NP833 O.D. problems, who has had them #2754608
03/22/20 03:50 PM
03/22/20 03:50 PM
Cab_Burge Offline OP
I've been putting together a street car, 1966 Dodge Coronet Deluxe 2 door sedan that I installed a NP833 tranny, 440 motor and a cut down Dana 60 with 3.55 gears in it.
I took the tranny completely apart to inspect it as I bought it out of a local towing and scrap yard, I didn't find any real problems in it but I was amazed on how small the O.D. gear is on the cluster shaft. work
My questions are who has had problems with them or broken one on the street? help What problems did you have and do you know what parts broke?
Thanks: Cab
Re: NP833 O.D. problems, who has had them [Re: Cab_Burge] #2754682
03/22/20 06:36 PM
03/22/20 06:36 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Cab there are some guys that have them in street cars that hold up fine unless you whoop on it with good traction. The gears do look pretty wimpy even compared to 23 spline gears. I would put one in a easy driving B-body and even if you do break it parts are plentiful and cheap shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: NP833 O.D. problems, who has had them [Re: Cab_Burge] #2754697
03/22/20 06:53 PM
03/22/20 06:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have installed several of them in our dinosaurs over the years and have had good luck with them. But they won't take a beating. As long as there is limited traction and not much gear banging, they work real well with deeper gear ratios. With taller rear gears, the tranny's gear spread starts to show up.
Master, again and still
Re: NP833 O.D. problems, who has had them [Re: DaveRS23] #2754706
03/22/20 07:10 PM
03/22/20 07:10 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
I put one in this, behind a nice 360 and in front of 3.55 gears but it didn't stand up to towing duty very long.
Re: NP833 O.D. problems, who has had them [Re: 1E2C] #2754761
03/22/20 09:01 PM
03/22/20 09:01 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The real problem is wear on the countershaft, as it uses thrust washers, not tapered bearings, and has no center support between input and output shaft, like a modern trans, so they get loose with big power or towing in overdrive. Use gear oil, change it often, don't beat on it in overdrive, and it will last a long time. Start with new thrust washers, bearings, needles, countershaft pin, and shim any excess endplay out of the cluster gear and run it. Just remember it was designed for a light 6cyl car so.... one last thing, check the ends of the cluster, may be worn from thrust, or wiped washers and metal.
Re: NP833 O.D. problems, who has had them [Re: 4406bbl] #2754778
03/22/20 09:51 PM
03/22/20 09:51 PM
VA
dragon slayer Offline
VA
I guess it depends,there are a few in 426 Hemi street cars in my neighborhood and a few in 440 6 pack cars used for street and cruising, and they hold up pretty well. They are put in cast cases though. Did one for my car from a Truck version, though it is not installed yet.
Re: NP833 O.D. problems, who has had them [Re: 4406bbl] #2754798
03/22/20 10:41 PM
03/22/20 10:41 PM
When you say countershaft are you saying the cluster gear shaft or the output shaft?
Re: NP833 O.D. problems, who has had them [Re: Cab_Burge] #2754813
03/22/20 11:09 PM
03/22/20 11:09 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The shaft or pin inside the cluster gear, it gets grooves in it where needles ride, end of cluster also gets wear on some.
Re: NP833 O.D. problems, who has had them [Re: Cab_Burge] #2754815
03/22/20 11:12 PM
03/22/20 11:12 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
i had hemi 4sp changed 3 years ago . never looked back.
Re: NP833 O.D. problems, who has had them [Re: 4406bbl] #2754817
03/22/20 11:18 PM
03/22/20 11:18 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You are bringing up a lot of bad memories cab, you should also check the front of the case where the countershaft pin rides, if it has a flat plug there it has a floating pin, you might want to bush that and make the pin tight. I think the cast iron overdrives were not floating pin, could be wrong, been a while.
Re: NP833 O.D. problems, who has had them [Re: 4406bbl] #2754835
03/23/20 12:45 AM
03/23/20 12:45 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
I've seen 2 of them from behind Slant 6's that looked like a grenade went off inside them. I personally would never use one!
Re: NP833 O.D. problems, who has had them [Re: lemondana] #2754885
03/23/20 08:55 AM
03/23/20 08:55 AM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
i was going to say that i use a Passon 4sp overdrive.
Re: NP833 O.D. problems, who has had them [Re: lemondana] #2754893
03/23/20 09:10 AM
03/23/20 09:10 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The OP asked for experiences. And he has gotten enough and they have been consistent enough to draw a reasonable conclusion. But an expressed opinion without that experience is really just a guess. And not a good source for advice.
Re: NP833 O.D. problems, who has had them [Re: DaveRS23] #2754897
03/23/20 09:20 AM
03/23/20 09:20 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I had one in a '77 Volare with the 318 that I bought brand new. The comment about being a PITA with deep rear end gears is correct. IIRC, the rear end was a 3.21 limited slip and you were in 1st gear only long enough to say you had been there. After I had about 40,000 miles on it, it developed a nasty trick of sticking in fourth gear if you hit it hard. Never did discover what was happening. Went through the shifter linkage adjustment and a side cover inspection but never discovered the cause. I really like the car though. If I was younger I'd probably be looking for a Roadrunner version.
Re: NP833 O.D. problems, who has had them [Re: 6PakBee] #2754908
03/23/20 09:37 AM
03/23/20 09:37 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I had a 77 Aspen RT with the 318 and the 833 OD. That car got beat on pretty well and the trans held up until it had 95,000 miles and then it got stuck in second or third gear. My dad took it into his machine shop at work and they corrected whatever was wrong with it without buying parts.
I recently had a guy tell me he had one in a 440 Challenger that would lift the left front tire and it lived in that application.
I've got one to put in my 73 Cuda and as long as I can live with the ratio spread I'll keep it. I can't afford a Passon or Magnum swap.
Re: NP833 O.D. problems, who has had them [Re: gzig5] #2754999
03/23/20 12:45 PM
03/23/20 12:45 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I have one in my 47 desoto with a roller 318 w/ cross ram 2x4 and has 323 rear gears. I rebuilt the trans when built the car. I didn’t see anything wrong with it inside and it hasn’t given me any trouble. The gear spread doesn’t bother me at all but I’m not racing it either, it’s just a fun cruiser.
Re: NP833 O.D. problems, who has had them [Re: gzig5] #2755000
03/23/20 12:50 PM
03/23/20 12:50 PM
VA
VA
The aluminum case OD do have the floating cluster shaft and wear easier. Cast Iron case do not have a floating shaft. First gear is a very low gear at 3.09, hence no need to even use it with a big block. The only real difference if put in a cast case, is the main shaft is thinner for at least one of the gears. So if anything was going to break it would that in my opinion. This is not a setup for track car, but inexpensive option for a cruise OD car.
I have a 383 4 spd B body that has a dana with 3.54. The motor trans are stock set up. I hardly use first gear even with a stock 383/4 spd.
With the over drive, I would expect it to be two speed with overdrive. But if you wanted to pull a cool hole shot in first gear, what a ratio with a 3.54..... laugh
Re: NP833 O.D. problems, who has had them [Re: dragon slayer] #2755039
03/23/20 02:05 PM
03/23/20 02:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Teaching my son to drive in a 51 Plymouth with a three on the tree.
Going to put in an A833OD I have on the shelf, that 3.09 first gear will really help him taking off, lol.
I don't pull hole shots or tow so the A833OD works fine for me, I probably have close to 200k miles on the two I have.
As for the aluminum case counter shaft hole issue, it can be bushed to fix that. I believe both Passon and Brewer's offer that service or did.
https://www.hotrod.com/articles/mopp-0110-a-833-aluminum-case-buildup/
Re: NP833 O.D. problems, who has had them [Re: lemondana] #2755262
03/23/20 11:02 PM
03/23/20 11:02 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I would have to see that with my own eyes to believe it. rolleyes
Mo' Farts
Moderated by "tbagger".
Re: NP833 O.D. problems, who has had them [Re: Grizzly] #2755263
03/23/20 11:15 PM
03/23/20 11:15 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Not everyone knows how to shift properly... shruggy
