Page 1 of 5 1 2 3 4 5
Engine sits for about a weekend and have no oil pressure. #2751835
03/14/20 12:41 PM
03/14/20 12:41 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
And it loses prime.
Can't get oil pressure started.
Ran it for about 15 seconds and nothing.
Had to put the priming shaft into the distributor hole and use the drill.
Pressure came right up.
Started right up with 72psi.
6 days later, same thing.
This never happened before.
What causes this to happen?And how do you fix it.
Dual milodon oil lines. It's the new external Black oil pump.
Re: Engine sits for about a weekrated car and got oil pressure. [Re: Sammy] #2751847
03/14/20 01:22 PM
03/14/20 01:22 PM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
Did you loop the suction lines above the pump, so that there always is some oil trapped and can´t go back to the pan?
Michael
Re: Engine sits for about a weekrated car and got oil pressure. [Re: Sammy] #2751860
03/14/20 02:20 PM
03/14/20 02:20 PM
if you slow the drill speed down to as best you can match the "cranking" RPM on the intergear will it prime? I'm wondering if it is bleeding off somewhere from a leak or not priming in the first place, just thinking out loud. Post what it ends up being.
Re: Engine sits for about a weekrated car and got oil pressure. [Re: RapidRobert] #2751863
03/14/20 02:33 PM
03/14/20 02:33 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
6 seconds on the drill and it's got oil pressure.
Re: Engine sits for about a weekrated car and got oil pressure. [Re: Sammy] #2751865
03/14/20 02:36 PM
03/14/20 02:36 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
wix/napa filter?
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2751881
03/14/20 03:09 PM
03/14/20 03:09 PM
It is loosing the seal between the pump and the block or somewhere else allowing the oil in the lines to drain down to the oil pan level. Look very closely at the O rings and oil line fittings and maybe even the lines to fix any problems with them wrench
Are you using the stock type oil pump gasket to the block? If so get rid of that twocents That pump only needs the O rings on the pump body and snout to seal properly scope
Re: Engine sits for about a weekrated car and got oil pressure. [Re: lewtot184] #2751886
03/14/20 03:15 PM
03/14/20 03:15 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Originally Posted by lewtot184
wix/napa filter?
Not this build.
Morosos
Re: Engine sits for about a weekrated car and got oil pressure. [Re: Sammy] #2751891
03/14/20 03:27 PM
03/14/20 03:27 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I've had 1 small block Melling pumps pressure by-pass piston stick open and have no pressure when cold. Also an old 2.2's pump did the same.
Big block would be easy to check that piston.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Engine sits for about a weekend and have no oil pressure. [Re: Cab_Burge] #2751893
03/14/20 03:40 PM
03/14/20 03:40 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2, a pin hole will break suction.
Boffin Emeritus
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2751894
03/14/20 03:40 PM
03/14/20 03:40 PM
AndyF Offline
AndyF  Offline
You have an internal air leak in the pickup system. Very common problem with the old Milodon dual external setup. It is less common problem with an internal pickup but can still happen.
Re: Engine sits for about a weekend and have no oil pressure. [Re: AndyF] #2751900
03/14/20 03:47 PM
03/14/20 03:47 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
It's the new Milodon oil pump and cover setup.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2751913
03/14/20 04:20 PM
03/14/20 04:20 PM
AndyF Offline
AndyF  Offline
If it has an external line then that is usually the problem. If it is all internal then you probably have an issue with the pickup tube. Maybe a small crack in the tube or the block is cracked in the threads or something like that. Internal problems are rare but problems with the external lines are very, very common. I stopped using the external line systems because they were such a hassle.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2751916
03/14/20 04:30 PM
03/14/20 04:30 PM
A727Tflite Offline
A727Tflite  Offline
And it loses prime.
When did this all start ?
You make no mention of that.
Fresh engine build, or been on the road untouched for years or something in between?
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2751921
03/14/20 04:39 PM
03/14/20 04:39 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
read title ,said to myself ..bet its got "Dual milodon oil lines"
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Engine sits for about a weekrated car and got oil pressure. [Re: MichaelF] #2751924
03/14/20 04:48 PM
03/14/20 04:48 PM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
Michael
iagree
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Engine sits for about a weekrated car and got oil pressure. [Re: Hemi Allstate] #2751931
03/14/20 05:15 PM
03/14/20 05:15 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
When you have an air leak into the pump, the “loop” makes the situation worse. You now have longer hoses filled with more air than you would with “normal” hoses.
A siphon is a siphon. Stop the air leak and you will lose the siphon.
I went through a season of this with my car. Never an external leak. I had the older cast 2 piece milodon pump. At seasons end, replaced the pump gearset, all the orings, resurfaced the pump cover, and had it hard anodized. (There were some minor radial scratches in the cover)
Never found a clear failed part, but doing this stopped the issue. My suspicion has been that the pump clearances, along with cover scratches, allowed air from the outlet to leak into the inlet. Just my best guess.
Re: Engine sits for about a weekend and have no oil pressure. [Re: AndyF] #2751935
03/14/20 05:28 PM
03/14/20 05:28 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Dual external -12AN lines
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2751936
03/14/20 05:31 PM
03/14/20 05:31 PM
AndyF Offline
AndyF  Offline
Take it all apart, clean and inspect everything. Put it back together with plenty of lube and torque everything to the proper specs. If that doesn't fix it then you'll have to try it again until you find the air leak.
Re: Engine sits for about a weekend and have no oil pressure. [Re: AndyF] #2751940
03/14/20 05:42 PM
03/14/20 05:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the dual swinging pick-ups have issues sometimes. I always used the static dragster pick-ups. that being said i'll be the odd man out here. try a different filter first before dismantling the mechanicals. I've had trouble with drain back on every wix, napa, k&n, and I hate to say but baldwins too. baldwins used to be top notch. the anti-drainback in the wix, etc, etc, doesn't work when the filter is in the horizontal. people will argue this but I doubt most people know or understand drain back. currently i'm using purolator pl30001's without issue. other brands may work too. a $10 test is where i'd go first.
Re: Engine sits for about a weekend and have no oil pressure. [Re: lewtot184] #2752279
03/15/20 06:37 PM
03/15/20 06:37 PM
AndyF Offline
AndyF  Offline
That could work. I use the small Mopar 409 filters on my stuff these days. The little filters fill up with oil faster and they are stronger since they are smaller. Screw one of those on there and see if it solves the problem.
