Parts Cleaner Question #2762344
04/10/20 02:42 PM
04/10/20 02:42 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Does anyone use diesel in their parts washer/solvent tank?
Re: Parts Cleaner Question [Re: elmor353] #2762354
04/10/20 02:58 PM
04/10/20 02:58 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Mineral spirits.
Re: Parts Cleaner Question [Re: 6PakBee] #2762392
04/10/20 04:06 PM
04/10/20 04:06 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I used to use mineral spirits but its gotten expensive. Now I use solvent from Safety-Kleen. Its about the same money but has a higher flashpoint. When solvent was cheap I wasn't too concerned about using it but with the price of the stuff now I give everything a quick wipedown first to get most of the crud off.
Re: Parts Cleaner Question [Re: elmor353] #2762425
04/10/20 05:24 PM
04/10/20 05:24 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I don't have a parts cleaner, but I really like Avgas
Re: Parts Cleaner Question [Re: 71birdJ68] #2762434
04/10/20 05:39 PM
04/10/20 05:39 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Yep cleans off all facial hair real quick.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Parts Cleaner Question [Re: Dave_J] #2762445
04/10/20 05:54 PM
04/10/20 05:54 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I've used diesel in mine for years, just close the lid when not using or your garage will have that diesel smell.
Re: Parts Cleaner Question [Re: GODSCOUNTRY340] #2762457
04/10/20 06:35 PM
04/10/20 06:35 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I've used diesel as a pre wash to get the big glop of crud off pre disassmibly. But in the parts washer I use 5 gallons mineral spirits. I was paying $8 a gallon ($40) but just looked and its $14 a galllon ($70)
65 Formula S Cuda
Re: Parts Cleaner Question [Re: Dave_J] #2762461
04/10/20 06:46 PM
04/10/20 06:46 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I was using Stoddard solvent, but it's gotten expensive and I can get diesel for $3 a gallon.
Re: Parts Cleaner Question [Re: elmor353] #2762472
04/10/20 07:40 PM
04/10/20 07:40 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Smell is the main reason not to use diesel. The flash point is higher than true mineral spirits.
Diesel flash point is about 52 C to 175 C depending of the Bio amount.
Regular Mineral spirits is between 30 C and 54 C
The newer 'Green' Mineral replacement is just mixed with water and will settle out over time. That water will go to the bottom of your washer tank and mix with the crud. NASTY.
65 Formula S Cuda
Re: Parts Cleaner Question [Re: Dave_J] #2762593
04/11/20 08:45 AM
04/11/20 08:45 AM
In a van, down by the river
jmf340 Offline
jmf340  Offline
Been using Super Clean for a while with decent results
Got Mopar???
Re: Parts Cleaner Question [Re: jmf340] #2762599
04/11/20 09:01 AM
04/11/20 09:01 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Crown PSC 1000 Parts Cleaner
Available at Tractor Supply if you have one
Re: Parts Cleaner Question [Re: Dave_J] #2762620
04/11/20 10:07 AM
04/11/20 10:07 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Funny you should mention this because a couple gallons of water is not a bad thing as long as its below the pump pickup. Firstly, the water and solvent don't mix so the water settles. Now all the crud settles in water instead of solvent - water is free!. There is no disturbance in the drum to stir things up so the crud stays in the bottom keeping the solvent cleaner. The water raises the level of your solvent thus giving you that much more to work with. It might take a while for the water to settle out of solvent but it would settle quickly if you're using diesel fuel.
You guys using gas of any sort ... what do you heat your shops with ? I wouldn't personally use gas in a shop unless it has electric heat and even then there are many other things that cause sparks - startup on my compressor, sparks from grinders, the welder, etc, etc.
Re: Parts Cleaner Question [Re: elmor353] #2762622
04/11/20 10:18 AM
04/11/20 10:18 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You can still get true Stoddard solvent? Between the VOC concerns and the toxicity I didn't think you could still get it.
Re: Parts Cleaner Question [Re: 6PakBee] #2762653
04/11/20 11:42 AM
04/11/20 11:42 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Back during the 1970's gas shortage (with gas lines, limited availability, and different days depending on your license plate number) I worked for a place that sold Stoddard Solvent. For my DD, I poured five gallons in my gas tank and added a like amount of ordinary gasoline. It smelled different out the tail pipe than straight gasoline, kinda sweet smelling, but it burned well when mixed, and at that time was cheaper than gasoline. Lately I to have seen it at what I consider to be an exorbitant price.
Re: Parts Cleaner Question [Re: John Brown] #2762700
04/11/20 01:16 PM
04/11/20 01:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I use kerosene in my tank. I mix oil and kerosene to burn so this way I just change out my dirty stuff more often.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Parts Cleaner Question [Re: elmor353] #2762792
04/11/20 06:00 PM
04/11/20 06:00 PM
Nope, Shell Sol 360 now up
Re: Parts Cleaner Question [Re: 6PakBee] #2762811
04/11/20 06:49 PM
04/11/20 06:49 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I was getting it from my local oil company. It said Stoddard Solvent on the buckets. Used to be $55 for 5gals. Last I looked , it was $70. I don't mind the smell of diesel.
Re: Parts Cleaner Question [Re: Cab_Burge] #2762839
04/11/20 08:14 PM
04/11/20 08:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
couldn't find it online shruggy Do you have a source and price ?? beer
Re: Parts Cleaner Question [Re: TJP] #2762884
04/11/20 10:30 PM
04/11/20 10:30 PM
Local Standard oil petroleum distributor up, $8.40 a gallon is what I'm remembering several months ago.
I buy five gallons at a time and use it as needed in my garden sprayer to clean parts in my solvent tank as the final cleaning before air drying and hitting it again with spray on brake cleaner and air again wrench
Re: Parts Cleaner Question [Re: Cab_Burge] #2763187
04/12/20 08:33 PM
04/12/20 08:33 PM
blewbyu Offline
blewbyu  Offline
I am in the parts washer business. I work for a large Chemical manufacture that makes the product for washers. This product has no Dot Haz label, it is over 145 Degree flash point and works great. It last 4 time longer then mineral spirits and does not evaporate like mineral spirits. It cost a little more then mineral spirits but works and last longer. Here is a brochure of the product. If anyone needs some drop me a PM
Attached PDF document
turbo brochure.pdf (44 downloads)
