Re: NP833 O.D. problems, who has had them
[Re: DrCharles]
#2755402
03/24/20 11:36 AM
03/24/20 11:36 AM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Years ago, a buddy put one in his hemi 4spd Bird, along with 8 3/4 rear end . . . he drove it that way for YEARS !!! Yes, he kept the original parts, but wanted to drive his car, all over !! Was cool to see real hemi 4spd Bird out on the highways !! . . . I had a 76 Road Runner, original non touched car, 57k miles on it when I got it. 318 with 4spd OD . . . had Passon rebuild the tranny, mainly for the leaking seals, but hey, might as well get it totally looked after. It was cast case, but drove that car all over, and put 21k miles on it ! Ran great, 23mpg all day long at 70mph ! . . . totally cool RR with the superpak option (all the spoilers, window louvers and stripes) . . .
[Re: A990]
#2756414
03/27/20 09:24 AM
03/27/20 09:24 AM
Posts: 1,321 VA
dragon slayer
VA
Decided to go back an examine in more detail the part difference. Picture of the OD(gears on) and normal Main shaft (no gears). Basically the 2 shaft are identical from the flange back towards the tail. Same size, same hub and slider for 1st and second gear.
What is smaller is the front of the shaft because the new 3rd gear for overdrive is now the smaller OD 4th gear. That small gear required a reduction in shaft diameter. Smaller hub too. Regardless, the shaft is not the issue anyway. The weak link would be the teeth on the shaft and hub that transmit the torque. The teeth on the hub and gears that lock in place when the slider engages. So where things are smaller is direct drive (3rd) and OD (4th). But no where near any limit that you would break the hub, or gear, let alone a main shaft.
The cluster is the same. So if you move this into a cast case, or have OD with cast case you have a transmission just as strong as any other 23 spline.
If you compared it to a slick shift Hemi, it may even be stronger then that. While hemi had a bigger input shaft, the back end is the same as 23 spline other that bushed gears and bigger bearings. Slick shift removed every other engagement tooth on the gear and hub from 36 to 18. That actually weakened the gears. Requiring more frequent repairs, until liberty made their mod with longer and wider teeth.
Aluminum cases are a whole other thing though. As discussed the floating counter shaft and weaker aluminum case could round out causing reduced gear mesh, riding tip of tooth to tip of tooth, with greater back lash, that just gets progressively worse if abused.
When I did this conversion a few years ago, I used later model big bearing cast cases, and over drives from truck set ups that had the longer B/E body shaft and tails.
You could do the same with an A body, but need the A body OD.
[Re: MoonshineMattK]
#2757195
03/29/20 12:26 PM
03/29/20 12:26 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
I have OD guts in an iron case in my 68 Charger/440 engine. Did the swap over 10 years ago but not tons of miles on it. (with 4.10 gears the miles are more pleasant) At the time I rebuilt the trans the reading I'd done said the aluminum case allowed the countershaft to move away from the mainshaft and that's what did the damage. The article I read talked about machining the aluminum case to spread the load. Its been a really long time and I cant remember the details. In an iron case with street tires and reasonable driving I wouldn't worry about it. This article goes through the steps of bushing the aluminum case counter-shaft holes. Not a terrible job if you have a mill. No idea how much a shop would charge you but figure a couple hours on the mill and the lathe work to turn up the bushings. I plan to do this to the one I have. https://www.hotrod.com/articles/mopp-0110-a-833-aluminum-case-buildup/Does anyone know how much weight is saved by the aluminum case?
