You asked for "high detail" response which I can not provide, but here is a DIY home-garage spray can approach I've taken on the last couple of full engine builds and multiple remove, clean, re-do, re-finish and install parts.
1) PRIMER - Plasti-Kote #228 Grey Primer
2) COLOUR - Plasti-Kote #232 Chrysler Blue
So far (about 10 yrs of sumer driving and winter hibernation - short-block assembly, the heads have come off a couple of times) there are no peels, the colour is still vibrant.
I will be using the same approach on my current W2 stroker build.
