Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: CSK] #2759032
04/02/20 05:33 PM
04/02/20 05:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
As far as I can tell from the ones I’ve had in my shop.......the Sidewinder and SM are the same head.
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: fast68plymouth] #2759039
04/02/20 06:11 PM
04/02/20 06:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
so the SM that that they are selling now are NOT like the victor ??
EDIT, looking on Ebay you can fin the Pro Comp Victor copies for sale. nothing like the SM or Sidewinders. the SM's I find have a heart shaped chamber
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: CSK] #2759079
04/02/20 07:14 PM
04/02/20 07:14 PM
So. Burlington, Vt.
So. Burlington, Vt.
Pro Comp is Speedmaster.
They have both the Victor and RPM style heads.
The pics I posted are of the RPM style heads.
These are what is being talked about as being easy to get to 300cfm.
This is the head that’s the same as the Sidewinder head.
SM, Sidewinder, Stealth, ProMaxx, E Street........ those are all direct competitors.
The Victor style heads flow over 300 ootb, and frankly....... in my mind aren’t really part of the conversation when one is looking for “budget” heads.
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: GY3] #2759091
04/02/20 07:40 PM
04/02/20 07:40 PM
Cab_Burge Offline OP
I would have been disappointed with those results with those parts tsk
Did they tune it at all or just run it like assembled to break it in?
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: fast68plymouth] #2759102
04/02/20 07:55 PM
04/02/20 07:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I looked on Speedmasters web site & all I could find was the Victor copies, Thanks for the clarification Dwayne.
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: CSK] #2759190
04/02/20 11:39 PM
04/02/20 11:39 PM
Summit sells both types of both brands scope
I'm going to advise my customer on which ones I would use but let him make the final decision work
I may buy a set of the M.W port side if they make them with standard rocker arm oiling instead of pushrod oiling they show for those size heads on Summit site work
I'll call Speed Master, Pro Comp, direct to find out scope
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: CSK] #2759304
04/03/20 09:15 AM
04/03/20 09:15 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I would call Marsh Performance. I got a smoking deal on a 400-15 Indy tunnel ram from them the other day. Indy and Hughes could not even get close.
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: mopar dave] #2759310
04/03/20 09:23 AM
04/03/20 09:23 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
so you guys r saying the sidewinder heads r better than the trickflow heads
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: one bad fish] #2759326
04/03/20 09:50 AM
04/03/20 09:50 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
From what i'm told the Trick flows are the best out of the box. The others can be made to work well with some investment. You have to look at the price of the recommended rocker arm for the head as well. Rocker arms for the Trick flows are more affordable. If I ever did it again, I would go for the TF270. Sounds like a lot less head aches and hidden cost with that head.
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: mopar dave] #2759331
04/03/20 09:53 AM
04/03/20 09:53 AM
bronx n.y
O
O
bronx n.y
dont they use regular style rockers
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: one bad fish] #2759379
04/03/20 10:51 AM
04/03/20 10:51 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I believe they do, that's why the rockers are more affordable. I have the victor heads which take an offset intake rocker resulting in a very expensive rocker set ($1100).
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: mopar dave] #2759394
04/03/20 11:07 AM
04/03/20 11:07 AM
bronx n.y
O
O
bronx n.y
but trickflows take regular ?
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: one bad fish] #2759401
04/03/20 11:21 AM
04/03/20 11:21 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Small block heads here but to bad you missed Speedmasters 40% off Black Friday sale. I bought two bare heads for 219.00 each shipped to my house. Everything they handle was 40% off.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: pittsburghracer] #2759404
04/03/20 11:27 AM
04/03/20 11:27 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
too bad speedmaster doesn't have any 210cc big block heads, they haven't for a while now. I've been checking hoping to see some sort of 30-40% off sale so I could get some bare castings...
Re: Are Speed Master and Pro Max BB aluminum heads any good? [Re: krautrock] #2759409
04/03/20 11:32 AM
04/03/20 11:32 AM
bronx n.y
O
O
bronx n.y
i dont know what to buy lol
