disc brakes #2760281
04/05/20 09:12 AM
04/05/20 09:12 AM
s.d.
K
kermit1 Offline OP
kermit1  Offline OP
K
s.d.
Does anyone know why disc brake E and B body cars have 10 inch rear drums and not 11inch.im using 1970 as my example.also has anyone tried switching to 11 inch and what where the results.thanks.
Re: disc brakes [Re: kermit1] #2760285
04/05/20 09:24 AM
04/05/20 09:24 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
My brother thought he would upgrade his Challenger to 11" rear and then had to add a proportioning valve because the rear brakes were to aggressive.
1969 Hemi Roadrunner 2nd owner
Re: disc brakes [Re: 69hemibeep] #2760396
04/05/20 02:31 PM
04/05/20 02:31 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
The trans am cars have rear 11’ brakes. I’ve had my rear brakes lock up under hard braking on my AAR. That’s not good.
Re: disc brakes [Re: kermit1] #2760404
04/05/20 02:51 PM
04/05/20 02:51 PM
AndyF Offline
AndyF  Offline
Put the 11.75 rotors up front and then put the 11 inch rear drums out back. You'll notice the difference. I had that setup on my early B body and it felt like you hit quicksand when you stood on the brakes. The car just dropped down and stopped.
Re: disc brakes [Re: fastmark] #2760473
04/05/20 05:57 PM
04/05/20 05:57 PM
s.d.
K
kermit1 Offline OP
kermit1  Offline OP
K
s.d.
thanks fastmark thats interesting that the factory used 11 inch rear brakes on the t/a cars.i had assumed up until now front disc could only be had with 10 inch rear.
Re: disc brakes [Re: kermit1] #2760962
04/07/20 12:31 AM
04/07/20 12:31 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
For what its worth, those 11" rear drums (finned) are very heavy in mass weight vs the non-finned 10" small drums.
