Re: Okay lets see some 360 build-ups (400 to 500 horse) #276994
04/05/09 10:16 AM
04/05/09 10:16 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
OK. Here's the specs: 4 inch eagle cast crank, scat I-beam rods with 7/16 capscrews, KB forged flattops, zero decked, and internally balanced...(those scat rods only weigh 572 grams, and cost $258) The compression figures right at 12.7 to 1. The cam is a solid with 256/260 @ .050, with .616/.626 lift with the 1.6 crane rollers. The heads flow 280cfm (after some home port work), and the intake is an M1 single plane.
The carb is a 1000 cfm holley 4150, and I have a Wilson one inch spacer.
The carb sounds big, but it was worth a solid 2 tenths over the 750 proform with much better throttle response. The carb took me from 12.40s to 12.20s, and the E85 took me right to 12.0s. The major increase was torque. My sixty foot time went from 1.74 to 1.66, and I had to shift at 6200 instead of 6400 like I did on the 91 octane. It is surprisingly streetable with 3.91 gears and a PTC 4000rpm stall converter in the 904 trans.
E85 took my mileage from 15 to about 12, but that was with about 10 to 1 compression, so we will see if the higher compression really helps with the fuel economy...it liked 10 less jets on the dyno than before... 90 with a power valve in front, and 99 in the rear (before it was 99/110). I do have E85 metering blocks, as the holley passages only flow about the size of a 94 jet...the jet extensions had to be drilled out as well. In fact, it ran the same without a jet in the rear extensions as it did with the 110s.
Keep in mind I race at 4880 ft elevation, so the NHRA corrected number for a 12.0 is 11.27, and I hope to be running 11.50s this year. I will find out in two weeks at our first heads up race of the season. I plan to run the 11.60 index class, so I should at least be competitive hopefully!
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Okay lets see some 360 build-ups (400 to 500 horse) #276995
04/05/09 10:18 AM
04/05/09 10:18 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
my 360 might have had 550 + horses. when i put it in calcutator on 60ft, mph ,et its different .
360 .040 flat top 4 cast crank finally died
lightly ported j heads 540 racer brown cam.1.6 cranes rockers ran best 10.37
than put reported eddies on last year 10.13 .
strokerkit is easy horsepower without a big cam for street
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: 10 o to go] #276996
04/05/09 10:30 AM
04/05/09 10:30 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am hoping mine makes 400. Its a 11:1 .040 over 360 with KB Hypers in it with .039 quench. Out of the box eddies with appropriate springs. Cam is Intake 318 Exhaust 325 Intake Lift .618 Exhaust .642(can't find duration at .050 right now). Victor 340 Manifold and a 700 Holley with proform body. Hope it runs good, car is heavy 3500lbs with 3.91 gears and a TA 8" 4500 converter.
68 Barracuda Formula S 340
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: 10 o to go] #276997
04/05/09 12:03 PM
04/05/09 12:03 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
don
fwi: when your computing the 60ft times output will always compute higher due to the torque multiplication of the torque converter..it multiplies actual output off the crankshaft and hydralically makes more torque for a short period just as the car launches..
that would account for a higher output reading when you factor in your 60ft..
mph readings is the best most accurate way to determine power output.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: cheapstreetdustr] #276998
04/05/09 12:18 PM
04/05/09 12:18 PM
Huron, South Dakota, United St...
dustyhof Offline
dustyhof  Offline
366 inch. Early 80's block, stock crank and rods, 11.8:1, KB pistons, CNC ported Edelbrocks, Mopar Purple shaft solid cam, 296 duration, .557" lift, M-1 intake, 950 Quick Fuel Carb. Ran a best of 11.36 @ 119 with a borrowed carb last year.
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: cheapstreetdustr] #276999
04/05/09 12:30 PM
04/05/09 12:30 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
This one is probably a little shy of 400 but it is very street friendly. .020 over 360,10.5 compression,Mopar .508 hydraulic with stock rocker arms,edelbrock heads,TTi headers,Air Gap intake,750 Demon,MSD 6 with MSD distributor(added after pics) 12.40's @ 109mph.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Okay lets see some 360 build-ups (400 to 500 horse) #277000
04/05/09 12:34 PM
04/05/09 12:34 PM
Anonymous OP
Anonymous OP
My little 366 puts out 392 h.p. not quite the 400 h.p. your looking for, but gets my '70 duster in the 11.70's @ 111:
1. '77 360 block 30 over
2. stock crank
3. eagle rods
4. speedpro pistons/rings
5. Lunati .513/.533 voodoo cam
6. Edelbrock heads w/mild work
7. Edelbrock air gap gasket matched
8. Quickfuel 850 carb.
of coarse full msd ignition and tti headers too....switching too the .533/.552 voodoo cam and single plane intake next week hoping for 11.40's...
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: 67HEMI] #277001
04/06/09 01:41 AM
04/06/09 01:41 AM
Anonymous OP
Anonymous OP
Wow looks like we got some major 360 power on this site....
Re: Okay lets see some 360 build-ups (400 to 500 horse) #277002
04/06/09 02:27 AM
04/06/09 02:27 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I had a stock crank .04 overbored 360 in the Demon that went 10.25 at 129.99 mph. Ported 587 heads,.590 racer brown flat tappet cam, victor 340 intake, crane gold 1.6 rockers, 11.75 to 1 comp ratio. Motor in car now is a .04 over 360/ w a 4.100 stroke crank, [418 c.1.]. Still has the racer brown .590 cam and ported 587 heads, a little adtnl. work to heads, flat top piston out of the hole .080, 13 to 1 comp ratio, Victor 340 intake, Crane 1.6 rockers. Burns 110 octane race gas or would be fully streetable. Never over 190 degrees even when it's near 100 deg. outside. Has gone as fast as 9.68 at 135 mph and as far as 450 ft on the rear wheels. Definetly over 400 to 500 horse . Not to shabby for a junkyard headed small block in a car that weighs 3060lbs. I never recall seeing a brand X sm block w/ junkyard heads anywhere near my e.t. at or near 3060lbs. I chase alcohol burning, roller cammed, aluminum headed sm block chevys all the time.
Re: Okay lets see some 360 build-ups (400 to 500 horse) #277003
04/06/09 08:08 AM
04/06/09 08:08 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
2. stock crank
3. eagle rods
392? is that on an engine dyno or chassis dyno?
2017 Grand Cherokee Overland
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: patrick] #277004
09/17/09 02:09 AM
09/17/09 02:09 AM
Barrie, Ontario, Canada
19Charger74 Offline
19Charger74  Offline
This ones kinda right in between your 400 to 500hp mark.
360ci .30 over bore, ported heads to flow 265cfm up from .500 lift with 2.02 & 1.60 valves, Eddy Air Gap, 750 holley carb, Mopar purple cam 292, 9.5 to 1 compression, MP ignition, TTI headers, MP windage tray.
I found a few 360 engine builds and this one apparently makes 450+ HP all day long and is dyno proven. I'm folling it for my build but adding some other stuff in there.
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: qwkmopardan] #277005
09/17/09 12:51 PM
09/17/09 12:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
THAT is stout...that moder must love that .080 out of the hole quench!
Tell us more:
Trans (ratios?)
Converter
Rear gear
Carb
Looks like ladder bars...??
Re: Okay lets see some 360 build-ups (400 to 500 horse) [Re: cudadoug] #277006
09/17/09 02:28 PM
09/17/09 02:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
73 360 +.030 stock crank h beams with kb 107s .002 out of the hole .040 mls gasket,home ported J heads milled to closed chamber .070 I think , 2.05 intake 1.60 exhaust , crane hyd roller around 238/ 242 @ .050 108 on 104 with just under .600 lift , ported M1 intake Holley 850 dp , hooker 1.75 headers, home built with apr studs top and bottom , never on dyno but pulled great to 6500, super low maintenance nothing to do but change the oil, mud raced with over 500 passes, I would think it will fall in the 400 to 500 range somewhere
Re: Okay lets see some 360 build-ups (400 to 500 horse) #277007
09/17/09 05:51 PM
09/17/09 05:51 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
My 360
Stock 1971 block
Stock crank
Stock rods
KB pistons 11.7-1 comp
Edlebrock heads ported by Hughes and milled to 55cc
TTI step headers
Custom Comp Cams solid lifters
Crane gold rocker arms
Smith Bros. pusrods
M-1 intake
Moroso elec water pump
950 holley carb on top of 1" open spacer and 1" super sucker spacer
Barry grant 220 pump
All MSD ignition
727 trans with 9.5" dynamic converter
4.10 rear 28" tall slicks
Car weighs 3260# with me in it, runs great on 93 octane
Made 421 horse at the rear wheels, Best ET. 11.21 at 121mph
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
