Re: 8-3/4" Ring & Pinion Noise - w/Pattern Pictures [Re: cudaman1969] #2760933
04/06/20 10:49 PM
04/06/20 10:49 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Originally Posted by cudaman1969
I’d look at the pinion bearings,
I agree,on/off throttle noise could be a loose pinion or bad bearing.A pinion race could have not been fully seated at install causing the pinon gear become loose after run-in.
Re: 8-3/4" Ring & Pinion Noise - w/Pattern Pictures [Re: RTSrunner] #2760944
04/06/20 11:25 PM
04/06/20 11:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Easy to check by dropping the shaft and shaking the yoke, checking turning torque with the axles out. Typically when that does happen, it makes a lot of noise.
Quote
Years ago I ran all the way up to 5:13's on the street without any noticeable noise. But that was 40+ years ago
As with many things, they don't make 'em like they used to.
Re: 8-3/4" Ring & Pinion Noise - w/Pattern Pictures [Re: CMcAllister] #2761006
04/07/20 08:36 AM
04/07/20 08:36 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I would increase the back-lash a tad.
