Fuel Pump ? #2760418
04/05/20 03:37 PM
04/05/20 03:37 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I purchased the Carter FP from a member here to replace to POS Auto Zone one on my 68 Charger ( 383). Looks like I need some fittings... anyone now what and where I can order?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Fuel Pump ? [Re: JMCFAN] #2760450
04/05/20 05:09 PM
04/05/20 05:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
those fittings are available at any hardware store. Just take the pump with you and match them up.
Re: Fuel Pump ? [Re: JMCFAN] #2760452
04/05/20 05:22 PM
04/05/20 05:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Which pump are you going to use? Left, or right?
Re: Fuel Pump ? [Re: JMCFAN] #2760454
04/05/20 05:29 PM
04/05/20 05:29 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It's been a lot of years since I retrofitted the "Hemi" pump. IIRC, the pump uses NPT fittings, for the supply you'll need the appropriate NPT to 5/16" female flare nut adapter. The fuel return is much easier, NPT to 1/4" barbed fitting. I'm sorry I don't recall the sizes for sure, I "think" they're 3/8" NPT?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Fuel Pump ? [Re: 71birdJ68] #2760463
04/05/20 05:40 PM
04/05/20 05:40 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Right. Carter
Re: Fuel Pump ? [Re: JMCFAN] #2760486
04/05/20 06:39 PM
04/05/20 06:39 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
pump on the right uses 1/4" pipe thread fittings. easy to find at NAPA, CARQUEST, etc.
Re: Fuel Pump ? [Re: lewtot184] #2760497
04/05/20 07:15 PM
04/05/20 07:15 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks!! hope they are open.... frown
Re: Fuel Pump ? [Re: lewtot184] #2760770
04/06/20 02:36 PM
04/06/20 02:36 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
No luck at Napa.
Re: Fuel Pump ? [Re: JMCFAN] #2760788
04/06/20 03:44 PM
04/06/20 03:44 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
The Carter high volume mechanical race pump I bought maybe fifteen years ago had straight thread (not tapered pipe) in the pump inlet and outlet, and came with fittings that used copper gaskets to seal them to the pump body. My pump came with two different styles of fittings, one set that adapted to AN lines, and another set to use with inverted flare lines. My pump looked a lot like the pump you show on the right.
Re: Fuel Pump ? [Re: John Brown] #2760796
04/06/20 04:06 PM
04/06/20 04:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Outlet fitting Outlet
Inlet if 5/16 hose Inlet
Re: Fuel Pump ? [Re: NITROUSN] #2760806
04/06/20 04:28 PM
04/06/20 04:28 PM
Those are the same type, not the Jegs brand, fitting I use on those fuel pumps when using the stock steel lines and hoses up
I buy them at the local auto part stores scope
Re: Fuel Pump ? [Re: NITROUSN] #2760808
04/06/20 04:31 PM
04/06/20 04:31 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thank you sir!!
Now while wait for them I will try and figure out how to that damn nut out so I can change the pump rod..... GRRRRR
Re: Fuel Pump ? [Re: JMCFAN] #2760914
04/06/20 09:44 PM
04/06/20 09:44 PM
Are you talking about unscrewing the pipe plug that is under the fuel pump mounting boss?
If so you need the proper size allen head wrench or socket scope
Re: Fuel Pump ? [Re: JMCFAN] #2760924
04/06/20 10:15 PM
04/06/20 10:15 PM
California
Tomkcuda Offline
Tomkcuda  Offline
California
No luck at Napa.
Try Ace Hardware.. they will have what you need.
Re: Fuel Pump ? [Re: JMCFAN] #2760940
04/06/20 11:18 PM
04/06/20 11:18 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
I think this is what you need on the outlet to the carb: Weatherhead (Eaton) 202X5. Straight Adapter - 1/8 in Male Pipe Rigid x 5/16 inch Female Inverted Flare.
Please Note: I have edited this post. The information above is incorrect. The Weatherhead (Eaton) 202X5 pictured below IS NOT correct for a Carter M6903. It is correct for a Carter M4845.
David
Re: Fuel Pump ? [Re: Cab_Burge] #2761036
04/07/20 10:03 AM
04/07/20 10:03 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Yes...and its slightly striped.... frown
Re: Fuel Pump ? [Re: JMCFAN] #2761054
04/07/20 10:50 AM
04/07/20 10:50 AM
NJ
cb1289 Offline
cb1289  Offline
NJ
If you have the directions that came with the pump, read them carefully. The aluminum castings can crack easily if you use Teflon tape when installing your fittings to the pump body. Teflon tape is a no no. Seal them another way and don't overtighten.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Fuel Pump ? [Re: cb1289] #2761056
04/07/20 10:55 AM
04/07/20 10:55 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks! No instructions in the box.... what do you use in place of teflon tape?
Re: Fuel Pump ? [Re: JMCFAN] #2761071
04/07/20 11:26 AM
04/07/20 11:26 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Teflon is not a problem I use it all the time. Leave the first thread exposed and wrap it tight with no more than two wraps. You can use a paste sealant also. If your cracking pumps you must be tightening them like a Gorilla.
Re: Fuel Pump ? [Re: JMCFAN] #2761072
04/07/20 11:28 AM
04/07/20 11:28 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Thank you sir!!
What part number pump are you using?
