Page 2 of 4 1 2 3 4
Re: 440 six pack idle help [Re: Tomkcuda] #2752151
03/15/20 02:02 PM
03/15/20 02:02 PM
italy
antonellomopar Offline
italy
I would install the idle solenoid, as in original six pack cars.
Re: 440 six pack idle help [Re: Tomkcuda] #2752152
03/15/20 02:08 PM
03/15/20 02:08 PM
What list # are your carbs? I'll look them up in my Holley master parts catalog and give you he stock jetting for the center carb and the part number for the outboard mixture plates and hole stock hole sizes, hopefully.
Me thinks someone may have mess with them before you got them work
On the power valve the vacuum rating shouldn't have any affect on the idle unless you have the idle speed screw adjusted up far enough to make the center carb idle on the transition circuit, you can check that by removing the center carb and flip it over after draining the gas out of it and see how far the throttle blades are opened in relation to the rectangular slot in the front center of the carb throttle plate scope if you can see any of the slot below the throttle plates it is to far open and idling on the transition circuit tsk
I check the power valves by removing them and then use my mouth and tongue to suck on them and make my tongue seal against the center hole, if the valve stays closed with my tongue on it is good, if it doesn't stay closed it is bad scope A ruptured power valve will make it idle rich all the time due to leaking fuel into the carb.
I use a vacuum gauge to check the idle vacuum and install a power valve that is one to two inches lower in vacuum, if it idles above 8.0 inches I use the 6.5 rated valves thumbs If it idles at 5.0 inches in gear like my old pump gas stroker motor did I would use either a 3.5 or 2.5 thumbs
I used both in it and it work the same, not so on the 4.5 tsk
Do you have a pin vise and a good small (.011 to .060) set of drill bits? If so use the drill bits to see what size the bleed holes are on your carbs, the center ones are the idle bleeds and outboard ones are the high speed bleeds scope Post them on here and I'll look up which size they where stock , if I can find them in my catalog luck
I've owned, tuned and driven a bunch of stock 340 and 440 six pack cars with the stock carbs, they would idle great and drive okay with the stock jetting and so on. You can make those motors run a lot better by proper jetting and tuning wrench up
Open the outboards idle mixture screws to 1/2 turn and the center to 2 full turns out from bottom and then use the center carb mixture screws to get it to run as lean as you can when warmed up and set the speed idle at or below 1000 RPM so the center throttle plates are not opening up to the transition circuits wrench scope
It is snowing here, hopefully it will not snow after tomorrow, we need the water but it is mid March work
Good luck on this, you can fix it thumbs
Re: 440 six pack idle help [Re: Cab_Burge] #2752154
03/15/20 02:15 PM
03/15/20 02:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I wonder if you have correct base gaskets under the carbs? especially the center carb.
Re: 440 six pack idle help [Re: Tomkcuda] #2752161
03/15/20 02:29 PM
03/15/20 02:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
Just issues of engine stall when choke is wide open at idle
That tells me you are very lean and most likely a bad vacuum leak or an internal carb problem.
Re: 440 six pack idle help [Re: Cab_Burge] #2752169
03/15/20 02:46 PM
03/15/20 02:46 PM
California
Tomkcuda Offline OP
Tomkcuda  Offline OP
California
center carb is 4375 outer carbs, front 4382 and rear 4383. I dont have the listing numbers as hard to read. Far as the base plate is concerned front base plate has been messed with as it was redrilled with new inserts to fit the screws. It was stripped and had to be drilled out. The hole is bigger than rear carbs and needle sticks out much further. I figure this one is easier to adjust since it's in the front. New base plate have been tough to find.
Re: 440 six pack idle help [Re: NITROUSN] #2752171
03/15/20 02:51 PM
03/15/20 02:51 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Your picture of the right side show the vacuum port for the rear carb booster is open. All three carbs need to have the vacuum ports connected through a T fitting. It looks like you have the center and front carb connected with a hose and nothing to the rear carb. They all three need to be connected together.
Re: 440 six pack idle help [Re: Tomkcuda] #2752187
03/15/20 03:43 PM
03/15/20 03:43 PM
California
Tomkcuda Offline OP
Tomkcuda  Offline OP
California
Hi
center carb diameter is 1/16 air bleed hole, outer 3/64
Re: 440 six pack idle help [Re: GODSCOUNTRY340] #2752190
03/15/20 03:48 PM
03/15/20 03:48 PM
California
Tomkcuda Offline OP
Tomkcuda  Offline OP
California
they are all connected correctly. What you see is a vacuum hose that goes into the choke pull off disengaged so the flap stays closed.. I put a screw in it to stop it from air leak.
Re: 440 six pack idle help [Re: Tomkcuda] #2752192
03/15/20 03:50 PM
03/15/20 03:50 PM
California
Tomkcuda Offline OP
Tomkcuda  Offline OP
California
my bad.. I see what you mean but still no difference.
Re: 440 six pack idle help [Re: Tomkcuda] #2752202
03/15/20 04:09 PM
03/15/20 04:09 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Here is what happened to me this past summer coming home from Carlisle. My six pack worked great on the highway but when i was almost home and had to stop the car didn,t want to stay running. After taking the center carb apart I found that there is a little ball that is held in place with a little brass strip in the accelerator pump housing which fell out. Put the little ball back in and laid the little strip in place and repined the little ears that hold it in and now run's like a champ. Like someone said it might be something little!!!!
Re: 440 six pack idle help [Re: Tomkcuda] #2752208
03/15/20 04:14 PM
03/15/20 04:14 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you mean the idle screws were drilled out it may be a problem, but as long as the engine dies when you turn the screw in all the way you should be able to get it to run. The idle screws in 6bbl baseplates are not the same as the regular metering block idle screws. Baseplate screws have longer thinner needles.
Re: 440 six pack idle help [Re: Tomkcuda] #2752313
03/15/20 08:08 PM
03/15/20 08:08 PM
The center carb. came with Holley #63 jets in it, the 4382 outboard carb should have a Holley part # 34r-6153-34 metering plate in it and it should have had a .052 fuel inlet size in the bottom of that metering plate, the other carb # 4383 should have had a r34-8153-35 plate number in it with a .071 fuel inlet size hole on the bottom of it.
I have heard a lot of people on here say that drilling those holes out to.086 works good shruggy
My set of original six pack 1970 carbs like #63 jets in the center carb and .096 air bleed jets in the one side and .092 size air bleeds in the other. Those plates had the original holes plug off and where drilled out and tap to use Holley screw in air bleeds. that set up worked real well boogie Once I got the fuel system straighten out with the proper size pre fuel pump fuel filter size it didn't want any richer jetting than it had up
I did try richening up the out board carbs jet sizes by .004 and it slowed down, I didn't try leaning it down though realcrazy
All the stock six pack center carbs I worked on didn't like a lot more jet size in them, maybe one or two sizes up or down, no more than that though tsk
Take a look at your outboard carbs. metering plate numbers, both of them and post it on here to see if they are stock or been change like the center carb jets have been work wrenchscope
Make sure that the fuel feed holes(channels) for the power valve haven't been plug off also scope
Let us know what you find thumbs
Re: 440 six pack idle help [Re: Cab_Burge] #2752355
03/15/20 09:53 PM
03/15/20 09:53 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Ummm, I suggest before taking this advice you mesure your metering plate fuel restrictions, specs given here are wrong and are out of a holley book. Wrong for a 6bbl, correct for a 4bbl. I do not know why there is this discrepancy,
but there are 2 types of 34-35 plates, you must measure. #63 jets are fine. Cab are you saying .092-.096 idle air bleeds on the center carb, sounds more like super stock end carb main jetting, my 3 sets are all .068 idle air, center carb, .055 on the ends.
Re: 440 six pack idle help [Re: 4406bbl] #2752360
03/15/20 10:15 PM
03/15/20 10:15 PM
California
Tomkcuda Offline OP
Tomkcuda  Offline OP
California
To all, I just posted on you tube on this issue. One thing I did discover is that plugging the air bleed holes on the outer carb with wire actually evened out the idle. I took it for a quick drive though it does not stall, its definatley running rich and some loss of power.
Far as the jet size, it's a 65 due to the size of the cam and is stroked out to 512. More and more I think it has to do with center carb not working properly. I should not have plug the outer bleed holes.
I am trying to keep the original metering block but I might just change it to 134-203 replacement and see what it does. I am pretty sure the outboard carb metering plates are both 34.
https://youtu.be/8X2MP8jzD3A
Re: 440 six pack idle help [Re: Tomkcuda] #2752404
03/16/20 12:45 AM
03/16/20 12:45 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
So you simply proved it is lean and needs more gas at idle. Now you say it is rich... well I hope so as you took half the air away from the emulsion tubes, and are drawing harder on the idle fuel feed restrictions in the end carbs, with the end carb idle screws at 1 full turn. It will be rich at 1 full turn. Until you measure the metering plate restrictions who knows what is in there. I suggest a holley carb manual by alex walordy so you understand how the idle works. I would say you need bigger idle fuel feed restrictions, made bigger .001 at a time. I am assuming the idle air restrictions are stock size. A metering block for the center carb that you can adjust would be good. I used a 600 or 650 double pumper plate on mine to get the drillable idle feeds. You adjust the fuel feeds .001 at a time until it idles with the center carb at 1 to 1-1/2 turns, ends at 1/2 max. Timing needs to be at least 25 on the crank and stable, not bouncing around. No magic here, the idle will take work, I am betting the center carb is open on the transition slots at idle, as a 512 needs more air than a 440, and I don't even want to get into fixing that.... but here goes. It would involve drilling throttle plates, not allowed on this board, most on here think any 6bbl with drilled plates has been modified, no it is factory. Bigger motor, bigger holes, .002-.005 at a time until it idles with the plates closed. Oh one more thing, that big hydraulic cam will not idle clean at 800 rpm like the big roller cams most guys use, so you guessed it, you need more air for that too, bigger holes. Now you know if you really want to fix it.
Re: 440 six pack idle help [Re: 4406bbl] #2752414
03/16/20 02:27 AM
03/16/20 02:27 AM
Not idle air bleeds, my carbs had .092 and .096 fuel restrictor, IE Holley screw in air bleeds acting as the jets on the bottom of the stock metering plates with the original metering holes plug off up
Re: 440 six pack idle help [Re: Cab_Burge] #2752458
03/16/20 09:36 AM
03/16/20 09:36 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Ok, you are right they do not like much more jet. I need to clean up my last post, no emulsion tubes in the outboard
carbs, might call them emulsion wells. Its where the fuel and air become an emulsion in the metering plate to start to become a burnable mix at idle.
Re: 440 six pack idle help [Re: Tomkcuda] #2752845
03/17/20 02:16 PM
03/17/20 02:16 PM
I thought of something else you can check and reset if needed is the fuel, float level. Most Holley like and need the fuel to barely dribble out of the side hole when running at idle speed, if you look closely at your carbs you will notice that the outboard screws for checking the float level are higher than the center bowl is scope Don
t set them in the middle of that hole, that is to high tsk
Let us know how your doing on fixing this issue, six packs rock when you get them right wrench Which is not always easy whistling grin
Re: 440 six pack idle help [Re: Cab_Burge] #2752930
03/17/20 08:20 PM
03/17/20 08:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Cab,you got it backwards,the center is higher than the ends,better check your scope ! no beer
Re: 440 six pack idle help [Re: 62maxwgn] #2752959
03/17/20 09:40 PM
03/17/20 09:40 PM
California
Tomkcuda Offline OP
Tomkcuda  Offline OP
California
I think I will try changing out the center metering block, new air/fuel mixture screws and gaskets. I still think it needs more fuel from center carb. I will post soon as the new metering block arrives. I appreciate all the advise as it seems alot of interest on the topic and outcome. I sure hope I find whats wrong and dont let anyone down. It would be great reference for someone else down the road.
Page 2 of 4 1 2 3 4
