easy roll cage paint prep Question
#2757778
03/30/20 09:06 PM
03/30/20 09:06 PM
RapidRobert
fresh bare metal roll cage. I will prep it with wax/grease remover then spray it with some rattle can black enamel that the paint shop recommended. My question is how should I prep the bare metal? steel wool? sandpaper? (what grit) or nothing at all. thank you for your time.
Re: easy roll cage paint prep Question
[Re: RapidRobert]
#2757807
03/30/20 10:11 PM
03/30/20 10:11 PM
Posts: 11,632 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I give it a going over with 120. Wipe it down with acetone. Light coat of self etching primer. Use Krylon 5 ball paint. Depending on what it is, I may do it in sections. You have to be able to keep it all wet to avoid overspray and have it shine.
[Re: CMcAllister]
#2757811
03/30/20 10:23 PM
03/30/20 10:23 PM
RapidRobert
sounds like a plan. thanks bro
[Re: RapidRobert]
#2757887
03/31/20 08:25 AM
03/31/20 08:25 AM
Posts: 1,213 Minn
SportF
Minn
Another thing you could try is the Home Depot Hammered (Rustolem?) enamel finish. Brush strokes disappear, finish looks great and is very durable. If you've never used it before its like a paint you've never put on before. But wear a respirator. I don't know what is in that stuff, but it is volatile.
[Re: SportF]
#2757889
03/31/20 08:35 AM
03/31/20 08:35 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
i would just pour the wax and grease remover on a red scotch brite pad, scrub the roll bar, wipe the bar down again wax and grease 2 times and paint. in the bodyshop where i work i have wax and grease in a sprayer so i spray it directly on the surface then i would scrub with the scotch brite. if i were doing this job myself i would spray it with PPG epoxy primer catalyzed with 401 and spray it out with a prevail spray bomb. and then paint with a single stage paint with the prevail spray gun. ****NOTE prevail spray guns are just like spray bombs. https://preval.com/
perception is 90% of reality
[Re: SportF]
#2757895
03/31/20 09:12 AM
03/31/20 09:12 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Another thing you could try is the Home Depot Hammered (Rustolem?) enamel finish. Brush strokes disappear, finish looks great and is very durable. If you've never used it before its like a paint you've never put on before. But wear a respirator. I don't know what is in that stuff, but it is volatile. THIS.i use the black ,it turns out to be a dark grey but goes good with any color combo.dont get the spray bombs the brush on looks better and holds up great.Surface prep is key,alot of goog advice so far
[Re: dvw]
#2757898
03/31/20 09:19 AM
03/31/20 09:19 AM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
POR-15 satin black in a spray can worked well for me. There is a whole system for it - Marine Clean (wax/grease remover) and Metal Prep (metal etch) that you use before the paint. Painted it right when I got it home from the chassis shop so there was no visible rust. Painting wasn't too bad though putting the panels, carpet and headliner back in was a nightmare.
'71 Duster '72 Challenger '17 Ram 1500
[Re: Neil]
#2757971
03/31/20 12:17 PM
03/31/20 12:17 PM
RapidRobert
Good comprehensive info. thanks guys! It is this years' stock car & at least at this stage I don't have to worry about overspray . Racing is tentatively still on but they are going week by week.
