Re: a dumb question but curious
[Re: ohiodemon]
#2754329
03/21/20 09:10 PM
03/21/20 09:10 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Heard they fit the Chevy Chevelle SS 396 chasses good.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2754337
03/21/20 09:37 PM
03/21/20 09:37 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
The only guy that did is in jail for Meth possession... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
...FAFO...
[Re: Cab_Burge]
#2754384
03/22/20 12:44 AM
03/22/20 12:44 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I do not think that would be a good thing to do or attempt. How many small block Chrysler were built and still being built. People would rather swap a Gen 3 Hemi with wiring harness and all other parts to make it run like a new vehicle. But I know of a few that have swapped an SRT4 Turbo into a Fox Body Mustang making it a rear wheel drive. None of these Brand X changes I would do.
1971 HEMI E BODY REGISTRY
[Re: ohiodemon]
#2754390
03/22/20 01:16 AM
03/22/20 01:16 AM
Posts: 1,757 Phila
PhillyRag
Phila
has anyone ever swapped a 351 based ford engine into an a-body duster/demon ? Seems plausible if you had a nicely worked up one already w/trans. And if you were replacing a worn/beaten 318, 6-cyl, or a smog 360. Would love to see the looks on the Mopar Crazys faces at a show
[Re: ohiodemon]
#2754395
03/22/20 02:40 AM
03/22/20 02:40 AM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
has anyone ever swapped a 351 based ford engine into an a-body duster/demon ? Only a moron with a very limited scope of common sense and intellect.
[Re: ohiodemon]
#2754433
03/22/20 09:19 AM
03/22/20 09:19 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
lol, the motor i have is a 420 cid stroker windsor dyno'd at 787 hp. so its a no joke engine trans is a g force 101a. body is a 71 duster very straight and very clean. just thinking. probably too much trouble. i disagree with the neg comments about this swap. doing this swap is what old time hot rodding is all about. making what you have fast with what you have available to you. i say GO FOR IT. after saying that, it won't be a easy swap and you won't get much help doing it. so be prepared before you start.
perception is 90% of reality
[Re: ohiodemon]
#2754446
03/22/20 10:08 AM
03/22/20 10:08 AM
Posts: 12,298 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Ford engines in our Mopars?!?!?! What's next? Ford 9" rears in our Mopars?
Master, again and still
[Re: BDW]
#2754453
03/22/20 10:25 AM
03/22/20 10:25 AM
Posts: 6,330 nowhere
Sniper
nowhere
This is where some 3D modeling software would really tell the story. If someone develops engines models, it would be easy to “drop it in” and see where the issues are. Lol It's called a tape measure and it's already done. The 351w is 1/2" wider, 4" shorter and essentially the same height. ![[Linked Image]](https://www.rx7club.com/attachments/v-8-powered-rx-7s-299/125848d1123680885-ford-lincoln-4-6-dohc-engine-specs.jpg)
[Re: DaveRS23]
#2754475
03/22/20 11:28 AM
03/22/20 11:28 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Ford engines in our Mopars?!?!?! What's next? Ford 9" rears in our Mopars? Exactly ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I would round out the swap with a 9" Ford type rear with ZERO factory parts used and then you would have a bulletproof drive train with that G-force box and the track proven stroker Ford engine. Wrap all that up in a Duster with a 4-link and you have a very nice consistent drag car. Go for it man ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DaveRS23]
#2754476
03/22/20 11:28 AM
03/22/20 11:28 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Ford engines in our Mopars?!?!?! What's next? Ford 9" rears in our Mopars? Mopars in Vzla use to get their K member and suspension replaced by the GM half chassis and suspension system ( Novas and Caprice ). I also have seen Ford axles and 350 engines on them... so yes, it can be worst.
[Re: NachoRT74]
#2754508
03/22/20 12:09 PM
03/22/20 12:09 PM
fast68plymouth
So. Burlington, Vt.
I’d probably chose to just make life easier for myself.
If I “had” to use that motor, I’d find a Ford product to put it in.
There are several Ford bodies I like well enough to use.
