Re: Fuel Pump ? [Re: NITROUSN] #2761074
04/07/20 11:36 AM
04/07/20 11:36 AM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Originally Posted by NITROUSN
Outlet fitting Outlet
Inlet if 5/16 hose Inlet
Thank you sir!!
Now while wait for them I will try and figure out how to that damn nut out so I can change the pump rod..... GRRRRR
What part number pump are you using?
M6903
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Fuel Pump ? [Re: JMCFAN] #2761101
04/07/20 01:07 PM
04/07/20 01:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The M6903 is what I figured. I see other mis-information on thread size. They are both 1/4 npt and the two references I made to the fittings are correct.
Re: Fuel Pump ? [Re: NITROUSN] #2761116
04/07/20 01:46 PM
04/07/20 01:46 PM
New Mexico
New Mexico
Thanks because I ordered last night and they already shipped! smile
Re: Fuel Pump ? [Re: JMCFAN] #2761280
04/07/20 09:57 PM
04/07/20 09:57 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
With all due respect,I use Teflon tape all the time too, just not when the instructions say not to. #2 non hardening Permatex seems to do the trick.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Fuel Pump ? [Re: JMCFAN] #2761292
04/07/20 10:20 PM
04/07/20 10:20 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Any good hardware store should have brass fittings.
If not Grainger has always been my go-to.
If there isn't a Grainger nearby (they are considered a essential business) then try summit or jegs.
If their customer service is still working they should be able to hook you up. Just give them the make and part number of the of the pump.
Good luck!
cc.
Re: Fuel Pump ? [Re: cb1289] #2761293
04/07/20 10:22 PM
04/07/20 10:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yep. Me too for the last 30+ years........
