Exhaust manifolds and angle plug?! #2761311
04/07/20 11:18 PM
04/07/20 11:18 PM
junction city oregon
V
viperblue72 Offline OP
V
My buddy acquired a 67 dart with 440 and factory a-body manifolds. Does anyone know if angle plugs work with them? He wants to run trick flows. He aware of the power losses but I can’t talk him out of it. He wants 500hp so I’m gonna aim for 550+ and cross my fingers I can talk him into headers eventually. Even tti shortys would be a big improvement.
Re: Exhaust manifolds and angle plug?! [Re: viperblue72] #2761543
04/08/20 03:44 PM
04/08/20 03:44 PM
V
V
If anybody has this answer I’d love to know, although I think I have him talked into buying a set of tti 1 3/4 shortys.
Re: Exhaust manifolds and angle plug?! [Re: viperblue72] #2761584
04/08/20 05:02 PM
04/08/20 05:02 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
I ran an angled plug head with manifolds for a single season and after the aggravation of frying plug boots paid to have a set of custom headers made. Can't remember the style of logs though - they weren't anything special.
Andy had successful stroker build utilizing ported alloy heads and HP manifolds: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2441142/1.html
Depending on the goals of the build your friend might want to have a look.
Re: Exhaust manifolds and angle plug?! [Re: MarkZ] #2761587
04/08/20 05:05 PM
04/08/20 05:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
use the straight plug edelbrocks. probably won't be much if any power difference with the manifolds.
Re: Exhaust manifolds and angle plug?! [Re: lewtot184] #2761596
04/08/20 05:16 PM
04/08/20 05:16 PM
V
V
I agree although we are going to be building a separate short block and bolting all this onto a low comp 440 for now.
TrickFlow are best bang for the buck and leave room for more later. I don’t like the quality of Edelbrock these days. By the time we had them worked and proper springs installed may as well have gotten the trickflows. We are also starting out with a hydraulic roller
that’s custom ground for a low comp 440. It’s 230/239 .520/.540 on 112lsa. Along with new heads and 1 3/4 shortys. I’d think it’ll make 450 with 8 to 1. Yes I did the math and even with 78cc chamber it’s still low. The car is an absolute turd currently. It barely breaks the tires loose.
Re: Exhaust manifolds and angle plug?! [Re: viperblue72] #2761742
04/08/20 10:10 PM
04/08/20 10:10 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Has he considered selling those manifolds? If they are original 440 A-body manifolds they are very rare and expensive. Even the 383 A-body ones are not cheap.
Then he could buy whatever headers work with the angle plugs... twocents
Re: Exhaust manifolds and angle plug?! [Re: DrCharles] #2761771
04/09/20 12:24 AM
04/09/20 12:24 AM
V
V
This is what I told him. I don’t know what they’re worth but I know they’re valuable.
Re: Exhaust manifolds and angle plug?! [Re: viperblue72] #2761783
04/09/20 01:49 AM
04/09/20 01:49 AM
You know that 440 motors weren't available in production A body until 1969, correct?
Which means that those manifolds may be 383 and not 440 confused scope
Look at the casting numbers and casting dates on them to see what they came on originally, I have heard of some guys using some of the early C body manifolds to put a 440 in some of the early A bodies confused
I bought a set of 1967 383 A body manifolds for my 1969 Dart GTS H code 4 speed car several years back to get rid of the low hanging Hooker fenderwell headers. I may be in the market for a set of 1969 383 exhaust manifolds, cash or trade work grin
Re: Exhaust manifolds and angle plug?! [Re: Cab_Burge] #2761853
04/09/20 11:15 AM
04/09/20 11:15 AM
V
V
I don’t have the numbers off them yet but they’re definitely a-body. They neck way down around the steering column.
Can, I’ll let you know first.
Re: Exhaust manifolds and angle plug?! [Re: viperblue72] #2761875
04/09/20 11:53 AM
04/09/20 11:53 AM
V
V
After looking at casting dates I believe somebody put standard hp manifolds in a-body somehow. I didn’t even know this could be done.
2843992-2 driver side. Although I don’t know what the -2 is for.
2806900 passenger side
Re: Exhaust manifolds and angle plug?! [Re: viperblue72] #2762025
04/09/20 07:28 PM
04/09/20 07:28 PM
pennsylvania
poboyengineering Offline
pennsylvania
I used standard HP manifolds on my 69 Dart, 383. I had elephant ears, so it fell where it needed to to clear, and it was tight around the steering column.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Exhaust manifolds and angle plug?! [Re: poboyengineering] #2762330
04/10/20 01:58 PM
04/10/20 01:58 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
If they are original factory A body manifolds, they may not fit. Also the drivers side is very restrictive. B body HP manifolds fit fine as long as you trim back the steering column. Andy F did it, take a look. http://www.moparts.org/Tech/Archive/bb/550hp.html ask him if there were any mods
