NE 1 use soft compound slicks ???????????? #276080
04/03/09 04:37 PM
04/03/09 04:37 PM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
Im going to order a set of 30 x 10.5 Hoosier soft compound slics they are DO5 soft compound.
I talked to the tech dude at hoosier and he said they are designed to " dead hook "
Sounds perfect to me
anyone switch to a soft compound and like the results ?
Anyone not like them any drawbacks?
Im not really concerned about getting a bunch of passes on them. I just want to get a dead hook
should I run a tube?
tech at Hoosier said i would not have to
Should I have them spun balanced or do you guys just mount them up and go racing?
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276081
04/03/09 05:24 PM
04/03/09 05:24 PM
PA
moparacer Offline
moparacer  Offline
PA
If you are over powering the compound the 05s will get a grainy look like its peeling the tread off of them.
Had them on my dragster, didnt work....Had them on door cars a few times, didnt work.....
Most of the time the 07s are the best choice IMO.....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: NE 1 use soft compound slicks ???????????? [Re: moparacer] #276082
04/03/09 05:30 PM
04/03/09 05:30 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Your too fast to dead hook Rick, you need to be up on the tire. But a big 'ol dead hook wheelie photo would be nice. Heck you've already got one in your sig.
Re: NE 1 use soft compound slicks ???????????? [Re: ProSport] #276083
04/03/09 05:37 PM
04/03/09 05:37 PM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
Can you tell me more what didnt work?
Did they spin or what elaborate please.
What wrong with a dead hook
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276084
04/03/09 05:54 PM
04/03/09 05:54 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I don't think there's anything wrong with a dead hook for us, I think it's just the super fast cars that need to be up on the tire.
Rick what's the tread width on that Hoosier? I've been looking at tires. Bondo loves the QTP but they only show a 27" tall tire with a 10.5 tread.
My M/T has a 10.5 tread, the Phoenix PH374 has a 10.8 tread, the Hoosier 18192 has an 11.10 tread .
I just wonder if some of these new true 10.5 classes will allow the bigger tread widths even though they say 10.5 on the sidewall.
Re: NE 1 use soft compound slicks ???????????? [Re: ProSport] #276085
04/03/09 05:59 PM
04/03/09 05:59 PM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
Here is the tire Bob
18205D05....30 x 10.5 x 15
tread 10.5
rim 10
section 13.1
Dia 94
This is almost the exact same size as the mickey that we run right now Bob.
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276086
04/03/09 06:51 PM
04/03/09 06:51 PM
tread 10.5
rim 10
section 13.1
Dia 94
You need to go to a 12" rim..That will help a ton..
Re: NE 1 use soft compound slicks ???????????? #276087
04/03/09 09:14 PM
04/03/09 09:14 PM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
Thanks for the info Poppa J
I been thinking the same thing. I do have three piece wheels and I could send them back and get the rear shells that are 2" wider.
I just cant believe that not one person has tried or has experiece with a soft compound slick
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276088
04/03/09 09:24 PM
04/03/09 09:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
they don't last long..
Re: NE 1 use soft compound slicks ???????????? [Re: Quicktree] #276089
04/03/09 09:29 PM
04/03/09 09:29 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
That is what I run on my car same size. have for 4 years now..don't do killer burn out..no need..I get 250-300 runs out of them. and I run 14-15 psi in them..on a 10" rim
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276090
04/03/09 09:39 PM
04/03/09 09:39 PM
NC
440Jim Offline
440Jim  Offline
NC
Rick,
I haven't run a soft compound, but I have heard they are great in spring/fall, but on the hot summer day races (sun), they spin if you have the power.
When I went from 12" wide rims to 14" wide rims (13.6" tread slicks), it was the best thing I ever did for hook and tire life. It allowed me to run more air pressure and it wore the tire more evenly, so it must have been more even contact. So, the idea of you going from 10" to 12" (or even 11" if they make it), has merit.
Re: NE 1 use soft compound slicks ???????????? [Re: 440Jim] #276091
04/03/09 10:18 PM
04/03/09 10:18 PM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
Thanks guys for the input....... NE 1 else
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276092
04/03/09 10:28 PM
04/03/09 10:28 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I have to agree , at least on Our Dart,but we have 14x32's . When we first went to the soft Hoosiers from M/T's at norwalk c.c.(sept.) a couple years ago ,it picked it up a 1/2 tenth, but in the heat it tends to spin. I want to try a set of Goodyears?
Re: NE 1 use soft compound slicks ???????????? [Re: Lil Wedge] #276093
04/03/09 10:43 PM
04/03/09 10:43 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I don't see why you would want to dead hook, wheel speed is very important, just some combinations benefit from more than others. It's not something you'll see with the naked eye in most cases, hence why data loggers are equipped to measure it.
There was quite a decent discussion about this in a post a month or so back, it might be worth searching for, I just wish I could remember what the post was about originally.
AL...
Alan Jones
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276094
04/03/09 11:00 PM
04/03/09 11:00 PM
Real soft compound slicks are usually for very light cars like altereds or front engined rails. We like the Hoosier radial 10.5x30 slicks, they are a softer compound but you run 20-22 lbs. of pressure in them. They go away in 60-70 passes. I would bet with the wider rims and some suspension adjusting your car would respond like you would not believe.You want the tires to spin a half revolution on the launch. John and Ben Holt would be the ones to talk to about this..You are going to their T&T on the 11th right???
Re: NE 1 use soft compound slicks ???????????? #276095
04/04/09 08:05 AM
04/04/09 08:05 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
If you are a ET chaser .you might want a little tire spin..if you are a bracket racer..you want dead hook...consistent
Re: NE 1 use soft compound slicks ???????????? [Re: VernMotor] #276096
04/04/09 08:30 AM
04/04/09 08:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Even with controlled tire spin you can still have
constancy... but it has to be controlled tire spin
and checking the tire pressure each round is a must.
I dont use the "soft" compounds and get a good 60'
Re: NE 1 use soft compound slicks ???????????? [Re: VernMotor] #276097
04/04/09 08:41 AM
04/04/09 08:41 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Rick, I have tried the DO-5 and all the other Hoosier compounds.The DO-5 was the worse one for my car.I have the 11 compound now and it hooks the best of all of them.I was talked into these by the guy I buy mine from and he was right.I use a 29x10.5 tire with 94 circ now but have had from 92 to 96 on the car and from 10.1 to 13.6 on the car at one time or another.The only thing I would go to next would be a radial.I use a tube and more air pressure in the harder compounds,which tends to give more wheel speed,use less shock in the rear,but have to tighten the fronts as it will go up extreemly high on a low setting.Hope this helps.Stock suspension Cal Tracs and change slicks often.
Re: NE 1 use soft compound slicks ???????????? [Re: VernMotor] #276098
04/04/09 08:52 AM
04/04/09 08:52 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You never ever ever want a dead hook!!!!
Take video of cars with the white stripe painted on the tire. Or if you know someone deadly consistant that you feel is doing everything right paint the stripe on their tire, if they will let you, and video their car leaving. If you go to slow motion, when watching the video, you will see the tire is not dead hooking.
On the rare occassion a car dead hooks, unless the converter is way loose then it bogs the converter, it bogs the motor. With a Data recorder you can see this in driveshaft and engine speed data. Sure you don't need the tire speed of a large tire tube chassis car, but you do need to spin the tire enough to force it to flatten the contact patch of the tire out to the racing surface. If you try and dead hook a tire there are several results that may happen depending on the size tire and how much power and weight you have.
One compress the tire so much the center of the tread lifts off the racing surface. If it stays compresses you are draging off performance running on a flat tire. If it spins the tire and gets on the tire you are not dead hooking.
Two run so much pressure you are already up on top of the tire. Either you dead hook it bogs the motor or the converter or it spins because the contact patch it too small. When you spin is the cituation it just keeps on spinning because the tire balloons and you run on a smaller patch wearing out the center of your tread.
Idealy paint a stripe and video the car. You want to spin the tire just enough so that white stripe never turns into a blur leaving the starting line. If the tire spins too fast the white stripe because impossible to follow. You want to see a very quick half to two full rotations of the slick, depending on the car, at the release of the brake. Then watch the stripe as the slick is now hooked up until the car is going to fast to see it.
As far as a car suddenly standing up that usually doesn't. This comes from dead hooking. What happens is the engine bogs loosing the power necessary to spin tire accellerating the car and the car just stands up. The tell tale of this is the the car falls out of the wheelstand quicker.
Re: NE 1 use soft compound slicks ???????????? [Re: 340RICK] #276099
04/04/09 09:20 AM
04/04/09 09:20 AM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
I switched from MT slicks to Goodyear soft compund tires. They are a stiff sidewall, D4B compound.(10.5 X 30) The car went from spinning hard,to eating oil pans! I need to find a compromise, get it up on the tire, and just black track a little. Have fun!
