Re: 512 with Trick Flow top end [Re: AndyF] #2765307
04/18/20 12:03 AM
04/18/20 12:03 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Ooops got caughg with the bounce between b/rb
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 512 with Trick Flow top end [Re: AndyF] #2765383
04/18/20 09:51 AM
04/18/20 09:51 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Originally Posted by AndyF
And talk to Dwayne about the camshaft. I was using a 264/268 duration solid roller in my 470 with dual conical valve springs and 1.65 ratio T&D rocker arms. If I was building a pump gas 512 and I wanted to hit 750 hp I'd use the same lobe family but maybe add a little duration. I'd probably use the same springs and rocker arms and I'd use a Wilson ported Indy 400-3 with a 1050 Dominator with 2 inch headers. I'm pretty sure that combo can make 750 hp with the 270 heads.
Andy can you explain what 2 inch headers play well with the trick flow heads and a low deck block...or anyone that has used them on a low deck and what car you installed them in ..... Thanks
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
