94 Dakota v6 to v8 swap (problem) #2749890
03/07/20 02:59 PM
03/07/20 02:59 PM
SW Ohio
AAR-B4 Offline OP
AAR-B4  Offline OP
SW Ohio
Help needed.
Swapped a 97 360 magnum into my 94 v6 Dakota. All is good except one major issue, the engine is about 2 inches too far forward. I do not see a set of holes in the frame crossmember that allows movement of the frame mounts. My research said this would be a simple swap confused
Has anyone encountered this issue??
Re: 94 Dakota v6 to v8 swap (problem) [Re: AAR-B4] #2749914
03/07/20 04:40 PM
03/07/20 04:40 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe check out magnumswap.com and see if they have any tips. work
Re: 94 Dakota v6 to v8 swap (problem) [Re: AAR-B4] #2749964
03/07/20 08:18 PM
03/07/20 08:18 PM
Guitar Jones Offline
The trans mount to crossmember bolts and/or mount bracket should be slotted. None of that changes from a V6 to a V8. Did you use the V6 or V8 engine mounts? The 94 may not be the same as the 97. In other words you may need 94 V8 mounts.
I never learned to count my blessings, I choose instead to live inside my disasters.
The Scamp is sold, now just two old trucks and one new one.
'74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. Magnum 5.2 MPI and NV4500 coming soon.
Re: 94 Dakota v6 to v8 swap (problem) [Re: Guitar Jones] #2749970
03/07/20 08:38 PM
03/07/20 08:38 PM
SW Ohio
AAR-B4 Offline OP
AAR-B4  Offline OP
SW Ohio
Some background, The engine and driveline (97 5.9 , sb 727, drive shaft and 8 3/4) were removed from a 88 single cab short bed using the Shumacher mounts (LA mounts).
Going into 94 3.9 42RH single cab short bed.
Used 94 5.2 mounts (5.9 not available in 94) anchor brand #2652 (same for v6 or v8). Its 2wd, should be easy. When I lowered the motor into the frame it looked too far forward (water pump is too close the radiator for a conventional fan. I went ahead with the trans (727) and its 2 " from reaching the crossmember. The drive shaft is the same amount short.
I'm stumped.........
Re: 94 Dakota v6 to v8 swap (problem) [Re: AAR-B4] #2749989
03/07/20 10:37 PM
03/07/20 10:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just a guess but could the mounts be either on the wrong sides or installed wrong. just wondering because if you don't get the mounts on the right side of the ears on a big block it causes all kinds of grief.
Re: 94 Dakota v6 to v8 swap (problem) [Re: stumpy] #2750000
03/07/20 10:56 PM
03/07/20 10:56 PM
Between Houston & Galveston TX
Satilite73 Offline
Satilite73  Offline
I don't know either so I did a google search and came across this thread on another forum. Maybe has something to do with your problem? shruggy
Linky >> 3.9 to 5.9
John
Imagine a '73 Satellite Wagon picture here. 😁
Re: 94 Dakota v6 to v8 swap (problem) [Re: AAR-B4] #2754633
03/22/20 04:52 PM
03/22/20 04:52 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I have a 91 Dakota sport that was a factory v8 truck. I am using a 2000 5.9 magnum engine and 904 transmission. Unless you will be using the factory overdrive transmission. Shumocker makes a transmission mount adapter for the 3 speed transmission.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 94 Dakota v6 to v8 swap (problem) [Re: mopar65] #2754640
03/22/20 05:02 PM
03/22/20 05:02 PM
mopar65 Offline
mopar65  Offline
Picture of transmission mount
Re: 94 Dakota v6 to v8 swap (problem) [Re: mopar65] #2754643
03/22/20 05:06 PM
03/22/20 05:06 PM
mopar65 Offline
mopar65  Offline
Oops try this one.
Re: 94 Dakota v6 to v8 swap (problem) [Re: mopar65] #2754760
03/22/20 08:59 PM
03/22/20 08:59 PM
Freeport IL USA
P
poorboy Offline
poorboy  Offline
P
Freeport IL USA
I don't know if this is relevant info or not, but I discovered a couple years ago the Dodge used 3 different transmission mounts between 1992 and 1994 Dakotas. The 93 was a changeover year, and neither the 92 nor the 94 will work without modification, and the 93 mounts are no longer available. The truck I ran into this on was a 4x4, but I've heard they did the same thing on the 2x Dakotas.
I had to modify the crossmember to get the 94+ trans mount to work. Maybe you have the wrong crossmember for the mount you are trying to use?
I sure hope you guy get this figured out, I will be putting a 96 318 4x4 drive train on a 91 4x4 chassis soon, and will be covering this with 49 Dodge sheetmetal. I'll have enough to deal with making the sheet metal work, I don't want to have to deal with a motor/trans issue as well, but I will if I need to. Gene.
Re: 94 Dakota v6 to v8 swap (problem) [Re: poorboy] #2754826
03/22/20 11:42 PM
03/22/20 11:42 PM
mopar65 Offline
mopar65  Offline
I cant speak about a 4x4 truck. But my 91 was v8 with a A500 over drive transmission. With the magnum 360 and 904 transmission. Using the adapter mount. My engine/ transmission bolted right in with no problems
Re: 94 Dakota v6 to v8 swap (problem) [Re: mopar65] #2755176
03/23/20 07:29 PM
03/23/20 07:29 PM
SW Ohio
AAR-B4 Offline OP
AAR-B4  Offline OP
SW Ohio
The engine is in.
To recap; it's a 94 2wd v6 Dakota that I am swapping to a 97 5.9 magnum and 727. I had to drill and tap a 1/2" plate for each side to move the motor mount forward about 2" (different for each side). Sandwiched the plate between the block and the mount.
All I can figure is the brackets on the k-frame are different from v6 to v8.
Moral of the story: don't believe anything you read on the net and only half of what you see. Other sites (not this one) said this was a "easy swap" "uses same mounts".
BTW the trans mount used is the one like 2 posts above.
Re: 94 Dakota v6 to v8 swap (problem) [Re: AAR-B4] #2755328
03/24/20 08:19 AM
03/24/20 08:19 AM
Dacula, GA
I_bleed_MOPAR Offline
Dacula, GA
Very strange. All the extra length is forward of the mounts on a V8. Apples and oranges probably but I'm wrapping up my swap of a 5.9 into a 3.9 QC. I used the V6 mounts with the only problem being I had to trim some of the plate off the bottom to clear the oil pan lip. I did have the mounts reversed L to R and they were several inches off. work
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
'00 Dakota QC 5.9 5 spd.
1970 True V-Code 440 Six Pack, 4 speed
by tomsjack. 04/05/20 04:04 AM
Must see movie! Clark Gable racing at Indy
by Hemi_Joel. 04/05/20 02:30 AM
Hemi block engine mount
by hemienvy. 04/05/20 01:38 AM
1969 GTX convert 4 speed project wiw
by MI Mopar Works. 04/05/20 12:06 AM
Moparts Recent Posts
Best place for 1972 Dodge Charger carpet?
by migsBIG. 04/05/20 03:22 AM
Pushrod length Q?
by HOTMOPR. 04/05/20 02:45 AM
50 year Ang. 426 challenger
by Runner2go. 04/05/20 02:31 AM
