Re: 1971 Cuda Dome Light Blinks With Turn Signals Or Hazards
[Re: Jeffaary]
#2766693
04/21/20 12:28 PM
04/21/20 12:28 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
This is a product of too small of a feed wire in gauge. Its called voltage drop. It is why the headlights are dim too at idle. Also all the connectors offer up a resistance too.
With the engine off voltage at the dome light is at 11 volts +/- 1 volt and when you put the 4 ways on you may see the voltage drop to 9 - 10 volts and then when the 4 way bulbs are out it will wink to the 11 volts again. But start the car and now the altanator is pushing 14.5 volts and that extra 2 volts does make a difference.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2766703
04/21/20 12:47 PM
04/21/20 12:47 PM
Dave_J
Auburn WA
Just to expand on wire gauge and voltage drop. On my 65 Barracuda the book says my headlight wires are 18 Gauge. This is too small for the wattage draw in amperes. It should be about 14 gauge at 12.5 volts. And the voltage must go from the engine side of the firewall thru a Bulkhead connector inside and then thru the headlight switch, then back thru that bulkhead connector a second time. So I wire in a relay system and feed the headlights directly with a 14 gauge wire right from the lug on the starter relay. Bigger wire gauge and less connectors makes the headlights MUCH brighter.
Same thing on my son's 1974 D200 pickup. The book says the headlight wires are 18 gauge. But I cut them and stripped the plastic insulation off and did a measurement and found that the wire was really 20 gauge. Way too thin of gauge.
Wire is costly for a manufacture. Thicker gauge wire cost more. So they use the thinest to just get the job done. No reserve in power rating. So when I do a rewire job on a daily driver I will replace all 18 gauge wires with a 16 or 14 gauge. Any 14 gauge gets a 10 gauge if I can. All starter cables get upgraded to 2 gauge. But wire also adds weight to the vehicle so this is why we have common chasses grounding. The better would be a true return ground wire for every item but this extra wire adds cost and weight.
[Re: Jeffaary]
#2766822
04/21/20 05:33 PM
04/21/20 05:33 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
it was somehow "normal" back in the days, now with aged conections and wires, even more. A low charged batt will make that even worst. With engine running the dimming on these is reduced because the increased voltage up to 13-14 rate. In some cars you can even notice the radio volume going up and down while blinking because on these the Radio feed is shared by the tunring flasher
Hazzards are a big suckers.
As I allways say, if you make mantenience on brakes and fuel system, electrical needs that too after 50 years. But, nobody uses to care that and think electricals will survive forever.
[Re: jlatessa]
#2766912
04/21/20 09:12 PM
04/21/20 09:12 PM
NachoRT74
Valencia, España
Flasher is allmost a Relay by itself. However a relay after the flasher won't work because flasher requires the bulbs load to work. A Relay before the flasher makes allmost no sense because there is not a trigger to make it work really. The hazzard one would be allways engaged, while the turning, will be engaged as soon you put the ign switch on.
Now, a trigger for the dome light.... well I would preffer to make the right thing which is a propper electrical system mantenience. Relay for dome light will solve the problem for it but won't fix the real problem.
Wondering when ppl will stop to patch the electrical stuff instead get deep into the deal to fix the worn and damaged parts!
[Re: NachoRT74]
#2766927
04/21/20 09:44 PM
04/21/20 09:44 PM
Dave_J
Auburn WA
Flasher is almost a Relay by itself. However a relay after the flasher won't work because flasher requires the bulbs load to work. A Relay before the flasher makes almost no sense because there is not a trigger to make it work really. The hazard one would be always engaged, while the turning, will be engaged as soon you put the Ign switch on.
Now, a trigger for the dome light.... well I would prefer to make the right thing which is a proper electrical system maintenance. Relay for dome light will solve the problem for it but won't fix the real problem.
Wondering when ppl will stop to patch the electrical stuff instead get deep into the deal to fix the worn and damaged parts! I think the 'Relay' comment is more directed to doing a Headlight rewire. You can get a nice H4 'Chinese' made one for $10 off Ebag but if you use one on a 6024 or 4656 headlight you must move two pins as a H4 and 6024/4656 use the same connector but for some reason they flipped two pins, Low beam and Ground pins. H4 headlight relay kit: https://www.ebay.com/itm/Headlight-H4-Headlamp-Light-Bulb-Ceramic-Socket-Plugs-Relay-Wiring-Harness-Kit/273763423866?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I do repairs as needed and if its not a 'Points Show' car I will cut old wires out and replace with better quality and replace bulkhead connectors as needed. I order 45 sets of the bulkhead connectors at a time to have some on stock. Bulkhead connectors also work on most spade connectors all over the body of a Mopar. Bulkhead Connectors: https://www.ebay.com/itm/Mopar-Male-Female-14-16-AWG-Gauge-Wiring-Harness-Terminal-Crimp-Connectors-NOS/192502001151?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I have two 4X8 foot sheets of 5/8" plywood here. On sheet 1 is the wiring layout where I took a 1964 Studabaker Daytona's wiring harness and used brad nails to make the layout. I then replaced 1 wire at a time, put new connectors on and rewrapped with glue-free vinyl tape. I pulled the brads out but my ink pin marks are still on it. Flip side in my 1965 Barracudas wiring layout. Second sheet is my 1978 Little Red's wiring and flip side is one for 1984 L body Omni/Charger
[Re: Dave_J]
#2767000
04/22/20 07:12 AM
04/22/20 07:12 AM
NachoRT74
Valencia, España
I installed 6 relays on my car. One for each AC-heater speed ( four ) and the other two for headlights, but all relays are into the cab hidden down the dash without cut a wire ( I didn't want a single relay visible ) All just relocating the stock terminals from switch plugs to relay plug and jumping a wire ( same color ) to continue the original trace. But I made it mostly to save switch points. My headlights are halogen sealed beams with sucks more power than regulars, and the AC blower switch plug allways got melt on my 74 due the poor contact made inside. I, still using original wiring and terminals to handle the power. I did of course the complete wiring and terminal mantenience of course, and replaced terminales where needed.
[Re: bee2333]
#2767141
04/22/20 03:22 PM
04/22/20 03:22 PM
Dave_J
Auburn WA
While diagnosing other electrical gremlins I had my door open while testing my blinkers and hazard lights. I noticed that the dome light got dim and bright as the blinkers went through their cycle. It was even more noticeable with the hazards. Anyone ever experience this? Does this sound like a ground or component issue? I see from the service manual that power to the dome light and the stop light switch come from the same place, so there is a relationship there. I had the same problem, after a lot of components changing, I found a factory splice in the engine harness ( if I remember correctly coil to ballast resistor to fuse panel wire is spliced) re-soldered it, solved I think these are likley the issue. I would start by slowly/carefully removing the Bulkhead connectors on the firewall. Clean all the male spades using some emory cloth. Don't go over board, just knock the darkness off so the brass kind of shows. It does not need to be shiny. Then use some Di-electric grease on the spades. This is also called 'Bulb Grease' in packets at Autozone. 3 packs should do it. On the firewall side female spades clean then as best as you can with the emory clothe folded small to insert in the female part using care not to get the emory cloth stuck. Blow out with compressed air or "Keyboard Dust Off'. Put the connectors back together and see if that helped. Then, the door jamb switches are hard to get too but clean them up and make sure they are solid grounded. Something as simple as the old fuse in the fuse block. Clean the fuse lugs and put in a new fuse. The old one may be slightly bad but looks OK.
[Re: Dave_J]
#2767143
04/22/20 03:30 PM
04/22/20 03:30 PM
NachoRT74
Valencia, España
This uses to be my procedure: Clean the terminals with degreaser, gasoline or diesel and a brush, then brush and soap to remove the oil products... sink the terminals on vinegar and salt solution for 4 or 5 hours ( this will eliminate rust and sulfated areas which previous cleaning process won't eliminate ), then a baking soda solution to remove acids and you will be good to go!.Brass will change a bit the color from yellow/gold to orangish but the metal will be nicelly exposed back to get good contact. bulhead and insulators needs to be deeply cleaned too. If not, you'll get bad contacts again. we are talking about 50 years of abuse and forgotten systems. try to keep original terminals were is posible. The factory crimping will be allways way better than any crimp you will make at home. If some terminal needs a replacement, crimp and sold will make the best job. I even used small 180 grit sandpaper pieces to insert and clean inside the curvatures ( inside the "claws" ) of the female terminals, one by one but If I have had one of these on hands, maybe was used that BTW I also get tight a bit the female outer claws with a plyer to catch tighter the male end once is inserted
[Re: NachoRT74]
#2767336
04/23/20 09:27 AM
04/23/20 09:27 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Go to AMazon and look up De-Oxit D5. Its the old Caig Laboratories Cramolin. I used to use the Red R100L and Blue B100L which were red and blue cans. It looks like the De-Oxit is the just the red. The red was the cleaner and the blue a protectant. In general, the D5 is good alone.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: BDW]
#2767470
04/23/20 02:52 PM
04/23/20 02:52 PM
NachoRT74
Valencia, España
But that doesn't fix the problem, just makes learn to live with it. Nice to have led bulbs if you want ( I'm not a fan of those, but at each own ), but terminals issues will be still there just masked with the less load devices.
Stop hidding the problem and go for it!
[Re: Jeffaary]
#2767740
04/24/20 06:44 AM
04/24/20 06:44 AM
NachoRT74
Valencia, España
It should have been the first LOL.
Voltimeter conversion is not a need, but this will be an endless discusion along the eternity LOL.
Oh well, and of course, the ground checks in all 4 corners! This is about everything.
