonnax shim kit. How critical is replacing the intermediate shaft spacer? I have the tool to measure for that, as well.
I am really happy with the one that's still in the truck. I have no idea how many miles are on it, total, but the fluid has always been bright and it's always shifted well. I can tell that it's tired and needs to be replaced with a fresh build, on top of the leaking seal, though. I've personally put almost 100,000 miles on that transmission. No towing, just daily driving. The shifts have gotten mushy, even with proper band adjustments, and there's substantial power loss, and I think occasional slipping in third, but it's hard to tell.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2773386
05/11/20 03:10 AM
05/11/20 03:10 AM
The intermediate shaft shim shouldn’t have to be changed unless you changed the intermediate or the output shaft.
It ultimately affects input shaft end play so make sure it’s there.
Re: 46rh Governor Questions [Re: A727Tflite] #2773654
05/11/20 06:55 PM
05/11/20 06:55 PM
I have changed both the output shaft, and the intermediate shaft.
I basically had to build a complete overdrive unit from spare parts. The only parts that will be original (in the overdrive unit) are the governor, and the overdrive direct drum. The entire overdrive gear set came from a 46re, it's the newer 22 degree angled gear set. I bought it as a unit, and was told that as long as it's not mixed with any earlier 15 degree parts, then it will work fine.
The intermediate shaft was ruined and the front of the shaft galled and rounded back over the retaining snap ring groove.
Have I made mistakes in my calculations with these parts? Everything has fit together in the overdrive assembly smoothly, and the thrust bearings are all oriented properly. I paid special attention to that.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2773707
05/11/20 09:41 PM
05/11/20 09:41 PM
Biggest issue to new builders is forgetting to install the overdrive bearing on the back of the overdrive piston, or putting those bearings upside down.
Don’t forget you need to check with the special tool and select the correct overdrive shim. If the shim you need is in between two shim thicknesses, always go to the next thicker shim.
Good thing you know about the tooth angle changes between diesel and gas.
As for the shafts being replaced, you must check with the special tool to make sure you select the correct thickness shim that goes on the back of the intermediate shaft. Oil everything up, especially those needle bearings, and you should be golden.
Re: 46rh Governor Questions [Re: A727Tflite] #2773730
05/11/20 11:18 PM
05/11/20 11:18 PM
I oiled the bearings liberally with transmission fluid before installing them. I also used Red Transjel to stick them into their respective places in order to keep the orientation straight. It helped that they only wanted to sit flush one way, and they're oriented the same way as each other. Even though I checked twice, I may pull the overdrive assembly apart again because I'm second guessing myself.
I will be taking both measurements, for both of the shims, tomorrow.
Oh, the seal on the back of the 4wd overdrive housing, should I install it with the opening (the side with the spring in it) toward the transfer case or back facing the overdrive internals?
Also, are the 22 degree angled gears appropriate for a gas application? This transmission is going behind a 5.9L Magnum.
Thank you for putting up with all of this new guy's questions. I couldn't find straight answers to these questions anywhere. Not in the FSM, the ATSG book, or in other forums.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2773765
05/12/20 06:47 AM
05/12/20 06:47 AM
The seal gets installed with the garter spring facing in to the overdrive unit. It keeps trans fluid in the trans. The seal on the transfer case has its spring facing in to the t/fear case. You will notice a groove cast in to the bottom of the overdrive extension housing. That is a weep hole, do not plug it up with RTV. If you see a leak from it investigate where the leak is coming from by using the color of the fluid to determine the source.
I would stick with the 15 degree parts. As for fluid I would only use Mopar ATF + 4 or equivalent. The overdrive will love you for it.
Re: 46rh Governor Questions [Re: A727Tflite] #2773939
05/12/20 04:29 PM
05/12/20 04:29 PM
Ok, I need to order another seal because I installed that one backwards.
I've only ever used ATF+4 in it, from everything that I read, there's nothing like it for these Chrysler transmissions.
Unfortunately I only have the 22 degree gears. What will this effect in the long run?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2773971
05/12/20 06:51 PM
05/12/20 06:51 PM
I have heard of a few noise complaints in gas applications besides that won’t hurt a bit.
Re: 46rh Governor Questions [Re: A727Tflite] #2774287
05/13/20 05:08 PM
05/13/20 05:08 PM
Today I began reassembling the overdrive unit to take measurements.
I ran into a huge problem. The governor key slot is different betweenthe original shaft and the 4x4 shaft I was sold. The key shown in the ATSG book is a small square whereas the key that came with the governor is a large half moon shaped.
Can you advise on whether I was sold the wrong shaft, or if I just need a different key?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2774305
05/13/20 05:52 PM
05/13/20 05:52 PM
It’s been too long, I don’t recall what if any differences there are but I would have to imagine you got the wrong key.
Re: 46rh Governor Questions [Re: A727Tflite] #2774308
05/13/20 05:55 PM
05/13/20 05:55 PM
Lacking milling equipment, I don't trust myself to cut this key super accurately. Would you trust a key cut with a bandsaw and filed as true as I could get it, for an application like this?
On second thought, the words Precise Measurement and Transmission seem to go hand in hand. I bought the last 4x4 output shaft that I could find, and it will be here by Tuesday. I visually verified that it had the proper key way slot.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2774332
05/13/20 07:05 PM
05/13/20 07:05 PM
Like I said it’s been too long, can’t imagine why we would make two different keyway slots, especially in your case, both being 4 x 4.
Unless the shaft you have is an aftermarket piece.
All the key does is align and hold the governor support so the weight/valve rod passes through the shaft.
Let’s see the key ways on all the shafts when you get the next shaft.
Re: 46rh Governor Questions [Re: A727Tflite] #2774373
05/13/20 11:29 PM
05/13/20 11:29 PM
I will definitely take pictures of them.
I was very surprised that this shaft had a different key way slot. The overall measurements were within spec, it has the governor hole through the shaft, and was advertised as an A518/46rh shaft. The key way is about a 1/4 as deep as the 2wd shaft that I got the governor from.
Found this interesting article detailing the endplay measurements on 46rh/re transmissions. From an ATRA March 2008 issue. Found it while searching for overdrive key specs.
https://atracom.blob.core.windows.net/gears/2008/2008-03/2008_3_10.pdf
Re: 46rh Governor Questions [Re: 46rhRebuild] #2774379
05/13/20 11:57 PM
05/13/20 11:57 PM
When I began this project I was proceeding with the knowledge that the only three components that were different between the 2wd and 4wd versions of the this transmission were the Extension housing itself, the Ouput shaft, and the Seal at the rear of the extension housing. So I began assembling pieces.
My parts list thus far for this build will be:
1. Transtar rebuild kit (seals, steels, Alto and Exedy frictions, etc) $88
2. Precision of New Hampton torque converter $146
3. 4x4 Extension housing $126
4. Ouptut shaft (now x2) $80 total
5. Overdrive planet assembly $60
6. Forward clutch drum and input shaft $45
7. Remanufactured valve body $260
8. Hayden 1405 trans cooler $27
9. Sonnax OD piston retainer $60
10. Various shims, bushings, assembly lube $60
11. Base price of "rebuildable" transmission $350
12. Measuring tools and alignment shaft $100.
Total price $1402 plus $500 labor to have my local mechanic swap the trans for me.
(Yes, I thought it would be cheaper to do it this way. I know, I'm an idiot.)
The Pro of all of this is that I'll know how to rebuild this truck's transmission everytime it needs it, and thanks to you, I'm learning how to rebuild it right, the first time.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775193
05/16/20 05:05 PM
05/16/20 05:05 PM
Here are both shafts. I installed the key in each one to show the difference in depth. The key way slot on the shallow shaft is also substantially longer.
Please let me know if you'd like additional photos showing any particular part of these.
I've seen pictures of 47rh shafts that have a similar looking keyways as the original shaft. I don't know if that helps at all. Here's a link showing the picture that I found. https://goerend.com/tcs-23-spline-billet-output-shaft-47rh-618101/
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775213
05/16/20 06:22 PM
05/16/20 06:22 PM
I see this as a non issue. Use either shaft you like, just make sure you have enough key sticking up enough to pilot the governor housing. As I said earlier, the housing doesn’t see any load.
Re: 46rh Governor Questions [Re: A727Tflite] #2775233
05/16/20 07:38 PM
05/16/20 07:38 PM
Thank you, sir. I have cleaned and installed the shaft I just bought.
I'll have a spare should I ever need one, and can have a machine shop make a proper key for it. I'll take the measurement of how much it protrudes above the shaft and log it in my build folder, for future use.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775295
05/17/20 01:07 AM
05/17/20 01:07 AM
Put the overdrive unit back together and pulled these measurements tonight.
Overdrive Thrust Plate
.7829
.7834
.7829
.7829
Chart is saying shim thickness .138-.140. I have the Sonnax shim kit but the base race of that kit is .175, and the spacer that I already have is .213. Luckily I was able to find the correct size for sale.
Intermediate Shaft End Play
.7470
The chart says that I need a shim that is .158-.159 thick, Moparpartsgiant.com is the only website that I could find with that size in stock.
Also, pulled the key protrusion measurement, in case anyone ever needs it. Key protrudes .180 proud of shaft.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775320
05/17/20 07:13 AM
05/17/20 07:13 AM
Look at the chart and select the shim that is the size called for or the next size thicker than called for.
Never go smaller.
Don’t forget that once the overdrive is built, install it before stuffing the trans. Then build the trans.
That procedure should be called out in any of the correct publications.
Re: 46rh Governor Questions [Re: A727Tflite] #2775473
05/17/20 03:18 PM
05/17/20 03:18 PM
The video series that I've been referencing says to build the transmission this way.
What is the reasoning behind this? I am not arguing, I genuinely want to know what this influences.
I appreciate your continued instruction. I also hope that all of this helps someone else, as other forum posts got me started on this project.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775557
05/17/20 06:37 PM
05/17/20 06:37 PM
Back to front because the intermediate shaft has to be in place to properly set input shaft endplay.
That’s why the intermediate shaft shim has to be selected to start with, that is a baseline dimension from the extension housing gasket face - down to the inside of the overdrive unit - if I recall to the top of the planetary.
Re: 46rh Governor Questions [Re: A727Tflite] #2775582
05/17/20 08:12 PM
05/17/20 08:12 PM
So is there another endplay measurement taken once I start re-assembling the main barrel of the transmission?
I wondered that when I kept seeing intermediate shaft endplay shims for sale. Is it a good idea to go ahead and order one of those endplay shim sets to have on hand for this build?
I looked at the washer kit that I bought for this build and saw that I have three of the three tab washers and a new hardened steel race. These look identical to what is pictured in the end play shim kits. Do I have what I need, sir?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775605
05/17/20 09:50 PM
05/17/20 09:50 PM
Once you have used the proper tools and selected and installed the correct shims in the overdrive unit and it’s installed on the trans, then build the trans using the standard procedures. Check and set geartrain end play (front and rear planetaries and drive shell), then adjustment of input shaft end play.
Re: 46rh Governor Questions [Re: A727Tflite] #2775919
05/18/20 06:43 PM
05/18/20 06:43 PM
I had to go back to the ATSG book to understand exactly what you meant there, (this is all very new to me.) I am going to list the measurements that I need to take. Please advise me if I have forgotten any critical measurements.
As I am building the main case of the transmission, I take measurements of:
1. The Front Clutch w/ feeler gauge under high point of wavy snap ring (should be within .070-.129")
2. The Rear Clutch w/ feeler gauge under high point of wavy snap ring (should be within .025-.045")
3. Planetary Gear Train End play w/ feeler gauge ( should be within .006-.048")
Once these measurements have been taken and everything is within spec, do I need to use a dial indicator to measure the total shaft endplay once the transmission has been assembled?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775927
05/18/20 07:04 PM
05/18/20 07:04 PM
You have everything correct as long as the overdrive is done and bolted on, just need to set input shaft endplay.
For your application try to stay in the middle of the clutch pack clearance specs.
Don’t forget that when you build the overdrive assembly to use the tool to line up the splines in the overdrive planetary and ORC otherwise you won’t be able to install the Intermediate shaft.
Re: 46rh Governor Questions [Re: A727Tflite] #2775932
05/18/20 07:20 PM
05/18/20 07:20 PM
Yes, sir. I have already made that mistake and had to take apart the overdrive to realign it. I check the alignment every time I move the unit.
Thank you for the advice about shooting for the middle of the clearance specs. Is my overdrive being on the tight end of spec a concern?
I am currently waiting on the correct spacers (overdrive thrust and intermediate shaft) to arrive, so I can begin assembly of the trans.
I was inspecting the main case last night and noticed that the overunning clutch cam was pushed very slightly forward. I can move it move forward and back on one side very slightly, but it does not want to rotate or move otherwise. Do I need to replace?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2775978
05/18/20 08:45 PM
05/18/20 08:45 PM
On the OD shim, use the next thicker shim if you fall in between two shims or you are close to the top of a given spec range.
As for the main ORC I would press it down in the case, re-stake all around it and make sure the set screw is
If you tow, or will be on sand, loose soil or doing pulling make sure you use low gear and not drive, the read band will help save the orc.
Re: 46rh Governor Questions [Re: A727Tflite] #2776019
05/18/20 11:00 PM
05/18/20 11:00 PM
I remeasured the OD shim tonight and I got a nasty surprise. I must have messed up my original measurement somehow. I am glad that you stressed it and that I double checked it.
The correct measurement average is 1.828. The Sonnax shim plus one spacer brings me to .185. The FSM says range is 1.8250 - 1.8399. Shim thickness .183 - .185. Would you leave it at .185 or add another .010 shim?
I turn off the OD unless I'm on the highway, I was told that it would make my trans last longer.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2776063
05/19/20 07:32 AM
05/19/20 07:32 AM
No, you are good, you are not at the top of the range. 1.828 is closer to the bottom of the range than to the top.
ATF + 4 really helped out all the transmissions - especially the RWD OD units. You shouldn’t have any issues leaving it in OD.
Re: 46rh Governor Questions [Re: A727Tflite] #2776184
05/19/20 03:31 PM
05/19/20 03:31 PM
Thank you for clarifying the shim range. I was fairly certain that I was in bottom of the range, but I'm learning to triple check when it comes to transmissions.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2776584
05/20/20 07:14 PM
05/20/20 07:14 PM
The replacement input shaft and planetary gear train came in, fully assembled. I checked the endplay measurement on it. .034. The ATSG book says that .006 - .048 is within spec.
I'll disassemble the assembly to make certain the thrust washers are in good shape. I'll recheck clearance after this. I bought all new washers, just in case.
If I understand correctly this entire assembly is inserted into the trans in one piece. Is this correct?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2776588
05/20/20 07:24 PM
05/20/20 07:24 PM
Yes as long as you have the shim installed before doing so.
Re: 46rh Governor Questions [Re: A727Tflite] #2776597
05/20/20 07:47 PM
05/20/20 07:47 PM
Yes, sir. The shim should be here by Friday. I know to be very careful about over spreading the shim when installing.
Are there any oddities in this part of the build that I should watch out for?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2776612
05/20/20 08:41 PM
05/20/20 08:41 PM
Lube it, stab it, follow the service manual. From this point forward after the intermediate shaft is installed, it goes together lime a regular 727.
Just be careful when you install the valve body that the OD/LU plug that enters the case does not get cocked and broken.
Make sure to check the OD accumulator spring in the valve body, they like to break from time to time.
Re: 46rh Governor Questions [Re: A727Tflite] #2777901
05/25/20 01:34 AM
05/25/20 01:34 AM
Yes, sir. Thank you for that advice. I know that the plastic housing on the pin is delicate.
I had to halt work on the trans in preparation for a busy memorial day weekend, but work resumes on it tomorrow.
First order of operation is to disassemble the planetary gear train, lube all bearings, and check thrust washer condition. Pre-dissassembly clearance is on the tighter end. I bought the gear train as an assembled unit, but I don't trust that everything is well lubed.
The video series that I have been consulting assembled the planetary gear train component by component inside the main barrel. Do you recommend this approach, or assembling the gear train beforehand and stabbing it?
Any recommendations for increasing the life of this rebuild is appreciated. I have time to order components if there are any parts that I should update.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2778192
05/25/20 08:48 PM
05/25/20 08:48 PM
You can assemble the geartrain either way. The transmission plant built the geartrain, checked the clearance then installed the assembled intermediate assembly.
Be clean, follow the directions in the pubs, run the unit to get the oil level qualified, then run it through the gears with the rear end off the ground through all the gears.
Re: 46rh Governor Questions [Re: A727Tflite] #2778340
05/26/20 12:14 PM
05/26/20 12:14 PM
I got the servos repopulated, the intermediate shaft support installed, and seated the overdrive yesterday. It was kind of a bear to seat. I was gentle with it because of the governor tubes, but I had to wiggle and fight it on a bit. Is this normal?
It seated so oddly the first time that I pulled it back off, and boy did it not want to come back off. The second time it seated the same way, so I guess it's just how this one wants to go together. I lubed the intermediate support where it contacts the bushings in the OD, so I know it wasn't because of lack of lubrication.
I used the Sonnax intermediate support, and NOT the oversized one.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2778426
05/26/20 04:14 PM
05/26/20 04:14 PM
Alright, I've got another weird one.
With the reverse drum in place, and a new thrust washer installed, there isn't enough clearance for the snap ring to install into the intermediate shaft support. What did I mess up?
I'm pulling the overdrive back off and making sure that the intermediate shaft support is all the way in. Its torqued to the right specs already but it's not much. I really only need another .020 of an inch to get this snap ring to clear.
EDIT: Pulling the overdrive housing and retapping the shaft support gained me no clearance. Maybe somewhere in the build I mixed up a couple of snap rings and this one is just too thick. I'm off to find a thinner washer or snap ring. Or sand this washer down if a thinner replacement isn't available.
Any advice is welcome if you've run into this problem before.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2778520
05/26/20 08:23 PM
05/26/20 08:23 PM
I think the correct L/R drum snap ring is angle cut on the ends. With the drum out the snap ring should fit in the groove. The correct thrust washer should have two anti rotation tabs on it.
There is nothing in the OD unit that would cause this issue. Only thing I can think of Is the ORC cam/rollers/race are not seated. The race should be pressed on the drum. Make sure it’s pressed on all the way. The cam should be pressed in to the case without any clearance between the cam and back of case.
As for the effort to seat the overdrive, that’s not uncommon. If you used the correct tool to assemeble the OD in the press and didn’t manhandle the unit/drop it before assembly on the trans then it’s just one of those units that’s difficult.
You have to keep the planetary and direct hub lined up during the OD build process.
Re: 46rh Governor Questions [Re: A727Tflite] #2778539
05/26/20 09:22 PM
05/26/20 09:22 PM
The snap ring I have is angled on the ends, and it fits in the groove without the washer installed. The washer is also .062 of an inch and has two anti rotation tabs. There isn't enough clearance for both of them, and the washer blocks the snap ring entrance, about halfway, when it's installed
I verified that the cam, and the sprag is seated well but I will tap the cam gently tomorrow with a round brass shaft to ensure that it's seated all the way. I don't have any way of fitting it in my little press.
I read that there are different drums that were used in the 727 and A518, and sometimes get mixed up. One used a delrin plastic washer and apparently didn't have as deep of an indent for the washer, from what I understood. When I was tearing down this trans I didn't find any kind of washer in that drum. I kept all the used parts just in case and I didn't see anything like it when I went through them again. I also noticed that my drum doesn't look like any of the A518 drums I'm seeing. It looks like a 46re drum. Does that change anything?
If I sand the non indented side of the washer to make this all fit, am I going to hurt anything?
Thank you for your assessment of the overdrive. I used a homemade tool to press the OD unit, but I used my alignment tool to make sure everything was lined up, and after installing the overdrive housing I found that it had stayed aligned. The third time installing the housing was much easier and it just kind of drew down into place.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2778607
05/27/20 07:58 AM
05/27/20 07:58 AM
I’m not aware of any differences between the very late style 727 and 518 drum, there may be.
Any drum that uses the snap ring and thrust washer must have the machined step in the drum though.
Re: 46rh Governor Questions [Re: A727Tflite] #2778728
05/27/20 12:10 PM
05/27/20 12:10 PM
It has the step in, but there isn't enough clearance. The washer is .062 which seems to be stock, the snap ring is .060 even. I also tapped the cam fully seated, there was about .006 under there. Now it won't allow a .0015 feeler gauge.
I suspect the drum, because the cam is fully seated, and the washer and snap ring still don't have clearance. This is a genuine Sonnax shaft support, so I imagine that it's true.
What's your take, sir?
EDIT: I asked a couple of sellers of remanufactured drums to pull a measurement of that step in, the most common measurement I've gotten back is .088. The one that came in this trans measures .020.
New drum is on it's way. I decided to replace the sprag, as well, just in case. I'll post how it continues once the new parts are in.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2781171
06/03/20 05:32 PM
06/03/20 05:32 PM
Received the correct reverse drum. The drum, metal washer and snap ring all dropped right into place, took less than five minutes.
The first picture shows the wrong reverse drum on the left, and the correctly cut drum on the right. The incorrect cut was .020, and the correctly cut drum measured .088. All other measurements appear to be identical. I'm being specific about the measurements in case anyone else runs into this with one of these rebuilds.
The second picture shows the correctly cut drum step.
The third shows how shallow the original drum was cut. Does anyone know which application would use a .020 cut reverse drum?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2781257
06/03/20 10:04 PM
06/03/20 10:04 PM
Where the band rides, same diameter between the two?
Still looking for my plant info - when I find it maybe there is an explanation for the depth differences.
Sorry, I have been offline for a while.
Re: 46rh Governor Questions [Re: A727Tflite] #2781577
06/05/20 12:04 AM
06/05/20 12:04 AM
I've been offline, myself. Busy, as I'm sure you are.
The two drums miked the same in all measurements that I could accurately pull, except for that step in. Aside from one being lipless, of course.
The gentleman who runs the transmission shop I bought it from sent me a new snap ring and an old plastic style (Torlone?) washer. I used the new metal washer with the relief cuts (relief cuts placed toward reverse drum).
He also pulled measurements from a half dozen drums for me and sent me the drum with the largest cup. He said that .075 was the most common he found, aside from the .088 he sent me.
It installed with almost no play, but the snap ring sits firmly in the groove and will move rotate around the groove with a fair amount of force applied. I figure this means that it's seated properly, and is not binding at all.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2781947
06/05/20 09:44 PM
06/05/20 09:44 PM
Finally had a chance to look for my plant info.
Info mentions changes from no thrust washer to a thrust washer.
Heat treated in that countersink area gets a snap ring without the thrust washer.
Non heat treated gets the thrust washer.
Re: 46rh Governor Questions [Re: A727Tflite] #2782275
06/06/20 09:11 PM
06/06/20 09:11 PM
I don't have any way to check for specific hardness. I didn't notice any kind of washer when I removed the drum originally, so perhaps the original is a hardened drum. It's now just sitting in a box of spare parts if anyone has a specific need for it.
Thank you very much for looking that information up.
The trans is in the final stages of being built. The forward and reverse drum have been assembled, and fall within spec. The pump will be getting cleaned and checked tomorrow.
Should I air check the servos before I install the valve body?
Also, are there any pitfalls to avoid when installing the VB or inserting the parking pawl down into the overdrive section?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2782283
06/06/20 09:47 PM
06/06/20 09:47 PM
The drum with the blued recess has the hardening I mentioned and does not use the thrust washer.
The one without the bluing is not hardened and uses the washer.
If you plan on using air pressure I would lower it to 30 psi before testing. The rear servo is easier to test if you just install the servo piston then bring it up almost out of the bore then close the apply hole off with your finger tip. Then try to push the piston down. If you can’t the seal is good.
If you used metal seal rings on the front servo piston and retainer it’s pretty difficult to screw those up unless you used a hammer. 😀
Teflon seals should be tested with air like the rear servo using the same pressure rate.
The park rod can easily be placed in the wrong spot. I find it easier to install the rod with the trans vertical, while someone tries to turn the output shaft. The plant actually installed the rod only, then the valve body and they had a tool that held the 3/4 snap ring so it’s could be installed once the rod engaged the valve body.
Re: 46rh Governor Questions [Re: A727Tflite] #2783411
06/09/20 08:10 PM
06/09/20 08:10 PM
Thank you for clarifying about the drums.
I absolutely DID NOT use a hammer to install anything internal to this transmission. Two seals on the outside, yes.
I have replaced every single teflon seal, metal seal, o ring, lip seal, plastic clutches etc that I've come across. I trust no seals a second time. Also those plastic sprags kinda scare me too.
I figured that the park rod was going to be one of the pains in the butt. Luckily the trans is vertical so I might just have to stab it and check, rinse and repeat, until I get it right.
I started to worry that I was going to wind up with a faulty build, because of all of the oddities that I've encountered. But everything is coming up within spec, the servo bores looked great, all the seals went in well, and I've got a professionally rebuilt and updated VB that I'm installing. So I should probably relax and just get this thing buttoned up.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2783528
06/10/20 06:32 AM
06/10/20 06:32 AM
Didn’t mean to imply you used a hammer, but that’s about what it takes to damage the metal seals.
Re: 46rh Governor Questions [Re: A727Tflite] #2784139
06/11/20 12:54 PM
06/11/20 12:54 PM
I took no offense, sir. I was laughing at the thought. Your advice has been invaluable, and I sincerely appreciate all of it.
I know that slipping that servo into the bore was tricky. I used the back of a screwdriver to tap it so that it would sit flushly and I could press it in by hand. I don't imagine that that could have hurt it, though. The guy in the videos used the back of a hammer, oddly enough.
I grew up working on diesel engines. I've seen people do dumb things to delicate parts with hammers so I do my best to avoid that behavior. I watched a guy deform a very expensive fuel rail because it wouldn't slip into place for him.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2795161
07/10/20 01:11 PM
07/10/20 01:11 PM
I apologize for the long absence, but had to focus on more immediate work for the last month.
I'm assembling the front direct clutch drum, and the frictions that I was supplied are the hi-energy waffle pattern frictions. Will this affect anything if I use these in place of the flat frictions that I see depicted in the book and videos I'm referencing?
This are the frictions that shipped with my rebuild kit, part number A22008E.
Also the gentleman in the videos says that if the clearance is tighter than .090 then binding will occur between the 2-3 shifts. The FSM states that .070-.129 is good to go. Is there any truth to this? I ask because my assembly measures at .078.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2795215
07/10/20 03:36 PM
07/10/20 03:36 PM
Using production hard parts and following production specs won’t cause binding.
That’s usually caused by messing with servo internals, front clutch release spring stack, and sometimes messing with the valve body.
Most guys tend to stick with the middle of the spec range for clurch clearance but you will be fine where you are.
As for the waffle discs, they provide more lube to the clutch discs which helps cool the clutch - like in snow plow use, frequent reverse applications.
The other theory is that the waffle grid wipes the oil off the steels faster instead of hydroplaning.
Like sipes in a tire.
Re: 46rh Governor Questions [Re: A727Tflite] #2795217
07/10/20 03:47 PM
07/10/20 03:47 PM
Thank you for explaining that. I had a feeling that was the purpose, but wanted to double check before I installed it all.
And.....it happened again. I was sold another part that does not match the specs for what I need. The front input shaft has a flared edge that is two different sizes, where it mates with the inner pump bushing. I'll take a picture and post it below.
The new one I was sold measures 1.235, whereas the old one measures 1.172. So I guess I get to go find another shaft. Because the original one is ruined where it mates with the intermediate shaft.
The new one is on the left.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2795240
07/10/20 05:01 PM
07/10/20 05:01 PM
If you are talking about the journal below the two input shaft seal rings, yes there are two sizes for the more modern units.
Re: 46rh Governor Questions [Re: A727Tflite] #2795242
07/10/20 05:05 PM
07/10/20 05:05 PM
Yes, sir, that is exactly what I mean. I realize that I was solely focused on the front sealing ring diameter, not even thinking about the large journal that rides in the stator bushing. I'm trying to track down the smaller correct size.
Are there any major pitfalls to avoid when pressing one out and into that front drum?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2795279
07/10/20 07:13 PM
07/10/20 07:13 PM
Look closely just below that journal and you will notice a wire retainer ring. That has to come out first.
Then press the input shaft out - “up” as shown in your images.
Support the rear clutch piston support in your press as close to the diameter of the input shaft as possible, like where the thrust washer seats.
I have seen guys crack the support when not doing so.
Re: 46rh Governor Questions [Re: A727Tflite] #2795543
07/11/20 03:44 PM
07/11/20 03:44 PM
Thank you, sir. I hope it does not come to that. The seller says they are going to make it right. Hopefully they have the correct OD shaft and drum assembly.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2795697
07/12/20 06:18 AM
07/12/20 06:18 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
This wonderful thread should be expanded into a book.
As an owner of a 1995 46RH that needs an overdrive unit rebuild I never knew there were so many important part variations.
Re: 46rh Governor Questions [Re: 360view] #2795963
07/12/20 08:04 PM
07/12/20 08:04 PM
If it hadn't been for Transman, I would never have been able to tackle this build with any success. I had zero knowledge of the parts differences in these transmissions, either.
I'm happy if my build can help any other people. The actual assembly isn't hard, just follow his hints! He's saved me alot of time and pulled me out of the woods everytime I've gotten stuck.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2796287
07/13/20 06:54 PM
07/13/20 06:54 PM
In case anyone needs to know the two different journal sizes on these input shafts, here they are.
The small shaft measures 1.159 OD on the land that rides in the stator bushing.
The large shaft measures 1.243 OD on the land that rides in the stator bushing.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2806987
08/09/20 05:40 PM
08/09/20 05:40 PM
Alright, back at it for the last part of the build before install.
The three tab thrust washer was missing on this build originally, What is the correct thickness washer to use?
I ordered a three tab thrust washer and hardened steel race kit, but am unsure which thickness I should be using.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2807031
08/09/20 07:26 PM
08/09/20 07:26 PM
Doing further research, I see that I need to install the rest of the assemblies, including the pump with no o-ring for ease of removal. Then measure total endplay with my Starret dial indicator. If I fall within specs, then I'm good to go. I've installed the intermediate of the three thrust washers first.
Endplay comes to .030 with the intermediate of the three washers installed. I'm searching through all my publications to find out if this is within spec. If anyone has specs around please post so that I can confirm.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2807080
08/09/20 09:07 PM
08/09/20 09:07 PM
.036 - .086” seems to be the number. I’ll check in a bit.
Re: 46rh Governor Questions [Re: A727Tflite] #2807230
08/10/20 10:48 AM
08/10/20 10:48 AM
Thank you sir. Using the thinnest of the three washers will get me there, it looks like.
Here's what I did, if you don't mind checking my work.
1. Install input shaft, rear drum, then pump, aligning everything (washer and hardened race installed). I did not intall the kickdown band
2. Install gasket and hand tighten two of the pump bolts to hold it in place
3. Used a lever against the shaft (unit is upright) to move it to the extreme upward range before the transmission wants to move as a unit.
Dial read exactly .030
Re: 46rh Governor Questions [Re: 46rhRebuild] #2807336
08/10/20 02:36 PM
08/10/20 02:36 PM
With the thin washer installed, the endplay is now .041.
Got the drums, kickdown band, and pump installed. All that's left is the valvebody, as far as I can tell.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2807368
08/10/20 03:58 PM
08/10/20 03:58 PM
2000 MY manual calls for .034” to .084” so hit me with a 2 x 4 - I was off .002” on min/max.
You will usually get a different number if you stand the trans up versus checking while horizontal.
At .041” I think you are good to go.
Re: 46rh Governor Questions [Re: A727Tflite] #2807398
08/10/20 05:11 PM
08/10/20 05:11 PM
Thank you, sir. Once the valvebody is installed at some point this week (trade school is back in full swing again, so that's most of my time) I'll check the endplay while horizontal.
Is it worth it to try to track down one of the tools used for attaching the eclip onto the valve body, rather than trying to stab it as one unit? I remember you saying it was really easy to screw up the location of the parking pawl.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2807460
08/10/20 08:04 PM
08/10/20 08:04 PM
Since your unit is vertical already I would just install the vb and rod as an assembly. Just be aware of the position of the rod passage and focus on that during installation. It helps to have someone turn the output shaft as you install the vb/rod assy.
Don’t forget to be careful installing the vb in regards to the od plug - lightly grease that bore and the pass through plug. Start a couple vb bolts then work the linkage to make sure park works.
Re: 46rh Governor Questions [Re: A727Tflite] #2808231
08/12/20 08:06 PM
08/12/20 08:06 PM
Thank you, sir. I appreciate all of the advice. I will report back once the VB is installed this weekend, and let you know how it went.
VB install will be this upcoming weekend. Still trying to find someone to swap this thing, my normal mechanic is a month and a half out.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2817330
09/05/20 09:03 AM
09/05/20 09:03 AM
Finallly have room at my mechanic's shop for him to do the swap either this upcoming week. The truck is finally succumbing to the brutal Florida heat, and I can feel the loss of power on the highway in third gear.
So, today is VB installation. I don't have another hand to help turn it, so will just do my best to get it stabbed right.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2817503
09/05/20 03:38 PM
09/05/20 03:38 PM
Finally assembled. New Precision of New Hapton TC and 36,000 GVW Hayden cooler going in with this rebuild.
I could not have done this without Transman. Thank you sir. I sincerely appreciate your patience in teaching this complete new guy how to do this. This is my first transmission build, and I was completely lost in the wood until you came and bailed me out.
I hope all of this different information helps out another guy who has to do this on his own, and maybe runs into some of the same problems that I did.
To whomever did this horrible damage to this first transmission, you're something I won't say here. However, your idiocy turned into a teachable moment for me, so I guess I owe them alittle thanks.
I will post a report after the trans is installed, and after I've driven it for a bit. Thank you all.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2817515
09/05/20 03:58 PM
09/05/20 03:58 PM
Glad you got it back together.
One last suggestion, leave the return line off at the cooler line fitting at the back of the main case, place it in a clear jug like a windshield solvent bottle.
Install approx 8 quarts of trans fluid in the trans. Have an assistant start the engine with the trans in park. Unless the valve body has been modified you should not have fluid flow to speak of.
When idling place the trans in neutral, once flow starts you should pump a quart of fluid out in about 10-12 seconds.
Once a quart is pumped place in park and shut the engine off.
This will make sure the whole cooler circuit is good, clean and that the anti-drain down valve is not stuck closed.
Top off the fluid and you should be good to go.
Re: 46rh Governor Questions [Re: A727Tflite] #2817526
09/05/20 04:20 PM
09/05/20 04:20 PM
The VB has an updated Sonnax kit installed. I will go find the specs that they gave me. Ok, here they are: Upgraded Manual Valve, Upgraded Switch Valve, Upgraded Pressure Regulator Valve, all Solenoids are tested, rebuilt or replaced with new.
Unfortunately, I won't be the one installing this. I'm not set up to do it. My mechanic has been doing this for 30 plus years, so I hope he verifies that everything is flowing. If not, I can do this once I get the truck back home, its only a five minute drive. Is it common for the anti-drain down valve to be stuck after a rebuild?
A new cooler is going in, but I'm reusing the same lines. As of right now the fluid in the old unit is still bright, and when I had the pan down it had no bad sludging or metal flakes. My mechanic said he'd blow the lines out with compressed air, to check for any blockages.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2817700
09/06/20 07:05 AM
09/06/20 07:05 AM
My guess is the Sonnax regulatormvalve has the pump prime feature which means it should have cooler flow in Park. That’s good.
As for blowing out the lines with compressed air, he wil only be able to blow in one direction if the valve is in the line.
With a new cooler and since the old trans fluid was nice and red you are probably fine.
Re: 46rh Governor Questions [Re: A727Tflite] #2818180
09/07/20 01:30 PM
09/07/20 01:30 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Not to hijack your thread, but since trans guys are on here, I have a 98 Dakota, V6, not sure what trans is in it.
It's not been changed, so what's in it, and is there anything to do to take out some of the "slack". Slow from drive to reverse and visa versa, upshifts are good.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 46rh Governor Questions [Re: Magnumguy] #2818201
09/07/20 02:26 PM
09/07/20 02:26 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
i believe you have an A500 transmission.
if the unit is in good repair, a shift kit should solve your problem.
just my opinion, your mileage will vary.
beer
Re: 46rh Governor Questions [Re: moparx] #2818237
09/07/20 04:47 PM
09/07/20 04:47 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I was thinking a newer style, I hope you’re right
Re: 46rh Governor Questions [Re: Magnumguy] #2818383
09/07/20 10:11 PM
09/07/20 10:11 PM
A500 also goes by 42/44RE.
42/44 is the later industry designation that went in to use.
First digit is number if shifts, second number is relative torque capacity, R is rear wheel drives and E is electronic.
As for the slack you are talking about, if it does this first time in the day and does not occur the remainder of the day then it’s likley torque converter drain down.
Need more info.
Re: 46rh Governor Questions [Re: A727Tflite] #2822317
09/18/20 02:36 PM
09/18/20 02:36 PM
Update on the transmission project.
Took the truck to mechanic's shop, tuesday before last. Popped in today to find out why I hadn't gotten any news. Found out he'd just moved the truck, with the transmission in the bed, over to his side open lot, and left it sitting in the back the entire time, and through the hurricane. He said "It was covered." I had covered the ends with heavy garbage bags and wrapped a tarp around it.
I pulled the bags off when I drove the truck back home and didn't see any signs of water inside the bags, around the seals, or anywhere near the entrances.
Do I pull the transmission apart to check everything, or do I sound ok? Please advise, I do not want all of my work to be in vain.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2822437
09/18/20 08:47 PM
09/18/20 08:47 PM
If the bags and tarp are totally dry inside you are likely ok. If the converter was in place only way for water to enter is the OD unit or dipstick opening.
As a quick check, pull the pan and make sure.
No converter, water could enter the pump and not get in to the pan but you should see rust I would think.
But you said things were dry so......
Re: 46rh Governor Questions [Re: A727Tflite] #2822591
09/19/20 12:26 PM
09/19/20 12:26 PM
So, just to be safe I went and dropped the pan.
The valvebody and filter were dripping water after I unbolted them.
I have the case and OD unit apart, and have pulled everything in the main case, am drying, and cleaning. Next I will pull the OD unit and double check that everyhing is dry. Hey, at least I get to double check the orientation of the thrust bearings again.
Do I need to take the valvebody completely apart or just soak in mineral spirits? It came full of test fluid from the valve body shop and was wet with it when I put it in.
As always, I will follow any advice you have for me.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2822625
09/19/20 01:37 PM
09/19/20 01:37 PM
So much for dry tarp. 😅😅
At this point anybodies guess if the valve body got wet.
Re: 46rh Governor Questions [Re: A727Tflite] #2822688
09/19/20 05:30 PM
09/19/20 05:30 PM
Oh no, the valve body definitely got wet. At least the filter was pouring water and there were water droplets on the bottom of the VB once I removed the filter.
What's the easiest way to ensure that it's purged of water?
Can I dunk and flush with mineral spirits, or does this need a complete tear down of the valve body?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2822719
09/19/20 07:07 PM
09/19/20 07:07 PM
If it were me I would split the valve body.
It’s already clean so just a matter of making sure all the steel valves are free and no rust forming.
Spray with WD-40 then rinse with mineral spirits.
Don’t even dry it, let it drip dry and assembled. Don’t use any towels to dry anything. Lint will screw things up.
Re: 46rh Governor Questions [Re: A727Tflite] #2822735
09/19/20 07:58 PM
09/19/20 07:58 PM
Thank you! That is happening tomorrow. I will carefully split it open and do exactly what you recommended.
Do I need to be concerned about the solenoids?
I have been extremely careful about lint in this transmission. If I needed a rag for anything I used an old t shirt. I learned quickly that shop rags leave a ridiculous amount of lint.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2822756
09/19/20 08:46 PM
09/19/20 08:46 PM
I would hit everything with the WD-40 followed with mineral spirits. Get the trans running as soon as you can.
Re: 46rh Governor Questions [Re: A727Tflite] #2822758
09/19/20 08:55 PM
09/19/20 08:55 PM
It's going into Tribb's transmission this upcoming week. I will definitely hit everything with WD-40 and mineral spirits, per your recommendations, sir.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2823035
09/20/20 07:04 PM
09/20/20 07:04 PM
The OD unit was dry, so bolted it back up to the main case. Only place I saw any rust was on the sun gear shell, it was nixed immediately.
VB is split, was doused in WD40 and then in mineral spirits. It's now drying inside a cracked open garbage bag. All check balls were removed, after taking clear pictures of their location, and stored safely.
Thank you for your help.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2827071
09/30/20 07:24 PM
09/30/20 07:24 PM
The new shop installed the trans today. I could not be happier.
I cannot believe how much smoother and stronger this truck is, with a fresh rebuild. I followed your advice, all the way through, and it turned out perfectly.
The only thing that the trans does that makes me think I need to adjust something is when it shifts down to a stop, it feels like the kickdown band hangs for a split second, and it's lurched a couple of times when getting to a complete stop. Other times it just has it's normal little "bump" and then stop.
Other than that I cannot believe how smooth these shifts are. The fluid was nice and bright when I got home, and as I drove it (first low speed around town and then on the highway after about 10 miles) it felt like it settled in and the shifts were smooth and felt right on time.
Here's the old dirty trans in the back of the truck.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2827133
09/30/20 09:04 PM
09/30/20 09:04 PM
Normally you should not feel a downshift when coming to a stop. Usually when you do you have a sticky TP linkage setup. Kickdown band (2nd gear band) is only on in 2nd. When slowing down it should never engage unless you manually pull it in to 2nd or stay on the throttle while pulling a grade and force 2nd gear with throttle pressure.
Closed throttle coming to a stop if you really work at it you may feel a slight bump around 1-2 mph but that’s rare most of the time.
Make sure the throttle pressure linkage is free and adjusted properly and a return spring is usually found on the TP lever to trans case.
Try shutting OD off and see if this bump disappears, it shouldn’t make a difference. The direct clutch in the OD unit comes on when OD come see off but the ORC in the OD should prevent any bump.
One other thing that I have seen is on two piece driveshafts the slip yoke at the center bearing can hang up on the splines.
Coming to a stop and depending on rate of decel the yoke can hang up on the splines then snap free/forward giving you what feels like a shift.
Re: 46rh Governor Questions [Re: A727Tflite] #2827232
10/01/20 08:03 AM
10/01/20 08:03 AM
Thank you, sir.
I tried turning off the O/D switch and it didn't influence it at all. I believe that it is the driveshaft, or at least some component outside of the transmission, because a loud clang accompanies the lurch sometimes.
Another oddity, it was chilly here today, and O/D would not engage, even on the highway. It engaged perfectly yesterday. Do I have a faulty Solenoid, sir?
I checked the fluid this morning and it was still bright and clear.
Re: 46rh Governor Questions [Re: A727Tflite] #2827258
10/01/20 09:04 AM
10/01/20 09:04 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
There was a TSB on that many years ago. It also affected the single piece rear shafts. The slip spline at the rear shaft on the transfer case could bind and release. My experience the shorter the wheel base the worse the condition. It never hurt anything but was a common concern by many customers.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2827430
10/01/20 02:12 PM
10/01/20 02:12 PM
Originally Posted by 46rhRebuild
Thank you, sir.
I think OD is defeated by the PCM until engine temperature gets up to a certain threshold. Additionally in certain applications there is an external temp sensor for the trans and in others it’s internal - part of the OD/LU solenoid assembly which has a thermistor built in. If it sees a low temp you won’t get OD, too hot and OD is defeated as well.
Re: 46rh Governor Questions [Re: A727Tflite] #2827500
10/01/20 04:33 PM
10/01/20 04:33 PM
46rhRebuild Offline OP
NitrousN, thank you very much! I have the shortest wheelbase 1500 for that year. This makes alot of sense, and is what I believe is happening to my truck.
Transman, this makes perfect sense, because overdrive engaged this afternoon after school. It operated smoothly and strongly for two hours, with no glitches. So the low temp thermistor must be exactly what was preventing my OD from engaging. Thank you so much for your help through all of this.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2828180
10/03/20 07:18 AM
10/03/20 07:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
On the RH trans the trans temp sensors are often on the output/front line on the trans. Close to where it screws into the case. 2 wire connector
Re: 46rh Governor Questions [Re: J_BODY] #2828419
10/03/20 07:37 PM
10/03/20 07:37 PM
A727Tflite Online content
A727Tflite  Online Content
I believe diesel gets this external sensor.
I believe gas uses the internal sensor - part of the OD/LU solenoid assembly.
Re: 46rh Governor Questions [Re: A727Tflite] #2829184
10/06/20 07:23 AM
10/06/20 07:23 AM
I've got a weird issue, now. So, when I was coming to a light earlier today my transmission felt like it didn't downshift all the way, and went I went to roll forward the engine just revved, without catching.
I pulled off onto the shoulder, and the transmission downshifted, and then I was able to jump back out into traffic normally. About ten minutes later I was pulling out of a neighborhood, and the same issue happened. I let back on the throttle, and eased forward and first gear engaged normally.
I tested it going to school, and when I started forward with light throttle pressure the transmission would engage normally.
There have been no hard shifts, the fluid is bright and does not smell burned in any way. What am I facing here?
I do not rev the motor hard, so my throttle input for all of this was light to medium, no more than 1500 rpms.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2829212
10/06/20 08:52 AM
10/06/20 08:52 AM
If it does it again and you are at a slow enough speed try doing a manual pull down of the shifter without getting off the throttle.
If it instantly starts to engage my first guess is it is stuck in high gear. May feel like neutral but most stock converters stall around 1700-2000 so if it’s in 3rd you aren’t against the converter. The true test for a gov issue is to install a 0-80 lb. gauge and see what’s happening when you get this issue. Pressure should track close to vehicle speed, 5 psi tab 5 mph, etc.
Re: 46rh Governor Questions [Re: A727Tflite] #2829258
10/06/20 11:07 AM
10/06/20 11:07 AM
Is this an odd issue to have occur a few days after a new rebuild?
It had no issues shifting, up until this morning. If it turns out to be the governor, then what could I have messed up during the rebuild, sir?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2829296
10/06/20 12:37 PM
10/06/20 12:37 PM
If it shifted ok then developed this issue I don’t think you screwed anything up.
My first guess is debris.
There are valve body issues that can cause strange behaviors so that is why I always start by checking governor pressure as part of the process of elimination.
If the truck upshifts and downshifts manually then your clutches and bands are fine, likely It’s your control system that is causing issues. Governor and valve body.
Re: 46rh Governor Questions [Re: A727Tflite] #2829302
10/06/20 12:44 PM
10/06/20 12:44 PM
Is there any chance of it working itself out, if it's debris? Or would I have to have the trans pulled again and manually clean the governor? I know that I can drop the valve body and clean it with it in place.
Not this weekend, unfortunately I am close to the impact path of Hurricane Delta.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2829309
10/06/20 01:08 PM
10/06/20 01:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most of the time a sticky governor can fix itself. Lots of quick stop and go and shifting to reverse can help loosen a sticky governor. Seems like the more you work it by jarring the output shaft the better it can get. I would say in my experience 90 percent fix them selves.
Re: 46rh Governor Questions [Re: NITROUSN] #2829313
10/06/20 01:17 PM
10/06/20 01:17 PM
Thank you, Nitrous!
I will take this to heart and do as much quick stop and go as I can.
The transmission started shifting really well, with the shift points almost exactly where my transmission used to be. Until the lack of engagement this morning I was thinking that it was breaking in really well. The transmission did this under identical conditions both times, this morning. Coming to a stop, transmission doesn't feel like it shifted fully into first, then trying to start rolling forward, engine revs up but truck doesn't want to catch. Give it more throttle, then engages.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2829323
10/06/20 01:36 PM
10/06/20 01:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
When that happens try manual 1st gear and see what it does. As soon as you feel the slippage when trying to go shift it to first. If it then takes off like it normally should the governor had hung up.
Re: 46rh Governor Questions [Re: NITROUSN] #2829327
10/06/20 01:52 PM
10/06/20 01:52 PM
Thank you again, sir. The first part of my drive is all rural highway. It wasn't until I got into the town where my trade school is at that I encountered this. So about 45 mins of highway driving and then the first light, it did this.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2830009
10/07/20 03:43 PM
10/07/20 03:43 PM
Update.
Truck started lurching when I pulled into my neighborhood coming home from school today.
Manged to limp rest of way home with truck jumping between what felt like 1st and 2nd gear.
Truck now dies after engine revs up and down 1000 rpms when shifting into Drive, 1, or Reverse.
Please help.
Fluid is still bright and clean. No burned smell.
Is this a bad torque converter? Could I have a band issue?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2830162
10/07/20 09:04 PM
10/07/20 09:04 PM
Now the engine won't start. The starter cranks the motor over strongly, and I can hear the fuel pump engaging strongly, too.
I had just filled up the tank, and it wasn't a mile and a half down the road that all of this happened. Is there an engine condition that can cause this, and this is just coincidental with the trans issues?
I appreciate everyone's help. I'm out of my depth here, and this truck has been great to me. The truck not starting has only ever happened when my battery was going out, or an ignition switch was bad. This is definitely not normal for this truck.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2830168
10/07/20 09:31 PM
10/07/20 09:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Can you check for codes? Its either something electronic that's failed or else you got a bad tank of fuel. If possible try to pump a sample through from the tanks pump into a clear container.
Re: 46rh Governor Questions [Re: NITROUSN] #2830481
10/08/20 04:24 PM
10/08/20 04:24 PM
Thank you, Nitrous. Unfortunately I didn't have the time or the ability to pull a fuel sample. This makes perfect sense that it would be electrical, and is only coincidental that it is happening around the time of my trans rebuild. The truck is a 1994 1500 with the 5.9 and is OBD 1. I do not have a code reader, so was unable to check codes. I did check the connection to the ECM, and checked my fuses. I even swapped my fuel pump relay with a known good relay.
This morning it cranked normally, gave me no issues on the way to school, and drove really well. When passing by an overpass I thought I heard a loud whining, but figured this could just be the gearsets that I changed in the OD unit. Transman warned me there could be more noise. To be fair I was in OD pushing 2000 rpms, so my rate of speed was up.
When trying to leave the school this afternoon the truck was doing the exact same thing as yesterday. Lurching, not wanting to go over 5mph, running really rough, sounding like it almost wanted to backfire. I limped to a parking lot, and had the truck towed to the mechanic who did the trans swap. I suspect a fuel pump going bad, and only acting up in the heat, now. It was pretty hot yesterday afternoon and today. This morning was nice and cool so may have been able to operate normally.
I did put the truck in park and revved the engine. It revved up to 2500 rpms normally, with no stuttering. I don't know if this is a sign of anything, or the truck simply being able to make rpms because in a zero load situation.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2830571
10/08/20 08:25 PM
10/08/20 08:25 PM
N
NITROUSN Offline
NITROUSN  Offline
N
For now you need to get it running correctly. Once running you can work out the bugs. A poor running or erratic running engine can cause a person to think there are other problems. Was the check engine light on? Knowing codes would be helpful. One other item that comes to mind is the crank sensor. I have seen these damaged with transmission removals.
Re: 46rh Governor Questions [Re: NITROUSN] #2830577
10/08/20 08:43 PM
10/08/20 08:43 PM
The check engine light was not on, which I thought was odd.
I wish I had had time to get an OBD 1 reader hooked up. The local auto parts stores don't have one (I've asked before), and I hadn't had issues that I couldn't diagnose myself with this truck, in years.
I got up to go to school, after having given up the night before, swapped the relay and depressed the schrader valve on the fuel rail after letting the fuel pump engage. I got a good squirt of fuel, and turned the truck over for grins. Fired right up perfectly. A good lhard test drive showed no signs of further issues. I chocked it up to a bad fuel pump relay and drove to school. Trans and engine worked perfectly.
Got out of school about 8 hours later, truck baking in the Florida sun. Ran like absolute garbage. I barely got 300 yards down the road. Check engine light still wasn't on.
I am not experienced enough with transmissions to know if this is an internal issue in the transmission. My common sense says no, because other than the sticky governor, it's worked perfectly. I suspect that they could have damaged that sensor during the install, or that the fuel pump is just going out.
I appreciate your help, Nitrous. I will post everything that they tell me.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2830585
10/08/20 09:14 PM
10/08/20 09:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just because the fuel seems to squirt strong a gauge needs to be used to get actual pressure. I can tell you how many times customers said the pressure was good on the squirt test so the pump is ok. Not.
Re: 46rh Governor Questions [Re: NITROUSN] #2830589
10/08/20 09:21 PM
10/08/20 09:21 PM
That's actually a huge relief. I am absolutely not an expert, and I really want this to be a single simple issue like a bad fuel pump. I've gotten over 80,000 miles out of this pump, and it does surge alittle bit first thing in the morning, so it's probably been getting weaker for a while. And who knows how long it was driven before I bought it on this fuel pump. I'm the third or fourth owner.
Again, thank you Nitrous, all of this is being extremely educational.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2834681
10/19/20 02:40 PM
10/19/20 02:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Did you get it back up and running?
Re: 46rh Governor Questions [Re: NITROUSN] #2835173
10/20/20 04:20 PM
10/20/20 04:20 PM
I got the truck back from the shop yesterday.
They kept it and tried to get it to replicate the issues that I was having. They were unable to, thankfully said that they were uncomfortable replacing the fuel pump, and just put some fuel dryer in the tank. For the diagnostics and the fuel dryer I was out the door for $89.
I got the truck most of the way home and then it started doing the exact same thing. I guess it would only act up when the truck was hot, running at highway speeds in overdrive. I limped the truck back to the shop. They diagnosed a bad distributor component. They replaced the whole distributor and the truck only missed twice minorly on the way home yesterday. Bill was $260. Super honest people, and their prices are VERY good.
Driving back home today from school I was doing 1800 to 2000 rpms in overdrive and it started missing. Every ten or fifteen seconds it will miss and lurch alittle. Not nearly as badly as before, but very noticeably.
What in the world am I facing here? This is all new, post transmission rebuild.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2835180
10/20/20 04:31 PM
10/20/20 04:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
still could be water in the fuel.
Re: 46rh Governor Questions [Re: stumpy] #2835189
10/20/20 04:43 PM
10/20/20 04:43 PM
Could water in fuel have caused my old distributor to fail? I ask because I genuinely believe that I did get water in my fuel, and replacing the distributor has helped immensely. I'm stumped.
The distributor replacement did help immensely, so I believe that it really did go bad.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2835745
10/21/20 04:50 PM
10/21/20 04:50 PM
Drove the truck to and from school today. It misses when accelerating, and at highway speeds, pretty much all the time. It's not anywhere near as bad as it was before the distributor was replaced. Before then it would shudder and lurch and try to die. Now it's a light miss that is like the truck is missing a beat, rather than a hard shudder.
I'm going to ohm out all of the injectors over the weekend. Does anyone have any recommendations for things to check? If this is a timing issue, outside of the injectors and the distributor, where else should I look?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2835820
10/21/20 07:04 PM
10/21/20 07:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Plugs or wires would be my guess.
Re: 46rh Governor Questions [Re: NITROUSN] #2835854
10/21/20 07:47 PM
10/21/20 07:47 PM
The plugs and wires have less than 10k miles on them, but I will swap them if you think it's possible something has gone bad in there, Nitrous.
I'm using NGKs, but have heard good thing about Champions, for the 5.9L Magnum.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2835869
10/21/20 08:19 PM
10/21/20 08:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I like NGK and with either them or Champion I have had no issues. You could OHM each plug wire. Most likely it is just one hole not firing 100%. Lots of cheap wires on the market. Seeing the distributor was replaced there are a couple things you should check. One make sure all the wires are seated correctly. And secondly ask the shop how they set the distributor. The distributor needs to have the sync signal set. If it is not set correctly it can cause some erratic running.
Re: 46rh Governor Questions [Re: NITROUSN] #2835870
10/21/20 08:22 PM
10/21/20 08:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
One other item is there was a TSB on erratic running due to plug wire routing. Take some time to find that TSB and follow what it says on routing.
Re: 46rh Governor Questions [Re: NITROUSN] #2835874
10/21/20 08:26 PM
10/21/20 08:26 PM
N
NITROUSN Offline
NITROUSN  Offline
N
TSB 18-48-98
Re: 46rh Governor Questions [Re: NITROUSN] #2835881
10/21/20 08:34 PM
10/21/20 08:34 PM
Thank you, I will follow that TSB down now, Nitrous. I will call the shop and ask them if they set the sync signal, tomorrow after class. They're really helpful so should be a non issue if it needs to be adjusted.
Found it. Here's the link for anyone else who might need it. I also have it saved as a pdf, in case link is down I can email it.
https://testing-public.carmd.com/Tsb/Download/31575/080022dc80bbf784
Nitrous, do you recommend running some injector cleaner through, just in case? If so, any recommended products? The gas that I normally use is Chevron, so should have a mild cleaner in it. This is also the gas station that I may have gotten some contaminated fuel at, though.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2835884
10/21/20 09:01 PM
10/21/20 09:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
When they changed your fuel pump they should of made sure the tank was clean. For the most part injectors are relatively trouble free. However if a fuel system is compromised with contaminants the injectors could be restricted. As I recall that system does not have a return so all particles can get trapped on the injectors inlet screen. Normally this is not a service repair to clean them. Most just replace them. However here is a trick I have used. Remove the injectors. Rig up a power and ground to power the injector from a 12 volt source. With the injector powered it will open the pintle off the seat. Take a nice clean white rag and you can reverse flush the injector with carb cleaner and compressed air. I like to clean and blow the contaminants into the rag just to see what comes out. Reverse flush will push the debris back out of the injector. I would do the other items I mentioned first. Check plugs, wires, wire routing, distributor sync signal .
Re: 46rh Governor Questions [Re: NITROUSN] #2836328
10/22/20 10:16 PM
10/22/20 10:16 PM
The shop said that the fuel pressure tested ok, so they didn't change the fuel pump. They put a drying chemical in the tank and did a diagnostic.
Today I traced out the plug wires, following the TSB and did the best I could with it. I realized that one of the wires was laying on my passenger side header, cylinder number six. I replaced this wire because I just went ahead and assumed that it was damaged by the heat, as the plastic wire loom was burned. I also replaced the single ignition coil for the system, located near the idler pulley.
The truck ran better and only missed a few times on the way home. I also added half a container of marvel mystery oil to the tank when I changed the ignition coil. I noticed a power gain, whether it was from the coil or the mystery oil I am unsure.
When it missed today it felt the same as the other days, it was only the frequency with which it happened that was different.
I called the shop and they acted baffled when I asked about the distributor sync signal. They just said that they installed the distributor at TDC and hooked the wires up. I don't know what the sync signal refers to, honestly.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2836413
10/23/20 09:27 AM
10/23/20 09:27 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You need to have the sync signal set. All they did is install the distributor. It is not like the old days of using a timing light. Some scan tools have functions that will allow setting the signal. There are more complicated ways with setting the crank balancer at a certain position and using an OHM meter on the distributor pick up to adjust it. Very important setting.
Re: 46rh Governor Questions [Re: NITROUSN] #2836415
10/23/20 09:29 AM
10/23/20 09:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: 46rh Governor Questions [Re: NITROUSN] #2836448
10/23/20 10:54 AM
10/23/20 10:54 AM
This shop has no idea what that adjustment is, so I may have to source another technician. I do not believe that this is something that I can do myself.
A call to the Dodge dealership let me know that they don't work on anything older than 2005. So I sent an email to the automotive department at my school to see if they'd be able to do this adjustment. I included the pdf from the link that you sent me, Nitrous. Thank you so much for your help.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2836484
10/23/20 12:05 PM
10/23/20 12:05 PM
I found a local old school mechanic who knew exactly what this was. The truck gets dropped off on Monday with him. Hopefully this clears it up. He said "Yeah, if the distributor hasn't been synced your fuel will be off and you'll get misses under load." I emailed him that sync signal bulletin, so he's on the same page.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2836490
10/23/20 12:11 PM
10/23/20 12:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You can not over look the basics. It is a shame that your first shop who replaced your distributor is not so smart. Like I said plugs, wires, and sync signal need to be verified as good before wasting another dime.
Re: 46rh Governor Questions [Re: NITROUSN] #2836609
10/23/20 03:52 PM
10/23/20 03:52 PM
I appreciate this advice. It is spot on. I checked the connections to every part of the system that I could think of. Everything is solid. New distributor and coil, one new wire. If setting the sync signal doesn't clear it up, then I will pull the injectors and reverse flush them into a white rag, using a 12 volt DC power source, per your recommendation.
None of these issues appeared until shortly after this trans rebuild. I do not think that the trans itself has caused any of this, but perhaps something happened during the install that contributed. I am not a big believer in coincidence, but perhaps that's what I'm facing here.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2836634
10/23/20 04:22 PM
10/23/20 04:22 PM
If a particular trans does not have a functioning lockup converter, you will be amazed how much driveability issues will pop up once lockup is introduced.
The only thing I have seen after a trans has been removed and reinstalled from a properly functioning vehicle that causes shudder is a damaged or dislocated/cocked distributor cap. Some of the earlier trucks had the cap real close to the firewall. Lowering the engine knocked the cap lose.
Re: 46rh Governor Questions [Re: A727Tflite] #2836700
10/23/20 07:24 PM
10/23/20 07:24 PM
By lockup converter do you mean the locking torque converter, Transman? This one is a Precision of New Hampton, I hope it's not malfunctioning. I spent the extra money for it because of their reputation.
I know that my distributor is really close to the firewall. I've always dreaded having to do that repair because of how tight it is back there. This is a 1994 and that firewall is really close to the back of the engine. It's possible that it got bumped when they were installing the new trans. Brand new distributor though, and it's running better, just not 100 percent. The sync adjustment is getting done on monday. The distributor getting harmed during install makes alot of sense, actually.
This issue started when I was rolling from a stop and going into first, a week or so after the trans was swapped. This is all new to the truck, I've never had timing or firing issues before. I don't know if all of this points the finger to anything specific. The trans fluid is totally bright red and clean. I'd been stressing that maybe I'd accidentally gotten the thrust washers in the OD unit in upside down and it was messing up. If I'd gotten them flipped would they have burned up already? I've done a few hours of OD driving already on this build, in the Florida heat.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2837659
10/26/20 04:24 PM
10/26/20 04:24 PM
Update: Two mechanics are now unable to perform the sync signal adjustment, an appointment has been made with a third. The second mechanic referred me to the third, saying that he would have the correct OBD1 attachments to perform the adjustment.
The second mechanic confirmed that my fuel adjustment was "out of range", and that my timing was on 10. Does this mean anything to you, Nitrous?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2837676
10/26/20 05:05 PM
10/26/20 05:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
Not sure what they were doing. If he was able to see it out of range I would think he could of turned the distributor to get it in range. There is a way to do it with an OHM meter.
Re: 46rh Governor Questions [Re: NITROUSN] #2837679
10/26/20 05:09 PM
10/26/20 05:09 PM
I have no idea. At this point I'm just praying that someone tunes my truck, so I can focus on my hvac school. Thank you for all of your help, you've been a lifesaver, Nitrous. I'll keep you posted with how it goes at the third mechanic.
Re: 46rh Governor Questions [Re: NITROUSN] #2837682
10/26/20 05:15 PM
10/26/20 05:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
CHECKING ilSTRIBUTOR POSITION
To verify correct distributor rotational position,
connect the DRB scan tool to the data link connector.
The data link connector is located in the engine com-
partment. Gain access to the SET SYNC screen on
the DRB.
WARNING : WHE N PERFORMIN G TH E FOLLOWIN G
TEST , TH E ENGIN E WIL L B E RUNNING . B E CARE ­
F U L NO T T O STAN D I N LIN E WIT H TH E FA N
BLADE S O R FA N BELT . D O NO T WEA R LOOS E
CLOTHING .
Follow the directions on the DRB screen and start
the engine. With the engine running, the words IN
RANGE should appear on the screen along with 0°.
This indicates correct distributor position.
If a plus (+) or a minus (-) is displayed next to the
degree number, and/or the degree displayed is not
zero, loosen but do not remove the distributor hold-
down clamp bolt. Rotate the distributor until IN
RANGE appears on the screen. Continue to rotate
80 - 28 IGNITION SYSTEMS Hit
the distributor until achieving as close to 0° as pos-
sible. After adjustment, tighten clamp bolt to 22.5
N-m (200 in. lbs.) torque.
The degree scale on the SET SYNC screen of the
DRB is referring to fuel synchronization only. It is
not referring to ignition timing. Because of this,
do not attempt to adjust ignition timing using this
method. Rotating the distributor will have no effect
on ignition timing. All ignition timing values are con-
trolled by the powertrain control module (PCM).
Re: 46rh Governor Questions [Re: NITROUSN] #2837690
10/26/20 05:33 PM
10/26/20 05:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Or read this . Forget page 1 and 2. Page 3 tells you how to set it. I previously said OHM meter but it is a voltmeter.
Attached PDF document
dakotatsb.pdf (108 downloads)
Re: 46rh Governor Questions [Re: NITROUSN] #2837879
10/27/20 07:18 AM
10/27/20 07:18 AM
Properly functioning lockup torque converter means one that not only locks but does not shudder.
Precision does good work, I know the owner, stand up guy.
Re: 46rh Governor Questions [Re: A727Tflite] #2838055
10/27/20 04:12 PM
10/27/20 04:12 PM
Nitrous, I specified to the shop that I wanted the Sync signal set, so I hope they do this tomorrow. I will save that bulletin. Thank you so much for sharing all of this information with me. I made sure to ultra specify that I need the sync signal done, so fingers crossed. If they don't get it right, then I'm attempting this.
Transman, thank you! It doesn't shudder at all, only the engine misses and lurches, and it's not even all the time. You aren't the first person who's said good things about Precision, so I took all of that into consideration and spent the extra money for their product. Thank you for your help with my build, the build seems to be smooth as silk, now.
Oh, there is a new rattle at idle. Could this be from the shield between the trans and the engine?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2838090
10/27/20 05:54 PM
10/27/20 05:54 PM
Rattles are a pain. I guess I would look at anything you disturbed doing the trans R & R first. Shield would be a good start.
Also, you asked earlier about putting in thrust bearings in the OD upside down. They generally last less than a couple hundred miles when that’s been done.
Re: 46rh Governor Questions [Re: A727Tflite] #2838465
10/28/20 05:57 PM
10/28/20 05:57 PM
Thank you, Transman. I've definitely logged a few hundred miles since the rebuild, so I'll relax there. I suspect it's the shield rattling.
Nitrous, so the new shop called me today and said my truck wouldn't start. They claimed it was happening before they started adjusting my distributor. That's funny, because other than the miss at highway speeds it was running pretty alright. It's never done this to me, and I told them I was uncomfortable with this claim. Service manager got nasty, and I was about to have the truck towed off property. The mechanic who worked on it came out and tried to be concilliatory. Said he thinks it's a "hot soak issue". Should I let these guys take a crack at diagnosing this, or what? I'm lost, and am debating having my insurance company tow my truck off their property tonight, and back to my house.
And when I say wouldn't start, I mean the mechanic confirmed zero spark was happening.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2838489
10/28/20 07:08 PM
10/28/20 07:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
At this time you need to trust someone. This no spark could be part of what has been wrong all along. Possibly the distributor replacement was not needed. At this point it needs to be diagnosed. I would at least allow them to run codes and to give you an estimate. It is always a possibility that the crank sensor was damaged when the transmission was removed and could of been the noise you heard in the bell area, These are guesses on my part. However get some sort of diagnosis.
Re: 46rh Governor Questions [Re: NITROUSN] #2838876
10/29/20 03:51 PM
10/29/20 03:51 PM
The mechanic who was being helpful had a conversation with me, late yesterday afternoon. He told me to replace my speed sensor, as it might be shorting out causing the 8v signal from the computer to interfere. He also said that when I came back and picked up my truck it should start up fine, after it cooled down. I picked up my truck, it had a longer than normal crank before start but it cranked. The miss was gone, my fuel mileage is back up, and my power seems to be back. Today the truck cranked up on the first key touch, like normal, every single time.
I'm going to go looking for an inexpensive OBD1 reader so I can pull codes myself, and I'm going to look into having the crank sensor replaced. As of right now the truck is running normally, shifting perfectly, and I know he was able to set the Sync signal so that issue seems to be cleared up. Thank you for your patience with all of this, and your help, Nitrous.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2838894
10/29/20 04:30 PM
10/29/20 04:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Did they set the sync signal?
Re: 46rh Governor Questions [Re: NITROUSN] #2838901
10/29/20 04:40 PM
10/29/20 04:40 PM
They did.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2838908
10/29/20 04:51 PM
10/29/20 04:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Run it for a while to see what it does. The code reader is a valuable tool to have. The hot soak with the no start makes no sense. All sensors use the same low volt reference signal and yes any of them could short and cause a stall or no start. Generally there are failure codes when this happens. I would not waste my money throwing sensors at it until you get a code reader.
Re: 46rh Governor Questions [Re: NITROUSN] #2838909
10/29/20 04:54 PM
10/29/20 04:54 PM
Thank you, Nitrous. I am going to track down a scanner today. Your advice continues to be invaluable.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2839031
10/29/20 08:46 PM
10/29/20 08:46 PM
OBD1 scanners are not inexpensive for Dodges, I'm finding. Nor are the OBD2 scanners that also read OBD1, however I found an article that I'm posting below that may work. Is this method recommended or should I keep hunting for an old scanner and correct attachment?
I found this article which seems to pertain to pulling codes for my 1994 1500 Ram. Codes will be recorded tomorrow, and I will post any that show up here, for analysis by wiser minds than mine. Though the article is wrong about the port, there is an OBD1 port.
However, for vehicles made on or before 1995, there is only one cheap way to get it: You do it yourself!
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the engine light. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports.
Dodge trucks have a diagnostic trouble code retrieval method, Unlike Gm and Ford trucks the Dodge line of trucks has no data port connector to gather codes from.
Instead Dodge has a ignition cycle activation sequence that anyone can active by turning the ignition key on off in rapid succession five times with the cycle ending in the "on" position.
Once this activation has started the check engine light will start to flash. The first set of check engine light flashes will be the first digit of the two number code. After the check engine light pauses for a short time it will start to blink again starting the second digit identification and completing the code's second number. If additional trouble codes are stored in the computer the first digit will begin to flash, and then the second digit. For example: the check engine light flashes four times, pauses and then flashes three more times the code is 43.
The check engine light will flash one and then two meaning the code gathering is over. The system will only flash 12 if there are no codes stored in the computer’s memory. To clear codes disconnect the negative battery terminal for 30 seconds and reconnect.
Below are the OBD DTC's for 1995-previous model year EFI-equipped Dodge vehicles.
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle position sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 waste-gate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects over-boost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
Import Car Code Definition
1 oxygen sensor
2 crank engine sensor
3 air flow sensor
4 barometric pressure sensor
5 throttle positioner sensor
6 motor position sensor
7 engine coolant temperature sensor
8 no.1 cylinder tdc sensor
12 air flow sensor
13 air temperature sensor
14 throttle positioner sensor
15 sc motor position sensor
21 engine coolant temperature sensor
22 crank angle sensor
23 no.1 cylinder tdc sensor
24 vehicle speed sensor
25 barometric pressure sensor
31 knock sensor
32 manifold pressure sensor
36 ignition timing adjustment signal
39 oxygen sensor
41 injector
42 fuel pump
43 egr
44 ignition coil
52 ignition coil
53 ignition coil
55 iac valve position sensor
59 heated oxygen sensor
61 transaxle control unit cable
62 warm up control valve position sensor
Re: 46rh Governor Questions [Re: 46rhRebuild] #2839249
10/30/20 11:19 AM
10/30/20 11:19 AM
moparx Offline
moparx  Offline
the "key dance" worked for my 95 mini van [and earlier ones], so it should work for your pickup.
i have been told many times the "key dance" works for the 96-2000 OBD2 mini vans, but i have never been able to get it to work.
the codes you have listed look like the ones i have used before.
try it and let us know.
beer
Re: 46rh Governor Questions [Re: moparx] #2839654
10/31/20 09:17 AM
10/31/20 09:17 AM
Will do, Moparx. So far the truck is running perfectly again, and other than the new annoying rattle at idle, I have no complaints in the performance or fuel mileage now.
I think Nitrous nailed it with his advice. Sync signal. Codes will be pulled Sunday or Monday. Halloween is a huge thing in my house, so spent all Thursday, Yesterday and today decorating, so no time to do anything other than driving. Power is better than pre trans rebuild, no shuddering, no failure to crank.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2845010
11/11/20 05:35 PM
11/11/20 05:35 PM
No codes thrown. Truck just kept running with a slight miss at highways speeds, until it didn't. Last hot afternoon the misfiring came back with a vengeance. Left me on the side of the road. When it cooled down, limped it to a mechanic. Diagnosed crankshaft position sensor. I'm having a Delphi one put in on Monday. Did alittle reading up on that sensor and it can cause the issues that I've been seeing, just like Nitrous said. Also could have been damaged during the Trans install, also like Nitrous said. Will report back after Monday.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2856802
12/07/20 08:36 PM
12/07/20 08:36 PM
I apologize for the long delay. I did not have anything to report until today.
The distributor, coil, crankshaft position sensor, spark plugs and wires have all been replaced. Everything is Delphi, Napa, or NGK, so good quality replacement components. The truck still has the intermittent miss at highway speeds, and sometimes when rolling forward from a stop. Overdrive engagement is intermittent, but the fluid remains bright and clean. No burning smell whatsoever.
Today the truck threw the first Code. Code 37. It appears that we have a torque converter issue.
Transman, do I need to have the transmission pulled and the torque converter replaced? This is a Precision of New Hampton converter, so am hoping that there is a warranty of some kind that will help with this.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2856824
12/07/20 09:18 PM
12/07/20 09:18 PM
I’ll have to see the trigger requirements to set code 37.
Launching the truck from a stop shouldn’t involve the lockup circuit so I’m puzzled what the launch miss could have to do with the converter.
Overdrive intermittently applying - there are several things that have to happen for OD. No Park or Neutral signal from the PRNDL switch, no brake pedal switch signal, no overtemp trans fluid signal, ambient temp and water temp sensor signal has to be above 65 degrees if I recall, may be others.
If you do a stall test, is there ever any missing?
You might want to ask around and see if any dealers will do a data recording when it act s up, we used to have a device called a Co-Pilot that recorded about 45 seconds after an event. Was very useful in this type of thing.
Works sort of like a RacePak does today.
Re: 46rh Governor Questions [Re: A727Tflite] #2856835
12/07/20 09:39 PM
12/07/20 09:39 PM
The miss from launch will appear within the first two seconds, and happens most often when the temp is under 40 degrees. I don't know if that information helps at all, sir.
As for the stall test, my local mechanic put the truck into gear, applied the brakes and did his best to make the truck stall. Nothing. No missing, nothing but clean firing. I'm not certain if this qualifies, but this is the only test of this type that has been performed on this truck. He was testing to see if my fuel pump was possibly causing this, or a fouled injector. He's 73 and has been at this his whole life, so I don't question his methods. He's the one who was finally able to get the truck to throw a code. He went out driving it for an hour to get it to duplicate the miss that I've been seeing.
Unfortunately this mechanic is the only one in my town that I haven't had bad experiences with on this build. I can try calling in the towns near here to see if someone can do a recording, but I'm not confident about finding anyone around here, and will have to treat this option as a last ditch one.
It's really odd with my OD engagement. I can be driving along on a 75 degree day, and the OD won't engage. I can drive for 45 mins and have it engage once, and then the minute I slow down it drops out of OD, and won't reengage again. I kept chalking it up to the break in period, and maybe the thermistor not reading a high enough temp. But I'm starting to believe that my TC is not locking up. Could this be a faulty Solenoid? The valve body was professionally rebuilt by Central Valve Bodies. I took the valve body apart and cleaned it and let it dry really well, after the water intrusion, making sure to put all of the check balls back in their correct locations.
Also, fuel mileage has dropped significantly. I'm burning half again as much fuel, recently. I have been told that this can be caused by either my torque converter, or by something in my fuel system. My mechanic insisted that I replace my pcv valve and my plugs and wires myself before he would go any further. He has been consistently trying to save me money through this nightmare.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2856931
12/08/20 07:41 AM
12/08/20 07:41 AM
Yes, no OD and you will burn more fuel.
As for no overdrive, what you might consider is to control that yourself.
You would have to make a small jumper harness that would attach to the three pin connector at the trans. Power to the center pin with key on, then the front pin is overdrive and the rear is lockup ground wires you would control from the cab.
Once in third gear you can ground either or both to control OD and/or lockup. If you consistently get them then your problem lies outside the trans.
I would try that first, sounds like you would have no problem making this harness.
A stuck brake switch will also prevent lockup.
Another quick test before you make that harness, take it for a ride and see if cruise control works all the time. If not, very good chance brake switch or PRNDL.
One more item TPS. While they act up more on the diesel trucks they do act up on gas. You would have to monitor with an analog voltmeter, not digital. The needle should never jump around, it should move very smoothly. Idle around .65 and at WOT should be be around 3.5-4.0 if I recall correctly.
Re: 46rh Governor Questions [Re: A727Tflite] #2856932
12/08/20 07:49 AM
12/08/20 07:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
While the co-pilot was a neat lil tool, finding a dealer that could actually set one up for a vehicle that old falls into the “slim and none” dept....
Re: 46rh Governor Questions [Re: J_BODY] #2856975
12/08/20 09:48 AM
12/08/20 09:48 AM
Thank you, Transman. I'm in class right now and will be asking my professor to help me design a wire harness that will do all of these functions. I have also forwarded all of this information on to my mechanic. I will report back my findings, as soon as I have actionable data. Thank you again for your help, sir.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857015
12/08/20 11:18 AM
12/08/20 11:18 AM
Would this three toggle switch diagram be correct?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857068
12/08/20 12:46 PM
12/08/20 12:46 PM
See attached
Re: 46rh Governor Questions [Re: A727Tflite] #2857083
12/08/20 01:25 PM
12/08/20 01:25 PM
Thank you, sir. You just saved me from shorting out my solenoids. I'm really glad that I asked you for clarification.
I had totally missed that they were being supplied power, and just needed ground. Instead I was trying to power everything, and that would have been bad, I'm thinking.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857091
12/08/20 01:36 PM
12/08/20 01:36 PM
Here is a pic of the solenoid layout.
My memory is fading, better check the center pin of your existing harness to see if it is 5 or 12 volts. My recollection is 5.
Re: 46rh Governor Questions [Re: A727Tflite] #2857212
12/08/20 04:45 PM
12/08/20 04:45 PM
I will definitely check the voltage over the weekend. I can't make a harness that fits those pin connectors, so I'm going to source an old plug for this connector and make one from that.
Sir, if that pin is 5 volts, how do I supply that? I can get 12 volts from the battery, but have no idea how to source 5 volts from the truck.
Driving the truck back from the mechanic, it's missing alot more. Constantly now. I've turned the OD off manually using the button on the dash, and also kept OD on. It seems to miss alittle less when the OD is off, but it still pretty consistently runs poorly. I can smell a strong rich running smell.
Idle is good, alittle higher than before, but that's the only difference. Absolutely no poor running in park or stopped at a light. I don't know if this points to anything. There is still a rattling, almost whining noise when stopped or in park, though. This is new to the truck post trans rebuild.
Also, my speed sensor has not worked in two years, if this is possibly contributing. And there is a two pin connector that is not connected, that looks like it should go to the transmission. My mechanic thinks it's for a transmission temperature sensor. I am telling you all of this, in case this helps with the diagnosis.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857241
12/08/20 05:23 PM
12/08/20 05:23 PM
From what I'm reading only the 46re has 5 volts supplied, to pressure/temp sensor. 46rh are solid 12 volt, from what I'm reading. If this is true it will simplify things.
I've also found new 46rh 3 pin pigtails for sale, so will be buying one of those. I don't want to cut into the existing harness because I don't have alot of extra length to play with in that harness.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857250
12/08/20 05:54 PM
12/08/20 05:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Fix the miss before you do anything transmission wise. A cylinder misfire will always seem more severe when in lock up or overdrive.
Re: 46rh Governor Questions [Re: NITROUSN] #2857267
12/08/20 06:18 PM
12/08/20 06:18 PM
iagree
Except the fact that you state no overdrive - a miss won’t cause that.
As for no speedo, I think that’s the RWAL sensor on the axle. The sensor on the transmission is for input to the SBEC which talks to the engine and trans.
Re: 46rh Governor Questions [Re: A727Tflite] #2857295
12/08/20 07:14 PM
12/08/20 07:14 PM
I am working hard to fix the miss, and am open to any suggestions. I am very serious.
These are the components that I've had replaced chasing down this miss, so far: Distributor, coil, spark plugs, wires, crankshaft position sensor. Please advise me on what you would tackle next, if this was your truck. The only code thrown has been code 37 so far.
This truck did not have a miss before the trans swap, and I am completely willing to call it a coincidence. Please advise me, I am willing to take advice and turn it into action.
Transman and Nitrous, thank you both so much for your help, I actively take your advice and apply. I fear that I am going to have to continue to ask for it until I am back up and running well.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857351
12/08/20 08:43 PM
12/08/20 08:43 PM
N
NITROUSN Offline
NITROUSN  Offline
N
One time we had an erratic misfire due to something either on the flywheel or converter. It was causing a signal or should we say a mis-signal on the crank sensor. The noise in the bell area could be a clue. The flexplate/flywheel has 8 holes that the crank sensor reads. Just possible that there is a problem there. You could remove the starter and lower shields and rotate the engine 360 degrees and look for something foreign or loose. As I recall we had a extra piece of wire off the converter weld causing a issue on one of the read holes. It is a shot in the dark but something that will only cost you some time and no money. Only other easy items would be to remove the cap and inspect it and the rotor. Remove the plugs and check the gap and look close at the porcelain insulators outside and inside for irregularities. Run it at night in the dark and look for any signs of secondary ignition spark jumping. I suspect you can have multiple issues but the miss concerns me as it just should not be there. I would have a hard time trying to diagnose a transmission problem with running irregularities. As also mentioned the brake light switch. Make sure it is adjusted and working correctly. A bad or mis-adjusted switch could cause lock up issues however I do not think it can be rapid enough to mis-interpet it as a miss.
Re: 46rh Governor Questions [Re: NITROUSN] #2857365
12/08/20 09:02 PM
12/08/20 09:02 PM
Nitrous, I will pull the lower trans shield and visually inspect and rotate the engine. I will also run it at night to look for any kind of secondary ignition.
The distributor cap and rotor has been pulled twice now, to make adjustments and for inspection. I replaced the spark plugs a couple of days ago, visually checked each one, put permatex never seize on the threads and carefully snugged them in. I installed new good quality wires at the same time, carefully, making sure that they are away from the headers.
I will check the brake light switch, as well.
The miss is aggravating. It's been there ever since the transmission was swapped. It got better after the distributor, and then crankshaft position sensor was repaired. Then was back two days later. At idle, the truck runs beautifully. Then when accelerating it feels like it loses power, it makes this phut phut noise, and then once I'm done accelerating or not running around 2000 rpms, it's smooth as silk again. The minute I start accelerating or am up around the 2k mark (what I call highway speed, because in 3rd gear I'm around 2200) I get that loss of power miss. It's not a jerk or shudder, it feels like all of a sudden I'm not getting fuel to a cylinder because there is a sensible loss of power.
To further cloud the issue, my stepfather put Marvel Mystery Oil in the tank right after the transmission swap because that shop recommended it. He also added it a few days ago, thinking it was helping. I swear the miss has gotten worse since it was put in my tank. No one around my area thinks it's a contributing factor, but I'm not so certain.
Should I replace the IAC or start hunting down a set of injectors? I've personally put 100k on these injectors, and have never done anything with the egr, iac, map sensor or throttle body. I'm doing my own research on the side, but I will do what you and Transman recommend.
Also, my downstream 02 sensor is right next to the transmission, and it's possible it got hit when they swapped the trans out. I mean, they hit everything else, so why not. Could a damaged 02 sensor do any of this?
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857373
12/08/20 09:13 PM
12/08/20 09:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Verify fuel pressure when it is acting up. You will need a gauge and there is a test port on the injection rail. You could tap in and run the gauge over the cowl and tie it to a wiper arm or tape it to the windshield. Correct fuel pressure is important and a must to verify.
Re: 46rh Governor Questions [Re: NITROUSN] #2857402
12/08/20 10:07 PM
12/08/20 10:07 PM
I'm familiar with the Schrader valve test port you're talking about. I'll get a fuel pressure test gauge tomorrow and drive around with it under my wiper so I can read it.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857408
12/08/20 10:21 PM
12/08/20 10:21 PM
Good point on the flywheel trigger windows, I had completely forgot about that until you mentioned it.
Any of the driveplates that have the windows can have the peripheral portion distorted too from a balance weigh welded on the outside of the converter getting pinched between this outer ring and the converter. This was a big problem on the 42LE in the Intrepid and Concord as well as the 42RLE in our other vehicles.
I re-read your post about the O2 sensor, yes it shares a splice with the OD solenoid wire - I have heard of instances that caused OD issues.
Re: 46rh Governor Questions [Re: A727Tflite] #2857621
12/09/20 01:08 PM
12/09/20 01:08 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
is it possible the downstream O2 sensor may be going bad, causing the fuel trim to mess up thereby causing the miss under load ?
beer
Re: 46rh Governor Questions [Re: moparx] #2857689
12/09/20 02:55 PM
12/09/20 02:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
Not really. The downstream 02 has very little to do with engine management. Its primary function it to measure the efficiency of the converter.
Re: 46rh Governor Questions [Re: NITROUSN] #2857971
12/10/20 08:21 AM
12/10/20 08:21 AM
Lesson learned, don't ever buy a fuel pressure tester from Harbor Freight. Not unless you want a gasoline shower.
I'm still not certain that the one that I bought from Autozone after that is working properly, it gave me a reading of 38 psi (after bleeding the air out from the connection, twice). The reading before bleeding was 0 psi, even when running. It advanced to 39psi once I shifted into drive, and stayed there. It never fluctuated up or down with the missing. If this number is correct, it's alittle low for my truck, I believe. However, the truck never acts like it's fuel starved. No pinging going uphill and it's burning plenty of fuel right now, believe me. My guess is that I'm not able to bleed the gauge fully and it's not giving me a correct psi reading.
Also, yesterday it was fairly warm outside, the TC engaged, and shifted right into OD. OD functioned perfectly until the outside air temp dropped, then refused to engage OD. This was after climbing under the truck and making sure that both connections were on nice and tight on the trans. The Neutral Safety switch was not on very tight, so I pushed it down hard. It's telling that my OD engaged for a bit after this, when the temp was warm enough.
Nitrous, you were right. Holy crap is that miss amplified when in OD. The whole truck jerks alittle.
I will be checking the brake switch today. Googling what is meant by that, now.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2857980
12/10/20 08:39 AM
12/10/20 08:39 AM
Also, the truck has had a custom dual exhaust that connects to an x pipe for equalization. There is no catalytic converter, as far as I can tell. Same headers and exhaust for the last 100k. I just wanted to let everyone know, to eliminate the catalytic converter as a suspected culprit.
I will climb under and take pictures of the entire exhaust system is anyone needs them. The x pipe (the place where the pipes come together before branching back out into dual pipes) has a heat shield on it.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2858005
12/10/20 09:36 AM
12/10/20 09:36 AM
N
NITROUSN Offline
NITROUSN  Offline
N
For what it is worth I have never bleed or heard of bleeding a fuel pressure gauge. Keep monitoring it when it is acting up.
Re: 46rh Governor Questions [Re: NITROUSN] #2858033
12/10/20 10:59 AM
12/10/20 10:59 AM
I couldn't get these cheap gauges to read until I bled them at the connection port. I had to make them spray alittle fuel for a second or two to get them to register pressure. Unless I'm just not using these things right, that's their normal operation. You're using much better gauges, I'm certain.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2858104
12/10/20 01:20 PM
12/10/20 01:20 PM
The brake switch runs the stop lights. It’s an input to the SBEC for lockup and cruise control..
While in cruise the assumption is that once the brake switch gets used that you want to stop, so shut off lockup.
You are slowing down so you want lockup disabled to prevent surging/bucking/etc.
Most engine driveability issues are exacerbated by driving in a higher numerical gear or in lockup or in manual transmission apps with clutch engaged.
Lower torque multiplication in high versus low.
Temperature having the effect on your truck sounds like to need to look at that very closely. I’m not a driveability guy but cold temp should make the truck rich - what if any effect on the miss I don’t know. But 60-65 degrees engine temp or higher and you get OD, lower you don’t.
Re: 46rh Governor Questions [Re: A727Tflite] #2858121
12/10/20 02:21 PM
12/10/20 02:21 PM
In regard to the temperature affecting whether OD engages or not, is this something that I should be tracking down on the engine side? Or should I be concerned that something in the trans is working incorrectly, sir?
I am going to change my thermostat, just in case it's malfunctioning and causing the engine to run cooler than it should.
Trans engaged TC lockup and OD perfectly all afternoon, because outside ambient temp was in the 70s. Miss is definitely something outside the trans, if my thinking is correct. This is a definite relief because I was still thinking I'd accidentally messed something up in the build.
Traffic was too heavy for me to use cruise control, will try tomorrow to check brake switch.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2859159
12/12/20 10:16 PM
12/12/20 10:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Any luck????
Re: 46rh Governor Questions [Re: NITROUSN] #2863977
12/23/20 04:20 PM
12/23/20 04:20 PM
I'd been waiting on that pigtail adapater to come in so I could try what Transman said about switching OD and TC on manually. Learned a valuable lesson today. To not do business again with PATC. They say they mailed me a part, it never arrived, then said it showed back up at their warehouse and that I must have refused it. So I'm out shipping, and a restocking fee for a part that I never received. Their parts manager has been horrible through email, so I'm out 20 bucks and still don't have the part. Lesson learned, though.
I've just been driving the truck like normal. Some days there's a miss, other days there isn't. When it's warm enough OD and TC lock up. When it's cooler out, they don't. Cruise control doesn't work, no matter what I do to try to engage it.
I'm still thinking that this is a fuel pump or bad fuel issue, like I thought in the very beginning. The other parts were just coincidental, getting broken in the install. I haven't put any more additives in the tank and have just been burning fuel. The miss seems to be getting less with each tank. I've noticed that it likes to do it once it's warmed up and has been driven for 45 minutes. I didn't see anything on the TC when the heat shield was off, not even when rotating the engine.
I honestly don't know what to do but just keep driving the truck and seeing what happens. This is not a new truck, we're closer to 300k than 200k, so I can live with a miss after a freshly rebuilt transmission I guess.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2864031
12/23/20 06:46 PM
12/23/20 06:46 PM
46rhRebuild Offline OP
O2 sensor will be getting replaced over the weekend, so maybe that will influence things. I'm sure the holiday season has been busy for everyone. Looking forward to being able to get it done after Christmas.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2864033
12/23/20 06:48 PM
12/23/20 06:48 PM
If the cruise does not work when the OD and lockup does then that is likely a cruise control only issue. I don’t recall all the requirements to achieve cruise lock, besides a Drive input from the N/S switch, trans speed signal, engine TPS, brake switch.
If OD and lockup does and so does cruise then likely you have an issue with a sensor or switch for temp. It should rule out the brake switch, N/S switch, speed sensor on the trans, the OD and lockup solenoids, engine speed input.
You still could have a wild TPS sensor showing wide fluctuation s in voltage.
Earlier you had asked about the temperature input. I’ll have to take a look at some paperwork and get back with you.
Re: 46rh Governor Questions [Re: A727Tflite] #2864354
12/24/20 02:18 PM
12/24/20 02:18 PM
As far as I know there isn't a speed sensor on this trans, or if there is I don't know what would be reading the speed. I've got a N/S plug and the other three wire plug coming off of the OD/TC solenoids, and that's it. If the vehicle speed sensor monitors that, then I'm going to go ahead and replace it. I'd driven without it working for years so just have been ignoring it. I monitor my speed by rpms and sound. It's second nature now.
I would love to know more about how temp affects this trans, as it pretty much dictates whether I have OD and TC lockup, sir. I can't thank you enough for all of your help. This project scared me to death, at first, but now I'd tear another 46rh apart in a heartbeat and rebuild one.
Re: 46rh Governor Questions [Re: 46rhRebuild] #2864416
12/24/20 04:16 PM
12/24/20 04:16 PM
A727Tflite Online content
A727Tflite  Online Content
Should be a speed sensor on the end of the speedo pinion adaptor. Maybe I am confusing years, instead of the cable there’s is a plug
Still looking for my paperwork -
Re: 46rh Governor Questions [Re: A727Tflite] #2864467
12/24/20 06:11 PM
12/24/20 06:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If your PCM has a fault code or an absence of speed signal the trucks engine and transmission will not function correctly.
Re: 46rh Governor Questions [Re: NITROUSN] #2865778
12/28/20 03:39 PM
12/28/20 03:39 PM
Sourcing speed sensor right now. I will report back once it's installed, along with any changes once 02 sensor is in place. Thank you Transman and Nitrous.
The truck didn't miss doing a grocery run today, so I got on the accelerator a bit when coming back home. Got up to 2500 in second gear before it shifted into third, nothing crazy. Truck missed every few seconds for the rest of the drive, after that. Shifts are perfect, outside of TC and OD, though.
I am going to swap the 02 sensor tomorrow hopefully. Weather has been bad down here (ok not lake effect snow bad, but rain and 40 degree weather still aren't any fun).
Re: 46rh Governor Questions [Re: 46rhRebuild] #2866068
12/29/20 01:42 PM
12/29/20 01:42 PM
Installed O2 sensor. Here is what it changed.
1. Truck has noticeable power increase
2. Miss is still present after truck warmed up
3. OD and TC engaged normally after truck warmed up
4. Miss is definitely present during acceleration and OD engagement
5. Miss is VERY noticeable when OD engages, as Transman and Nitrous both said
The speed sensor should be here in a couple of days, and I will install and report back then.
Truck is driveable, operation is better, miss is still present. At one point the miss was hard enough that it felt like the truck wanted to backfire. This was accelerating from a dead stop at a stoplight.
Page 1 of 12 1 2 3 11 12
