I need to replace 4”X 5” pattern axles 8.75 #2758404
04/01/20 01:20 PM
04/01/20 01:20 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Hello everyone,
I need to know what my options are for new axles.
Existing 4”x 5” bolt pattern, 8.75”.
Thank you in advance.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: chagjr] #2758428
04/01/20 02:40 PM
04/01/20 02:40 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Maybe check with Dr. Diff ???? www.doctordiff.com
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: chagjr] #2758566
04/01/20 07:08 PM
04/01/20 07:08 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
$400 for new axles from Dr Diff or send your current axles to Moser engineering and have plugged and redrilled for $90.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: HemiRick] #2758585
04/01/20 07:42 PM
04/01/20 07:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Lots of options: Dr Diff, Strange, Moser, Dutchman, Yukon, even used ones...depends on what you're doing.
You'll also need to know length and bearing type, specific application if going used.
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: HemiRick] #2758662
04/01/20 11:15 PM
04/01/20 11:15 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Stock length DoctorDiff axles run $295 pair, assembled. See below:
https://www.doctordiff.com/axle-pkg-stock-length-mopar-5x4-1-2-bolt-pattern-pair.html
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: DoctorDiff] #2758668
04/01/20 11:30 PM
04/01/20 11:30 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Why is everyone assuming he wants a bolt pattern change? He doesn't say that.
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: Sniper] #2758672
04/01/20 11:34 PM
04/01/20 11:34 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What is wrong with your axles. I am assuming that you are looking for A-body 5 on 4" axles...
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: Jim_Lusk] #2760155
04/04/20 08:38 PM
04/04/20 08:38 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Ordered through Dr Diff.
Thanks Moparts!
Harry
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: Sniper] #2760232
04/05/20 06:00 AM
04/05/20 06:00 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think because the request is somehow confusing? 4"x5"? What doesn't mean that?
It should say 5x4" or 5x4.5"
And maybe that is what it takes to open interpretations
Re: I need to replace 4”X 5” pattern axles 8.75 [Re: NachoRT74] #2760259
04/05/20 08:15 AM
04/05/20 08:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You will need B body backing plates, shoes, and drums as well.
Doug
