Too hot #8 on 440-6 #2754138
03/21/20 11:58 AM
03/21/20 11:58 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
My buddy just installed a freshly rebuilt 70 440 HP in his charger. 6 pack, MSD ignition, headers. It runs well. But #8 is having an issue. The top of the #8 header tube is getting cherry red. So hot it melted the spark plug boot. #6 is plenty hot too but not quite as bad. What could be happening here? Thanks for the thoughts.
1970 Dodge Challenger T/A
Re: Too hot #8 on 440-6 [Re: jeff968] #2754148
03/21/20 12:14 PM
03/21/20 12:14 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Likely a vacuum leak at the intake at the #8 intake port. Hot = lean.
Re: Too hot #8 on 440-6 [Re: Jim_Lusk] #2754152
03/21/20 12:21 PM
03/21/20 12:21 PM
iagree scope
Re: Too hot #8 on 440-6 [Re: Jim_Lusk] #2754300
03/21/20 07:49 PM
03/21/20 07:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree x3
Could be a gasket/ port sealing issue, or possibly a crack in the intake, but something appears to be leaning out that cyl. and possibly #6 as well. twocents beer
Re: Too hot #8 on 440-6 [Re: TJP] #2754323
03/21/20 08:52 PM
03/21/20 08:52 PM
A727Tflite Offline
A727Tflite  Offline
You dont say how hot 6 is but first thing I would check is the vacuum fitting connection at the back of the manifold.
Check the hose for cracks and see if it is attached on the other end.
That fitting leads right in to the #8 port entry.
Re: Too hot #8 on 440-6 [Re: A727Tflite] #2754414
03/22/20 08:04 AM
03/22/20 08:04 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
use a temp gun,to see how hot,but sounds like a vaccum leak
Re: Too hot #8 on 440-6 [Re: dart games] #2754994
03/23/20 12:37 PM
03/23/20 12:37 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Thanks guys for the suggestions. Much appreciated.
Re: Too hot #8 on 440-6 [Re: jeff968] #2755180
03/23/20 07:36 PM
03/23/20 07:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
keep us posted on the fix beer
