Re: oxy/acetylene heating Q [Re: Dave_J] #2764235
04/15/20 01:09 PM
04/15/20 01:09 PM
moparx Offline
moparx  Offline
the only drawback with using stainless fasteners, is you MUST use [lots of] anti-seize to prevent the threads from galling.
just 45+yrs of experience using stainless fasteners.
beer
Re: oxy/acetylene heating Q [Re: RapidRobert] #2764357
04/15/20 05:59 PM
04/15/20 05:59 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted by RapidRobert
I worried that if I heat the nut cherry red that it will weaken the bolt that it is on. Am I worried over nothing?
1. The rust has compromised the strength more than the heat will. Go for it. Does not need to be glowing cherry red . Stop When you see it start to change color. A couple of heat cycles will help.
2. The crayon/wax trick works.
3. Make your own very effective penetrating oil with tranny fluid and acetone.
