Re: Need some natural gas piping help. [Re: Dartforforty] #2760741
04/06/20 12:54 PM
04/06/20 12:54 PM
Guitar Jones Offline OP
Originally Posted by Dartforforty
Originally Posted by Guitar Jones
I was actually surprised this pipe doesn't have an inner lining. The handyman that replumbed the water lines said it's ok being exposed as long as the bend is gentle. What do I know? I haven't even seen a gas appliance since I was 18.
The Key word being Handyman, He is NOT LICENSED
The National Standard Plumbing Code states you must be licensed to work with potable water lines and waste pipe lines
So I would say your handyman is not licensed to do plumbing let alone give his opinion how to properly install a gas line
He is a retired city engineer so... And again, I know there are no building codes in this county.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2760761
04/06/20 02:02 PM
04/06/20 02:02 PM
New Jersey
Dartforforty Offline
New Jersey
Being an engineer doesn't make him a plumber
I don't dispute his credentials as an engineer
A handy man is just that, one day he is a painter, next a roofer...…. A jack of all trades and master of none
I went to school, did my apprenticeship and took a test to get a plumbers license
Plus here in Jersey we do a 7 hour class every two years to review the codes and renew our licenses
When I purchased my property in Virginia I went to the town hall and got a book on building codes.
Basically it said they would approve any construction project that followed the manufacturers guide lines of installation
On a final note I am glad I don't live in a state where they allow a ticking time bomb with an endless fuel source to lay in wait
Re: Need some natural gas piping help. [Re: Dartforforty] #2760778
04/06/20 02:58 PM
04/06/20 02:58 PM
Well yeah but they have allowed the state to be a toxic dumping ground for C8, and WV hasn't blown up yet. laugh2
Thanks for the insight, I appreciate it.
Re: Need some natural gas piping help. [Re: Guitar Jones] #2765401
04/18/20 10:17 AM
04/18/20 10:17 AM
So here is what I did to repair the lines. There is metal pipe in the ground from that manifold that has the poly attached with hose clamps. I was a little concerned about that but after looking under the house I see every connection of the poly pipe to metal fittings is done the same way so, I guess there isn't any use in worrying about that one connection. There was a split in the poly pipe under all that tape so I have a 100 foot roll of it and will probably try to redo and sort all this out this summer. At least I got the worst of it taken care of for now. Thanks to everyone for the help!
