Page 2 of 3 1 2 3
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: tubtar] #2756276
03/26/20 07:58 PM
03/26/20 07:58 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
WOW, that's a ton of work but a great job!! Keep us posted
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Stroker Scamp] #2756334
03/26/20 10:51 PM
03/26/20 10:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
I totally iagree bow
Your dedication and skill amaze me up bow
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Cab_Burge] #2756677
03/27/20 11:42 PM
03/27/20 11:42 PM
Alberta
440_Offroader Offline
Alberta
I use to go down as a crew member for my friend's 1598cc Hayabusa. He also ran a bike that had two 1250cc GSXR engines in it!?! Oh the stories! Haha. From the 5 times I was down there, it was definitely a cool experience. It can be hot and exhausting, but still a good time. Haven't been down in 8 years, but might make it down again some time. I always loved seeing Mopars there, and yours will be one to watch! Wish you good luck and safe low level flying!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: 440_Offroader] #2756694
03/28/20 01:24 AM
03/28/20 01:24 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks!
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2957253
08/25/21 12:31 PM
08/25/21 12:31 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Okay, so missed it by a year, but finally got my junk to Speed Week 2021! Had a good showing with a 187mph at the 2 1/4 on the short course right out of the trailer, which cleared me for the long course! Stayed on yhe short course for a couple more passes to work out some things, then moved over to the long courses. Lexan windshield caved in a little on a 217mph run, but we fixed that. Made a few mods and went 230.973mph exit speed at the 5 mile after averaging 229+ for mile 5. Stayed in the throttle to the 6 mile and burned a piston, so done for this year. Tires grew considerably which threw final calculated ratio off quite a bit. Also had inlet turbulence and fuel distribution issues that I must address. We will be back next year, class correct and ready to break the record if conditions permit!
217mph run, winshield caves at 53:37, uneventful-
https://youtu.be/QbIa7B70Rak
230.973mph run, other GoPro didn't capture.
https://youtu.be/IFnDxQg_iic
img_2_1629220322101.jpgimg_1_1629220308180.jpgSpeed Week Bonneville 8.21.21 6 resize.jpg
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2957269
08/25/21 12:59 PM
08/25/21 12:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
VERY cool, at least you made it !!!! smile
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: CSK] #2957290
08/25/21 01:49 PM
08/25/21 01:49 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
Awesome, Hope you get the little bugs worked out and you become the new record holder !!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2957338
08/25/21 04:24 PM
08/25/21 04:24 PM
Are they, BNI, going to run again this year like in the past?
I can't believe how long your right foot was on the floor shock I'm not sure I could keep mine down that long work To many 1/8 and 1/4 runs, maybe whistling
How long is the long course now work
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Cab_Burge] #2957350
08/25/21 05:07 PM
08/25/21 05:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What was the terminal rpm on the long course run?
I know it’s hard to really tell from watching a video on the phone, but it sounded like you ran it higher in 3rd than what it would pull in 4th.
It didn’t “sound” like it was super high rpm in 4th.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Cab_Burge] #2957358
08/25/21 05:36 PM
08/25/21 05:36 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Cab,
Long course 1 was graded to 9 miles this year, long course 2 was graded to 8 miles. The short course is 3 miles.
Put it on the calendar for next year, see you there to break the record!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2957432
08/25/21 08:44 PM
08/25/21 08:44 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Very cool build and very successful outing.....I love how your cage allows the use of the stock mirror and you have stock floor boards...Bet the car isn't light. You look comfortable in there and car looks pretty stable at speed. And I think your hood scoop hates you lol....
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Dragula] #2957470
08/25/21 10:25 PM
08/25/21 10:25 PM
Alberta
Alberta
That is awesome for you first time out. I have no doubt, that you'll beat that record. You must have some good weight in the back, to keep them skinny tires from spinning! I know how slippery that salt is! Good luck with your upgrades for next year.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: fast68plymouth] #2957484
08/25/21 11:15 PM
08/25/21 11:15 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Man Dwayne, you are picky!! LoL! I wish you'd have been with me and told me to lift at the 5 mile marker! Would have extended my fun and saved me a couple thousand dollars!
You are correct. The engine seemed to struggle to get to max rpm in 3rd, then stopped accelerating at 6400 in 4th. The rear 28" tires expanded 2 1/2" in diameter which threw my final drive ratio way off. On the dyno (at 860'elevation, don't know the DA) the engine made 135 less hp at 6400 vs 7400 where max hp was attained (which is what 28" tires should have given with this gear at 240 or so), so even at Bonneville DA there is a difference, in this case enough the engine couldn't overcome the aero of the car with the taller tires. I believe fuel distribution and inlet turbulence exaserbated the problem. The a/f on each bank was showing 12.7 up to a point. As the speed increased well above 200mph, the a/f (based on an Innovate Motorsports dual guage) was changing so rapidly I could only see a number occasionally, bouncing between 12.7 and 13.1. The engine made best power at around 13.1 on the dyno...for a few seconds at a time. That was obviously too lean in the spread for the #7 which burned and #6 which had the thermal coating partially burned off but the piston survived. I now know I should've had O2 sensors in all primaries and a way to monitor that on the fly, or I should've kept it richer to keep it alive. That and I should've lifted at the 5 mile marker, or definitely when rpm started to decrease, although I'd guess the damage was already done. Expensive lesson learned, 5 miles was probably plenty for WOT! I had asked the experts when I was building the headers about EGT or O2 sensors in each primary and was told that wasn't needed on a NA engine at this HP level. I wanted to do it before Jet Hot coating if so. I learned the expensive way it is needed and the cost of the system would have paid for itself here!
Solutions- Get the heads and manifold to Wilson's Manifolds to help fuel distribution, work on the scoop for better inlet air, and add a K&N
air filter that will flow enough air to help control the inlet turbulence. If you have any suggestions I am wide open for suggestions. I cannot use computer controlled ignition in this class or fuel injection. There is a low pressure above the scoop I will address, not exactly sure how I will change it to help inlet airflow, but I will change it.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Dragula] #2957488
08/25/21 11:17 PM
08/25/21 11:17 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Dragula, you can't see it but the car has a full headliner! Need to tighten that mirror up! LoL! And yes, I was quite comfy in there, if a little snug!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2957507
08/26/21 12:50 AM
08/26/21 12:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Incredible….. thanks for sharing your experience
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: J_BODY] #2957523
08/26/21 06:36 AM
08/26/21 06:36 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Very cool. Hope to see it in person next year.
69 GTX 68 Road Runner
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: JERICOGTX] #2957533
08/26/21 07:48 AM
08/26/21 07:48 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You are motivated far more than most. I'm sure you will succeed.
Doug
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: dvw] #2957537
08/26/21 08:35 AM
08/26/21 08:35 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Amazing! You guys did a ton of work to get there. Congrats on a successful campaign.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2957556
08/26/21 10:10 AM
08/26/21 10:10 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I saw this car in 1 of Johns videos.He has some great footage.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Clanton] #2957576
08/26/21 11:54 AM
08/26/21 11:54 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Awesome!!! Thanks for sharing!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Page 2 of 3 1 2 3
