Re: Horrendous fuel mileage [Re: DrCharles] #2758588
04/01/20 07:54 PM
04/01/20 07:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Originally Posted by DrCharles
Originally Posted by fourgearsavoy
Sounds about right to me shruggy My Savoy with a 493 ,620 cam and 3,54 gears, 1050 QF carb. gets about 40 miles on 15 gallons of fuel just normal driving with a couple of full throttle blasts. It really drinks the fuel on 100 MPH blasts.
Gus beer
40/15 = 2.7 mpg eek
So I am in the ballpark, at least for the "too much is just right" crowd.
Oh well, I didn't build this toy for economy up but I may need to get a bigger fuel cell!
Yeah my wife always tell me "every time you drive that car it costs you $50 " shruggy Norwalk Raceway is about 45 miles from my house and the gauge is below E when I get there drive
Going to put some 3.23 gears in the Dana and put an 800 Thunder series AVS carb on and see if I can get 50 miles out of a tank.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Horrendous fuel mileage [Re: fourgearsavoy] #2758592
04/01/20 08:08 PM
04/01/20 08:08 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
big block, big cam, double pumper..... geez what do you expect?
Re: Horrendous fuel mileage [Re: volaredon] #2758601
04/01/20 08:24 PM
04/01/20 08:24 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
From my original post:
Quote
I suppose I shouldn't be surprised because big cams are not known for economy, but still...
Since I got 8 to 15 mpg from a mild 383 with 3.23 gears, I figured 6 to 10 with this one.
Well, I'd like to get 10 mpg on the highway at a steady 60, since I already know it cruises nicely at 15-15.5 AFR there. We shall see wink
Re: Horrendous fuel mileage [Re: DrCharles] #2758632
04/01/20 09:38 PM
04/01/20 09:38 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Quote
An overdrive would change your world.
Spinning 451 cubes at 3,000rpm still requires a substantial amount of fuel to obtain 15-15.5 AFR, the shear volume of air you are pumping per minute is substantial.
The amount of fuel you need to run at that rpm is probably what my little Hemi consumes at 100mph in 6th.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Horrendous fuel mileage [Re: GoodysGotaCuda] #2758634
04/01/20 10:04 PM
04/01/20 10:04 PM
West Plains, MO
West Plains, MO
Well, sure, but I can buy a lot of pump gas for the $5-6k it would cost me to install one whistling
Especially since I'll probably only drive it a few hundred miles a year...
Don't forget that the throttle is mostly closed (14" vacuum) and the VE is way down. It's not like the cfm is anywhere near what it is at WOT work
Quote
Could be, it's a much more efficient and modern engine - although I don't know what body it's in (drag coefficient). My '72 Dart is not quite as aerodynamic as a brick but it's close smile
Re: Horrendous fuel mileage [Re: DrCharles] #2758647
04/01/20 10:37 PM
04/01/20 10:37 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
We've found than an OD is not nearly as much of a fuel saving idea as much as it helps you enjoy the car more than you think you could.
We put a GV in a Lil Red Express, for about $3,000, and my father-in-law couldn't be happier. The fuel savings will never add up on paper, but the pure enjoyment it brings is worth it 10x over. It's much MUCH nicer to just get in an go somewhere, you don't feel the stress though the car as it screams down the road. You can carry on a decent conversation and make it to a reasonable destination without constantly monitoring the fuel gauge.
It depends on your location, but here in Texas we can run 100-150mi round trips at 75-80mph to attend a decent car event, I do not miss the days of running 1:1 904 with 3.91s.
That said, enjoy! I know my Warlock is good for about 250whp and gets about 8mpg, those trucks are barns on wheels...but I do have a a518 OD in the shed for it biggrin
2020 RAM 1500
Re: Horrendous fuel mileage [Re: dOoC] #2758678
04/01/20 11:52 PM
04/01/20 11:52 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Gus beer
40/15 = 2.7 mpg eek
Sounds like WOT mpg on a Hellcat !
Well if the 11 minutes to a tank is right, I figure 1.98 mpg on a demon wide open at 200 mph, hellcat would get better.
Re: Horrendous fuel mileage [Re: DrCharles] #2758682
04/02/20 12:28 AM
04/02/20 12:28 AM
Work on the AFR so you can get from 14.3 to 15.5 AFR at light throttle cruising under 2500 RPM and see how much that improves the gas consumption on the highway when cruising twocents wrench up
I like to see from 12.8 to 13.3 at WOT(full street exhaust system 3.0 pipes to the rear bumper) on our local pump gas with no ethanol in it up
Re: Horrendous fuel mileage [Re: DrCharles] #2759038
04/02/20 06:01 PM
04/02/20 06:01 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Hmmm, my Volare had a 11:1 360 with a way too big cam and a big carb. When I went to the track, I'd put 5 gallons of race gas in it. I could make 3 warm up passes, make 3-4 round passes. Of course for every 1/4 mile pass there was the 1/4 mile back to the pit stall. Roughly 3-4 miles put on it a day. I'd have a small splash of gas left over. So roughly 5 gallons to go 3 miles at 6000 rpm comes out to about .6 mpg.
Could be worse.
