Re: Fixing Big Block Cam Bearings
[Re: dthemi]
#2771656
05/05/20 11:24 PM
05/05/20 11:24 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
If you're using the same cam, here's something that happened on a BBC. Plenty of oil clearance, and straight. Ate bearings almost as soon as it fired up. The problem turned out to be tiny heat cracks in the cam you couldn't feel with your hand. Showed up in the polisher. New cam , no more instawipe bearings. I mean smoke coming up through the valve cover with almost. 003 oil clearance. Spun by hand like a top, but as soon as pressure and heat hit it,,,presto saw blade Thanks for the input, I really do appresiate all the replys. I'm sure it is a possibilty, at this point it doesn't matter why. My OP was asking if anybody knew there was enough room to install 54mm or 55mm roller cam bearings not "What went wrong?" I've been in touch with a good friend of mine that owns a real, real top notch shop and we have decidded to install 50mm roller cam bearings. He told me Bullit Cams has cam cores so that is another thing I don't have to find. Al said I might have an oiling issue and I might, I don't know. This block has lifter bore bushings in all the lifter bores and that has been a topic in the past but that being said I had 50PSI at idle and 85PSI from 3500rpm through 7500rpm (Data logger). I might make a tube bypass to help the oiling but once again the engine bearings looked wonderful.
[Re: MR_P_BODY]
#2807366
08/10/20 04:53 PM
08/10/20 04:53 PM
Biginchmopar
Carson City, Nevada
I have the 50mm bearings in my 48* SB.. I had to do a slight bore job to get the bores right I really like the 50mm on a SB I have 60mm roller bearings in my Small Block I really like them and the cam. I was going to try 55mm but I didn’t want to weaken a stock block.
[Re: LA360]
#2807574
08/11/20 08:24 AM
08/11/20 08:24 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Glad you got it sorted out! That looks awesome too! What would the machining to install these bearings in a block typically cost?
[Re: an8sec70cuda]
#2807614
08/11/20 10:48 AM
08/11/20 10:48 AM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
So now that that this hurdle has been cleared what is the plan for the block?
[Re: cudaman1969]
#2807691
08/11/20 01:39 PM
08/11/20 01:39 PM
Biginchmopar
Carson City, Nevada
Are all the bearings the same size? Do you need a special cam or does it ride on the bearings? All the bearings are the same size (50mm) I had to get a new cam from Bullet Cams. It's not anything real special just a 50mm cam core. Yes the cam rides on the bearings.
