Re: It is time to ask for help - A/C fitting
[Re: Old Ray]
#2768414
04/26/20 01:08 PM
04/26/20 01:08 PM
Posts: 19,587 north of coder
moparx
pics would be nice if possible. i "think" you should be able to double flare the aluminum line connected to the block and join a double flare steel line to it using a double flare connector [female both ends], providing you can find the proper size connector for your lines. with this, i'm aSSuming both lines to be connected are the same size ?
[Re: moparx]
#2768605
04/26/20 11:42 PM
04/26/20 11:42 PM
Posts: 2,042 colorado
savoy64
colorado
tubes and hoses? anything like that near you? maybe pacific hose?
[Re: Old Ray]
#2769016
04/28/20 09:48 AM
04/28/20 09:48 AM
Posts: 240 British Columbia, Canada
Old Ray
General question, (and Gene) this is the stainless weld-on adaptor from Vintage Air, I am not sure what kind of weld or braze to use as the OEM steel lines seem more steel then aluminium alloy so rather then risk it, would it be possible to drill and tap the stainless adaptor (if there is enough material) and use a pipe short nipple ? Living near a small town in the country has it advantages, ... this is not one of them.
[Re: Old Ray]
#2769260
04/28/20 08:30 PM
04/28/20 08:30 PM
Posts: 1,514 AZ
Mike P
AZ
Hope I'm not missing something here. As understand what you want to do is connect the pipes on the block to a hose. In the past I've been able to use compression fittings for situations like this. 4 Seasons makes the fittings I've used before...... I've had good luck with them and all you need to install them is a couple wrenches.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Old Ray]
#2769280
04/28/20 09:08 PM
04/28/20 09:08 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
Oldray, I don't do much AC, I'm a windows down kind of guy. That said, I doubt there is enough material in an AC line to cut threads into, the lines I've seen are way too thin. As far as welding, Stainless is usually pretty nice to weld to. If the AC lines are steel with an aluminium coating, you will have to remove the coating to weld to the stainless fitting. I would suspect a gas weld or a tig weld would be the best method, because its too easy to burn through thin tubing with a mig. A compression fitting may work, but I would really want to watch for a freon leak using a compression fitting.
They have been making custom length AC hoses for years, there has to be a simple way to accomplish this, might be worth consulting a home AC installer. They do custom hoses all the time. Gene
[Re: Old Ray]
#2769901
04/30/20 06:23 PM
04/30/20 06:23 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Thanks Kevin, someone else suggested Aeroquip also in regards to steel hydraulic lines to hose on industrial equipment. I am looking in to it. If you remember (at 3 in the morning) where you had seen it please let me know. Thanks. I found these. Maybe something there that will work for you. https://www.apairinc.com/shopping/?ic=4340Kevin
[Re: Twostick]
#2769981
04/30/20 09:58 PM
04/30/20 09:58 PM
Old Ray
I found these. Maybe something there that will work for you.https://www.apairinc.com/shopping/?ic=4340 Kevin WOW ! that's some crazy stuff ! I had not thought of two individual fittings with a bar to hold them in place. the backside of my block fitting has small short nipples that fit into the condenser block. This company has the fitting with different pilot sizes so I will have to measure mine. Thanks, cool.
[Re: Twostick]
#2771602
05/05/20 08:55 PM
05/05/20 08:55 PM
Old Ray
UPDATE: I would like to thank twostick (Kevin) very much for his help. I contacted them and got a price on some kind of industrial equipment fittings that I think would have worked. I also found some other fittings that would have to be brazed on with silver solder. I was about to order some when I realized I was looking at this all backwards, I think I was being cheap and trying to use as much of the Dakota as possible, but for a guy that lives by the creed that every equation has two ends, so you can change either end, I was blind, stupid, and mostly old. The fittings and the silver braze or the other fittings with shipping to Canada were going to be close to $ 100.00 Canadian, it took me a long time to see the light but why not change the condenser to an aftermarket one with the #6 and #8 fittings already installed. EUREKA ! $ 57.00 cdn with free shipping from amazon. (made in China) See, two ends to the equation if I would have had my eyes open. Thanks to all that helped, much appreciated.
