Re: New spring perches, larger hole size [Re: dvw] #2763045
04/12/20 01:14 PM
04/12/20 01:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Iso spring perches were made with a 1 1/2" center hole.
The MP perch with a 5/8" center hole was originally a Dakota application (3/8" spring center bolt). Installing them on a passenger car 5/16" center bolt is a non-issue because this bolt locates the shock plate, and the shock plate locates the rearend housing via U-bolts tight against both sides of the spring perch.
I carry special 5/16" center bolt spacers, however.
Re: New spring perches, larger hole size [Re: DoctorDiff] #2763129
04/12/20 05:11 PM
04/12/20 05:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ya, I missed the Iso diameter by a ton.
Doug
Re: New spring perches, larger hole size [Re: dvw] #2763176
04/12/20 08:04 PM
04/12/20 08:04 PM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
I purchased a relocation kit in the nineties and it came with the large holes in the perches. we used two drill a 1/2'' hole in a flat plate and fully weld it to the perch. this lowered the car and fixed the large hole problem.
