Need some natural gas piping help. *UPDATE* #2760271
04/05/20 08:53 AM
04/05/20 08:53 AM
Guitar Jones Offline OP
I have some 1" OD plastic natural gas pipe I need to replace. I would like to splice it in to the existing pipe under the house as I really don't want to have to dig all that up. Since I really don't want to go to the Home Depot I'd like to order it on line and have it delivered but I'm not sure exactly what I should buy. Any and all help would be appreciated. I have a few pics of the existing pipe so you can get an idea of what I'm dealing with.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760276
04/05/20 08:56 AM
04/05/20 08:56 AM
Maybe just for now I can splice the pipe together for whatever that is under the tape but I can also see where the pipe is cracking where it makes that bend out of the connection going in to the ground.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760303
04/05/20 10:00 AM
04/05/20 10:00 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
We just had an underground propane tank installed, here's a pic of a splice and the info decal on it. Not sure where this stuff is sourced, the contractor that did the job provided it. Hope this helps.
Edit- this PN# is actually for 1" pipe so it should work. Seems like it's readily available everywhere, costs seem to range anywhere between $40-$50.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Need some natural gas piping help. [Re: RMCHRGR] #2760330
04/05/20 11:21 AM
04/05/20 11:21 AM
New Jersey
Dartforforty Offline
New Jersey
All under ground plastic gas poly pipe requires a special anode less end to attach to above ground.
They have threaded ends to adapt to metal piping.
I have repaired the orange gas poly you have using the fitting pictured above.
The picture you posted of the gas poly connecting to the metal pipe above ground is un-safe and not up to standards of the National Gas Code
Re: Need some natural gas piping help. [Re: Dartforforty] #2760341
04/05/20 11:37 AM
04/05/20 11:37 AM
Thanks guys.
Yeah I figured that connection wasn't up to standards so I would like to fix that as well. There is another connection like that going into some metal pipe that goes into the laundry room outside the house. It is real close to the ground so I don't know how deep that poly pipe is buried.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760475
04/05/20 06:03 PM
04/05/20 06:03 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Gas piping is at about 5 PSI or less but still I would want a good splice and not cheap car heater hose clamps. Too many stories of houses blown up in a 2 block diameter from a gas leak.
Good luck. Soapy water is your friend in working on this.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Need some natural gas piping help. [Re: Dave_J] #2760489
04/05/20 06:52 PM
04/05/20 06:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Paying a licensed plumber to do this work is probably worthwhile.
He knows what he's doing, he has the tools and parts to fix it to code and knows how to check it for leaks. When I had my gas line from the meter to the house replaced they got it done, had the inspector over to verify the leak check, and no it isn't soapy water, and did it all legal and proper in less than one day. Whomever had been working on your lines is obviously not qualified.
So if my house blows up due to a gas leak my insurance will have to pay and not be able to claim unlicensed repair.
Re: Need some natural gas piping help. [Re: Sniper] #2760498
04/05/20 07:17 PM
04/05/20 07:17 PM
Makes sense. I just know codes are pretty lax or nonexistent here. There are no building codes in this county. The pipe that comes from the well is the same poly tube (larger diameter though) that is just laid across the ground and down the mountain. I haven't ventured up the mountain yet to take a look though. Air is a little thin around here and I'm already short of breath.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760511
04/05/20 08:02 PM
04/05/20 08:02 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Living in the country has a lot of benefits, but sometimes you find out the drawbacks. I know enough about gas to know I don't know enough to mess with it. Mine is all metal piping, and it was easier for me to pay the plumber to dig up the old stuff and put in new as I had recently had a triple bypass and it was the middle of summer, no way I was digging 50ft of pipe out of the ground in 100+ temps. Well, not if I wanted to survive it, lol.
Re: Need some natural gas piping help. [Re: Sniper] #2760518
04/05/20 08:19 PM
04/05/20 08:19 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Not being harsh, but this is the home you had inspector problems with and they let it fly like that?
You might try as I did, I had my local gas company run 250 of the proper line and correct ends and to code and the cost wasnt too crazy.
STOP POTATO HATE!
Re: Need some natural gas piping help. [Re: Mr PotatoHead] #2760523
04/05/20 08:33 PM
04/05/20 08:33 PM
Yep same place but nothing was ever said about the gas lines, just the foundation. I don't recall seeing the tape on the gas line before we bought it but it took so long for the deal to go through who knows what happened and we didn't get a final walk through either. Oh well, we still would have bought the place though because we love it here so much and nothing else came close to what we wanted.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760526
04/05/20 08:47 PM
04/05/20 08:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would join those that tell you to get a qualified installer to install the new stuff. I have to wonder if such a person exists in your area. Maybe a call to whomever supplies your gas can direct you towards someone that is qualified. The money you spend to fix this issue correctly is probably a very small part of the expense a failure of that gas line might cost. After all, you are sleeping there, right? Gene
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760529
04/05/20 08:53 PM
04/05/20 08:53 PM
Superfreak
Superfreak
I would get a gas contractor in to give you a quote to have the work done to code. The fact that your local government may be lax and not care what you do, your insurance company will see things differently
if something else were too happen and they see the gas line not up to code.
Re: Need some natural gas piping help. [Re: ] #2760533
04/05/20 08:59 PM
04/05/20 08:59 PM
I got the names of three contractors but they may or may not do this kind of work. Either way it will get fixed even if I have to do it myself.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760646
04/06/20 09:14 AM
04/06/20 09:14 AM
New Jersey
New Jersey
First off the gas poly pipe is not by code allowed to be layed on top of the ground. It is for direct bury use. When you come out of the ground you need to use the special metal ends to make a connection to the house pipe or appliance you are feeding.
So if you had this pipe exposed at the time of your inspection your inspector was very lax in doing his job.
That kind of work would get you a big failure sticker upon inspection here in New Jersey.
Ed
Licensed New Jersey Master Plumber
Re: Need some natural gas piping help. [Re: Dartforforty] #2760654
04/06/20 09:48 AM
04/06/20 09:48 AM
Yeah but I believe the rules if any are different here as the gas company has this stuff just laying on the ground in many places, not just here. Might even be nearly impossible to bury it in some spots.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760680
04/06/20 10:47 AM
04/06/20 10:47 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Failing code requirements, the rules you should follow are the ones the manufacturer sets for it's product. UV exposure is probably an issue at the least. Not to mention a trip hazard, mowing over it, animals chewing on it, lot's of issues to consider. Your existing line probably has a date code on it somewhere, if you find it then you can make an educated guess how long it's been in use and you already know it's leaking.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760698
04/06/20 11:23 AM
04/06/20 11:23 AM
New Jersey
New Jersey
Are the large gas mains laying on top of the ground also?
Hillbilly Hacking is no excuse for putting the public in harms way
So I guess the gas company by you can ignore the National fuel gas code also.
They use poly for gas for ease of installation, metal pipe would be safer on top of the ground, but then the gas company would have to actually work
You use a flow mole to install small gas lines and dig where needed
Directional drilling is another method
We had a gas line explosion up here in New Jersey by me a few years back
It leveled the house and almost killed 3 gas company workers
Re: Need some natural gas piping help. [Re: Sniper] #2760699
04/06/20 11:26 AM
04/06/20 11:26 AM
I was actually surprised this pipe doesn't have an inner lining. The handyman that replumbed the water lines said it's ok being exposed as long as the bend is gentle. What do I know? I haven't even seen a gas appliance since I was 18.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760735
04/06/20 12:41 PM
04/06/20 12:41 PM
New Jersey
New Jersey
The Key word being Handyman, He is NOT LICENSED
The National Standard Plumbing Code states you must be licensed to work with potable water lines and waste pipe lines
So I would say your handyman is not licensed to do plumbing let alone give his opinion how to properly install a gas line
