69 charger 383 pulley diagram? #2761217
04/07/20 06:39 PM
04/07/20 06:39 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Does anyone know where i can find pictures and/or diagrams of the pulleys on a 69 charger 383 with power steering and no a/c. Trying to help a friend. Thanks guys.
The car is all rigged with washers everywhere. Trying to make it look orginial.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 69 charger 383 pulley diagram? [Re: stickman] #2761285
04/07/20 10:08 PM
04/07/20 10:08 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
This is all I could find in my factory 69 b-body manual.
Appears to be for all engines. This is listed in the cooling section of the manual.
Good luck!
Here's a link just in case:
https://imgur.com/a/oniurqk
Re: 69 charger 383 pulley diagram? [Re: stickman] #2761558
04/08/20 04:19 PM
04/08/20 04:19 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Two belts, double pulley on the bottom. Water pump and alternator on one and power steering on the other
