Re: Need good alignment specs
[Re: sbcjd]
#275648
04/05/09 09:36 PM
04/05/09 09:36 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Would the above alignment specifications you stated be the same for a daily driver with radial tires and no drag strip racing?
I'll set up a daily driver for as much caster as I can get without sacrifcing camber. Camber I like to see at 0 to . 5 deg neg. no more than a 1/2 deg split between camber/caster. Toe I want at .06
[Re: autoxcuda]
#275650
04/05/09 10:28 PM
04/05/09 10:28 PM
Posts: 9,316 SoCal
68HemiB
SoCal
I'm more than a little late to this particular dance, but I aligned cars for a living in a previous life. I cannot speak to alignment specifically targeted at the auto-x crowd. The specifications for Mopar alignment back then tended toward slightly positive camber, and I have not been horribly dissatisfied with 0 to maybe 1/4 degree positive camber to this day. Therefore, you will not find me among those determined for some negative camber action. What I am in favor of is as much balanced, positive caster as possible. Besides getting toe to something reasonable (no more than 1/8" total in), in my mind there is nothing more important than getting the caster really close side-to-side. Anything else is asking for a come-back due to a complaint of pulling. Offset bushings (installed to maximize positive caster, not positive camber) are some additional help in the direction of positive caster before abandoning stock UCAs in favor of tubular numbers. ![](/ubbthreads/images/graemlins/Twocents.gif)
Down to just a blue car now.
[Re: autoxcuda]
#275651
04/05/09 10:36 PM
04/05/09 10:36 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
I always ALWAYS run some negative camber. The $64 question: How much? There's a whole host of factors, some of which are:
> How aggressively is the car driven? (i.e., canyon and entrance-ramp carver?)
> I assume radials (otherwise you might actually want 0° camber), but the aspect ratio is important, the lower the aspect ratio, the less negative you need
> Roll stiffness
> Tire pressure
> Wheel width to tire section width
I have run as much as 2° negative and STILL worn out the outer part of the tread first. But, then, I am an animal.
For most of my street-cruiser type buddies, I recommend 0.5 to 0.75° negative.
I like lots of positve caster but not more than 2.5 to 3 deg. or so. More is better for road racing as long as there are no REALLY long high-speed straights -- excess caster makes the car pretty spooky at very high speeds. Caster is somehow hard for a lot of guys to conceptualize. Picture a line drawn between the center of the ball joints. If this line is viewed from dead-ahead of the car, you're looking at steering axis inclination (not independently adjiustable). Viewed from the side, this same line is caster.
Rick
[Re: 68HemiB]
#275652
04/05/09 10:41 PM
04/05/09 10:41 PM
Posts: 15,493 the boonies
aarcuda
the boonies
as coincidence may have it, i had just checked my 70 service manual and saw they actually called for positive camber (just like you said).
but i can see how negative camber would aid in cornering.
What do you make of the toe numbers i posted? Can I just rotate the tie rod sleeves an equal amount to get it closer to 1/16" or does it need to go back on the rack?
Re: Need good alignment specs*** UPDATE***
[Re: aarcuda]
#275655
04/06/09 07:52 PM
04/06/09 07:52 PM
Posts: 704 USA
rftroy
USA
With all these very high caster numbers, I hope you guys are talking about power steering. The original questioner didn't mention power or manual, but you sure don't want +5 deg caster with manual steering.
I set mine at 0 to +1 for manual. Above (and at) +1, you can really feel the difference and steering gets hard.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#275656
04/06/09 09:20 PM
04/06/09 09:20 PM
Rick_Ehrenberg
Marlboro, NY, USA
...yeah, fast ratio manual and sticky tires. One of the only real forms of exercise I get (the others are even more fun) ;->
+5° caster is crazy. Part of the problem with super-high caster settings is that the vehicle tilts significantly during the caster sweep, actually distorting the camber measurement. It can be almost impossible to prevent a lead (pull) with caster set that high.
Rick
[Re: Twostick]
#275660
04/07/09 10:58 PM
04/07/09 10:58 PM
Posts: 9,316 SoCal
68HemiB
SoCal
Too much caster can cause a violent shake after hitting a big bump at speed ie railroad tracks or potholes. 5 deg might work on a tabletop smooth track but I wouldn't want it on the street.
Kevin
Respectfully, I suggest that this symptom in a car has nothing to do with aggressive caster, and everything to do with the integrity and condition of the front suspension. For high caster numbers, I suggest one look up the factory alignment specs on a 1973 era Monte Carlo. That model exhibited none of the symptoms you attribute to positive caster.
When I was lobbying for the merits of positive caster, it was in the framework of the practical numbers one can get from a stock or near-stock Mopar front end, and in a car with power steering.
In addition to the lack of wandering and return-to-center benefits of positive caster, I also see it as a mechanism to obtain beneficial camber in turns. As I have said before, I am not in the camp of negative static camber fans (because I don't throw my pigs around corners quickly very often). However, positive caster will result in a shift toward negative camber on the outboard side and toward positive camber on the inboard side in a turn. This I find to be something desirable.
[Re: Rick_Ehrenberg]
#275662
07/12/09 10:05 AM
07/12/09 10:05 AM
Challenger 1
Cincinnati, Ohio
> Roll stiffness
> Tire pressure
Rick
Great read, thanks Rick.
[Re: Twostick]
#275663
07/12/09 07:40 PM
07/12/09 07:40 PM
Posts: 6,516 Santa Cruz, California
Lefty
Kevin
I've never heard of that. On 94+ Dodge 4x4 trucks it's the other way around. Not enough positive caster causes death wobble.
[Re: HealthServices]
#275665
07/13/09 12:40 PM
07/13/09 12:40 PM
Posts: 1,164 Los Angeles, CA
JF_Moparts
Los Angeles, CA
This is a great thread and I hope it gets archived.
Here's a few questions:
I just took my manual steering 71 RR to an alighnment shop and they couldn't get the caster/camber settings anywhere near the factory recommended settings. Eventually they did the toe-in and didn't charge me for the effort. The suspension was rebuilt in 1991, but since then only 3000 miles have been put on the car. Could I be looking at misaligned eccentric cam mountings?
Also, with laser alignment equipment that mounts reflectors on the wheels, is there an easy way to access the eccentric cams withthe wheels on? I was in the shop, helping the guys locate and turn the cam bolts, and we had a heck of a time doing it. (Of course it didn't help that the shop doesn't get many vintage mopars and had mostly metric tools. I can forgive the first, but not the second.)
I have an appt to get my power steering 71 Sat aligned this afternoon, and I was planning on going with these specs:
Camber: -0.5 Caster: +3.0 Toe: 1/16
One more question: Does it ever make sense to have different camber settings for left and right? Such as: Left: -0.7 Right: -0.5
Thanks.
[Re: JF_Moparts]
#275666
07/13/09 01:03 PM
07/13/09 01:03 PM
Challenger 1
Cincinnati, Ohio
I reached around the tire with it on, to access the cam bolts. I like your specs, do you have stock upper arms? If so, you might have trouble getting 3+ caster. Mostly metric tools? ![](/ubbthreads/images/graemlins/runaway.gif)
