Tritech three piece rear main seal install? #2765138
04/17/20 03:58 PM
04/17/20 03:58 PM
gregsdart Offline OP
I bought a Big block rear main seal but no instructions came with it. Anyone have instructions? Two days and nobody at tritec or Elite racing will answer the phone.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765214
04/17/20 06:28 PM
04/17/20 06:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A "three piece" main seal. That sounds like a bunch more places to leak !!!
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765290
04/17/20 10:00 PM
04/17/20 10:00 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
picture and part no ?
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765527
04/18/20 02:09 PM
04/18/20 02:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Looks like the O ring stretches over the crank flange but does the O ring go inside or outside the seal halves?
Re: Tritech three piece rear main seal install? [Re: John_Kunkel] #2765551
04/18/20 03:12 PM
04/18/20 03:12 PM
over the outside. Also they go in dry. Absolutely no lube on crank or seal or they will leak. But which way do they face and any other instructions?
These seals are made of ptfe and tgat is why no lube.
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765555
04/18/20 03:38 PM
04/18/20 03:38 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I believe that you are looking at the outside. The lip that is sticking up in the picture should be a dust seal.
Brian
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765558
04/18/20 03:45 PM
04/18/20 03:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well considering they operate with vacuum system it's tough to say what side goes to the source without having them in my hand. Maybe one of the Chevy sites have information on them or the Bullet shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Tritech three piece rear main seal install? [Re: fourgearsavoy] #2765684
04/18/20 09:02 PM
04/18/20 09:02 PM
Pic of seal. Tan inner lip gray outer lip and sealing band. So far i know this;
Instal DRY! Crank included. Any lube will cause a leak.
Splits at 12 and 6 oclock
Very light lube on outer edge of sealing band so it doesn't stick and bunch up when the crank is installed
I do not know which way it goes in - lip turned in or out?
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765699
04/18/20 09:22 PM
04/18/20 09:22 PM
Me thinks I will pass on this seal for now shruggy
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2765705
04/18/20 09:33 PM
04/18/20 09:33 PM
Rittman Ohio
Rittman Ohio
From what I've read about these seals they have to be used with a vacuum so that would mean the lip would go to the crank flange. That way when your pump is pulling vacuum it will suck that seal lip tight against the journal . That's the way I would install it.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Tritech three piece rear main seal install? [Re: fourgearsavoy] #2765971
04/19/20 01:36 PM
04/19/20 01:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gus beer
From what your saying the lip of the seal would go in towards the crank.. I would put that seal in
with the lip(the loose or free side) of the seal outward so air coming in would expand the lip to
assist in sealing.. if it had no vac pump then I would turn the seal around due to pressure already
on the crank case.. I guess it comes down to terminology.. what is the lip
wave
Re: Tritech three piece rear main seal install? [Re: MR_P_BODY] #2766010
04/19/20 03:24 PM
04/19/20 03:24 PM
Gus beer
wave
I agree with you guys logic, but then i also wanted to sale on the Titanic😅 So i hope you understand my hesitation till i get instructions.
Re: Tritech three piece rear main seal install? [Re: MR_P_BODY] #2766013
04/19/20 03:28 PM
04/19/20 03:28 PM
Rittman Ohio
Rittman Ohio
Gus beer
wave
When I say crank flange I mean the flange the flywheel bolts to.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Tritech three piece rear main seal install? [Re: fourgearsavoy] #2766029
04/19/20 04:15 PM
04/19/20 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gus beer
wave
Gus beer
Got ya.. I took that to mean crank side as to the inside of the engine not the exterior(out side)
wave
Re: Tritech three piece rear main seal install? [Re: MR_P_BODY] #2766729
04/21/20 12:28 PM
04/21/20 12:28 PM
FINALLY! Talked to the engineer that designs these seals for Nascar and prostock.
The lip faces the transmission so vacuum pulls it tighter. Install dry and dry crank surface. Self lubing. except for light lube on the outer O ring for ease of install. Splits at 10 and 2 oclock. PTFE Can withstand very high rpm and much wider temp range than other seals.
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2766734
04/21/20 12:40 PM
04/21/20 12:40 PM
AndyF Offline
AndyF  Offline
10 and 2? How would that work? 10 and 4 or 2 and 8 maybe.....
Re: Tritech three piece rear main seal install? [Re: AndyF] #2766804
04/21/20 03:19 PM
04/21/20 03:19 PM
Andy, the engineers explanation was that that achieved good, even compression of both parts of the seal.
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2766808
04/21/20 03:37 PM
04/21/20 03:37 PM
AndyF Offline
AndyF  Offline
10 and 2 are not 180 degrees apart so it doesn't make any sense.
Re: Tritech three piece rear main seal install? [Re: AndyF] #2766837
04/21/20 04:58 PM
04/21/20 04:58 PM
Since the two parts crush slightly when the retainer is installed, if the two parts were both at 12 oclock they would not have to slide on each other to seat properly but might leak. If they were 180 degrees from each other that would create the largest amount of slip between the inner and outer parts. 10 and 2 make sense to me because they would be offset a lot but wouldn't have to slip as much to crush together, eliminating distortion. 572boatracer has been able to pull some very high vacuum using these seals.
The engineer also asked what seal i was using on the front of the crank. The Milodon geardrive seal works fine but Tritec makes a special seal for Jesel beltdrives to help hold vacuum.
Re: Tritech three piece rear main seal install? [Re: gregsdart] #2766845
04/21/20 05:29 PM
04/21/20 05:29 PM
AndyF Offline
AndyF  Offline
Okay so put one end of the seal at 10 o'clock and the other end at 2 o'clock and tell me how that looks to you!
