Re: Tach acting erratic. 69 dodge
[Re: moparx]
#2765961
04/19/20 01:57 PM
04/19/20 01:57 PM
Posts: 6,111 Detroit
Kidsixpack
Detroit
MSD box overheating because it's hidden ? loose/corroded tach connection on box ? I will check this. Thanks KID
[Re: moparx]
#2781500
06/04/20 07:46 PM
06/04/20 07:46 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
MSD box overheating because it's hidden ? loose/corroded tach connection on box ? Mine was a loose/high resistance connector right on the negative side of the coil Obviously looking at it , you sure in the hell couldnt tell when it had full insulation/rubber over terminal end Didn’t figure it out until I took an ohm meter on the wire itself and had the wife wiggle and bend and move the wire around And then when I finally took/peeled the insulation off you could see the dark area Was a bad connection I would assume since new , as it progressively got worse over the years
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Kidsixpack]
#2781712
06/05/20 12:43 PM
06/05/20 12:43 PM
Posts: 6,567 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Nothing new in the ignition system. The tach is wired to the hidden MSD. It’s all been on the car for around ten years. KID Including the Monster Tach? Kevin
[Re: Twostick]
#2787269
06/19/20 10:11 PM
06/19/20 10:11 PM
Kidsixpack
Detroit
Nothing new in the ignition system. The tach is wired to the hidden MSD. It’s all been on the car for around ten years. KID Including the Monster Tach? Kevin Yes the tach has been on the car at least as long as the MSD. Planning to try to work on it this weekend, Will update this post. Thanks KID
[Re: Kidsixpack]
#2787333
06/20/20 09:26 AM
06/20/20 09:26 AM
Posts: 2,529 God's Country Maryland
GODSCOUNTRY340
Your tach could be bad. I had an Auto Meter tach go bad years back, the 340 developed a mis and a jumping tach needle that I couldn't track down to any certain cylinder. I replaced all the electrical components in the ignition system, no fix. I disconnected the tach wire and the mis went away. Hooked it back up and the mis came back. It was the tach all along.
