Re: degree cam [Re: pittsburghracer] #2764718
04/16/20 06:09 PM
04/16/20 06:09 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted by pittsburghracer
Originally Posted by RapidRobert
^^^ it says fits gm/furd lifter .842"/.875" bores. I'm assuming it expands enough to fit ours
This one fits Mopars.
https://www.summitracing.com/parts/pro-66843
Does anyone know of one of these that fits a .937 lifter bore?
I have tried one of the Proform "universal" checkers and it does not fit well.
Thanks!
Re: degree cam [Re: 340Cuda] #2764753
04/16/20 07:03 PM
04/16/20 07:03 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have one of the proform universal checkers, you have to expand it to its maximum but it has worked well for me. expand it slowly and rock it a little, until it gets tight in the lifter bore.
I am just so used to, that everything is built to fit a Chevy, and you have to fiddle with it for a Mopar.
Re: degree cam [Re: jwb123] #2764941
04/17/20 09:59 AM
04/17/20 09:59 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
On my bushed R3 block if the checker is loose enough go in its very wobbly at the bottom with no way to tighten it up.
Re: degree cam [Re: 340Cuda] #2764982
04/17/20 11:10 AM
04/17/20 11:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Made my own 25 years ago for solid lifter and roller.Home made piston stop for when the head is on up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: degree cam [Re: pittsburghracer] #2765380
04/18/20 09:46 AM
04/18/20 09:46 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
where did you get that long extension on the top. mine didnt come with that.im using mine on a world alum. block and the guage hits the block so i have to turn it away from me to make it work.it still works great just a bit of a pain.
Does that fit in a small block with the dial indicator on it???? Seems like it’s awful long and the indicator would hit the block.
Yep it works great on small blocks. I just did my new 408 a few weeks ago
