K-FRAME INTERCHANGE #2757985
03/31/20 12:47 PM
03/31/20 12:47 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Asking for a friend, really laugh
70 B body K frame, will this fit in a 75-79 B body car? Most of my peeps say no, differences in aprons? and suspension.
What say y'all?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: K-FRAME INTERCHANGE [Re: Magnumguy] #2757995
03/31/20 12:58 PM
03/31/20 12:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think the K-members changed in 73 on the B-bodies. They went to a rubber insulated K. I doubt an earlier style would bolt up.
Re: K-FRAME INTERCHANGE [Re: burdar] #2757996
03/31/20 01:06 PM
03/31/20 01:06 PM
S.E.Ohio
S.E.Ohio
I thought so. Thanks
Re: K-FRAME INTERCHANGE [Re: Magnumguy] #2757999
03/31/20 01:12 PM
03/31/20 01:12 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
No,it will not fit.I'm sure you are familiar with the '75-9 style K-frames as used on Magnums.The 1970 K frame is much smaller and bolts on the flat area of the frame only. Plus the upper control arm of a '70 is attached to the body/frame rail.The later isolated K frames provide the mounting points for both upper and lower control arms and strut rod as well.
RT
Re: K-FRAME INTERCHANGE [Re: Magnumguy] #2758012
03/31/20 02:10 PM
03/31/20 02:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
pre 72 and post 73 K members are diff monsters.
Aside that, 70/72 are a bit diff from pre 69. Interchanges as a full assembly but sway bar mounts diff, so if you install a 69 K member on a 70, will need to match the 69 sway bar parts as far I know
Then, up to 72 all V8s are same K member but Hemis... and of course /6s are diff from the rest too.
since 73, /6, SB and BB are diff.
Re: K-FRAME INTERCHANGE [Re: NachoRT74] #2758320
04/01/20 10:03 AM
04/01/20 10:03 AM
RWG75
RWG75
The 75-79 B body K frame first appeared in 73 or 74 and I know I pulled one of them for one of my 76s. It was also used in the 80-83 R body NYer, Newport, St. Regis and I transplanted one of those in to my 75. Recently stumbled over this handy reference:
Re: K-FRAME INTERCHANGE [Re: ] #2758345
04/01/20 11:12 AM
04/01/20 11:12 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
66-69
70-72 w/ skid plate option.
73-78
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: K-FRAME INTERCHANGE [Re: moparmarks] #2758531
04/01/20 06:03 PM
04/01/20 06:03 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
69 1/2 are a hybrid.70 on bottom 69 top with 69 sway bar. no skid plate unless its a hemi.
Re: K-FRAME INTERCHANGE [Re: sixbbl 69] #2759339
04/03/20 10:03 AM
04/03/20 10:03 AM
S.E.Ohio
S.E.Ohio
Thanks folks
