Re: pressure testing a heater core [Re: stumpy] #2770408
05/02/20 11:43 AM
05/02/20 11:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by stumpy
Because I have used a garden hose to pressure test a heater core when I didn't have a compressor to use. I just opened the faucet a little at a time.
That would not work if the outlet of the core is capped, as the pressure will equilibrate to whatever the line pressure is. beer
Re: pressure testing a heater core [Re: TJP] #2770418
05/02/20 12:13 PM
05/02/20 12:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Well it worked fine for me. shruggy
Re: pressure testing a heater core [Re: stumpy] #2770498
05/02/20 04:54 PM
05/02/20 04:54 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
This tells how high a water column needs to be to maintain a certain water pressure. Some of our water towers are up on the top of the hills at the outskirts of town. Taller the water tower is (or how high up the hill the water reservoir is), the more water pressure you will have.
->kylesconverter.com/pressure/pounds-per-square-inch-to-feet-of-water<-
